45901 Members
64 Forums
195326 Topics
Max Online: 2449 @ 05/13/13 01:57 PM
#2661859 - 06/22/12 12:36 PM
GM recalling over 400,000 Chevy Cruzes
Loc: So. Utah
Edited by Bill in Utah (06/22/12 09:56 PM) Edit Reason: removed copyrighted content
2003 Jeep GC 4.0L 171,000 Miles SuperTech HM 10W30 Purolator L14670 Oil Filter
#2661861 - 06/22/12 12:44 PM
Re: GM recalling over 400,000 Chevy Cruzes
[Re: strongt]
Loc: Saratoga, NY
Thanks for the heads up, I'll pass it along to my dad as well.
13 Ford Focus SE 2.0L/8000miles/PP 0W-20/FL-910S 13 Chevy Traverse 3.6L/2000mi/FF 85 Honda Shadow VT500C/33k mi /Castrol powerRS 5W-40
#2661883 - 06/22/12 01:02 PM
[Re: strongt]
Loc: MN/ND
Pretty quick to start a recall with only 2 reported/investigated cases, at least the solution is simple.
Edited by Brenden (06/22/12 01:03 PM)
1991 Acura Integra - 257k/???k B18B Swap Oil: Maxlife 5w30/Purolator P14459
1995 Honda Civic - Built B17A1 + 4.4FD ITR 5spd
Built Not Bought.
#2661885 - 06/22/12 01:06 PM
[Re: Brenden]
Loc: ventura, ca
Pretty quick to start a recall with only 2 reported/investigated cases, at least the solution is simple. I actually see it as a good thing. Rather than wait like they no doubt would have in the past, just admit something is wrong and fix it.
#2661930 - 06/22/12 01:58 PM
[Re: strongt]
Loc: Alberta, Canada
So...CNN isn't national news??? I heard about this all the way up in Canada this morning on a local small time radio station....so this isn't international news either then?? Come on...this is the same as all the other recalls being issued for every other company out there lately I can go through threads on this forum for the past few months and every main stream company has had a recall lately... {removed non GM topic to keep on subject}
Edited by Bill in Utah (06/22/12 09:55 PM) Edit Reason: trying to keep the bashing out of the thread.
09 Corolla 1.8L-180Kkms(112Kmi)-PYB,Denso 05 LeSabre 3.8L-110Kkms(69Kmi)-PYB,Baldwin 97 Suburban 5.7L-375Kkms(231Kmi)-PYB,Baldwin
All with mpg > EPA
#2661936 - 06/22/12 02:02 PM
[Re: strongt]
Loc: Upstate NY
Good to know.
The shield design is one reason I keep sucking out the oil with my MityVac come oil change time.
And, any more details on the manual transmission thing? I DON'T want the dealer monkeying with my car's manual transmission now that I've got it shifting the way I like it!
EDIT: Looks like the MT car issue is when the clutch is fully worn out and somebody keeps driving, the transmission could burp fluid onto the shield. The original shield modification supposedly takes care of that issue too.
Edited by sciphi (06/22/12 02:11 PM)
2009 Honda Fit Sport 2012 Chevrolet Cruze Eco
#2661944 - 06/22/12 02:08 PM
[Re: strongt]
Loc: USA
I guess GM never figured their cars would ever leak oil or have worn clutches...
#2661953 - 06/22/12 02:14 PM
[Re: NHGUY]
Loc: Upstate NY
I guess GM never figured their cars would ever leak oil or have worn clutches... There are two documented incidents where sloppy dealer oil changes appeared to cause engine fires. The cars were both serviced at a dealer for an oil change, and 15 minutes later both were burning on the side of the road. Correlation? Yep. Causation? Maybe. These engines are pretty new to leak oil...
Edited by sciphi (06/22/12 02:14 PM)
#2661962 - 06/22/12 02:27 PM
[Re: sciphi]
Loc: Saratoga, NY
I guess GM never figured their cars would ever leak oil or have worn clutches... There are two documented incidents where sloppy dealer oil changes appeared to cause engine fires. The cars were both serviced at a dealer for an oil change, and 15 minutes later both were burning on the side of the road. Correlation? Yep. Causation? Maybe. These engines are pretty new to leak oil... +1 I can easily see how this happened.
#2662264 - 06/22/12 08:40 PM
[Re: strongt]
Loc: Upstate NY
The "fix" so far is hacking away 75% of the underbody tray so any spilled oil goes to the ground instead of collecting on the tray.
What a silly idea, and one that could come back to bite them in the rear end. Underbody panels are a cheap way of cleaning up an aerodynamically horrendous area of the car, and GM decided to eliminate the Cruze's. Also, it does a marvelous job of keeping road debris and salt away from the engine and transmission. And, GM spent a LOT of time/effort developing this specific panel. Eliminating it is throwing away all the benefits for nothing!
I got this car for the fuel economy, and do my own oil changes. ANYTHING that might affect the fuel economy and eliminate a designed engine bay protection feature is a big deal to me, and hacking it away since some dealer "techs" can't change oil isn't the right response!
Keep trying, GM!
#2662324 - 06/22/12 09:59 PM
[Re: strongt]
Loc: UT
Okay folks. Lets KEEP this about GM and the CRUZE recall. Every MFG is going to have "issues" and GM is taking care of this one. I've removed off topic bashing about other brands and bashing about GM in single word posts. Bill
#2664305 - 06/25/12 08:26 AM
[Re: strongt]
Loc: North Carolina
I've owned a Cruze Eco 6MT for about 20 months and 16K miles. Very pleased with this car, 34.5 MPG average with lots of city driving !!!! Wow...I noticed this "problem" at my first oil change(500 miles). Yes a little of the oil lands on the belly pan as it is draining from the engine. Proper use of shop towel = problem solved. Which raises the question: How many oil change techs don't clean up spills after they are done? Good day. Rickey.
#2664501 - 06/25/12 12:18 PM
[Re: strongt]
Loc: Sunny Florida
Sad that this is really a result of sloppy service and not a true defect.
On my Chrysler, which is well shrouded underneath, there are channels that lead to a central hole. Pretty simple...
"In a democracy, dissent is an act of faith." J. William Fulbright Best ET-12.79 @ 111 mph 4340 pounds, Street tires Just like we go to Publix
#2664558 - 06/25/12 01:40 PM
[Re: strongt]
Loc: Ontario, Canada
So what's the deal with the clutch being involved? Are people slipping them so much that they ignite the oil? Do dry clutches actually throw sparks even with a proper aggressive start? Or do people drive around with them slipping? How can a dry clutch last for more than a few minutes with any sort of slippage?
07 Focus ZXW, 5spd manual, 52,000km GTX 5W20 03 Tracker, 5spd manual, 212,000km, PP 5W30 95 Neon, 3spd auto, 282,000km, Rotella T6 5W40 "Cone Killer!"
#2664577 - 06/25/12 02:07 PM
[Re: IndyIan]
Loc: Upstate NY
So what's the deal with the clutch being involved? Are people slipping them so much that they ignite the oil? Do dry clutches actually throw sparks even with a proper aggressive start? Or do people drive around with them slipping? How can a dry clutch last for more than a few minutes with any sort of slippage? They're probably worried that a new manual transmission owner burns up the clutch and boils the MT fluid teaching themselves how to drive stick-shift.
