U joints
by dlundblad
30 minutes 52 seconds ago
Yamaha Bolt XV950
by FWR132
Today at 02:12 AM
Mower revs up/down when cold
by DrRoughneck
Today at 12:14 AM
2015 dodge journey crossroad
by hardcore302
Yesterday at 10:17 PM
Looking for new mechanical pencil
by Merkava_4
Yesterday at 09:33 PM
Sewer gasses in bathroom
by sxg6
Yesterday at 09:13 PM
I am a idiot, a fool or what? UOA coming soon!
by Vern_in_IL
Yesterday at 08:57 PM
4ft LED T8 replacement bulbs 6.97$
by Rand
Yesterday at 08:35 PM
Low cost sedan looks better than expensive one
by HTSS_TR
Yesterday at 08:22 PM
Toyota red in motorcycles/snowmobi
les
by Altydoc
Yesterday at 07:42 PM
Looking at some old posts
by Oldmoparguy1
Yesterday at 07:35 PM
Towing a heavy trailer
by Donald
Yesterday at 07:31 PM
Bigford545, FWR132, smancer, FJCurious, kburns
58899 Registered Users
31 registered (1foxracing, bmod305, b1amgm47, alanwayne1908, Bandito440, billt460, 3 invisible), 770 Guests and 6 Spiders online.
58899 Members
66 Forums
253479 Topics
Page 2 of 2 < 1 2
#2640001 - 05/30/12 08:01 AM Re: Burning/Using Delo 400 [Re: Chris142]
Jim Allen Offline
Loc: NW Ohio
Here is another tidbit of useful info for you Chris. According to TSB 86-10-14, the maximum acceptable soot level for the IDI in 1986 was 3 percent.
Jim Allen
Keepin' the Good Old Days of Four Wheeling Alive
#2650739 - 06/10/12 10:30 PM Re: Burning/Using Delo 400 [Re: Chris142]
Chris142 Offline
Loc: apple valley, ca
Ok im down 1 qt. It's halfway between full and add. Took 1000 miles. We will see how long it takes to get to the add mark. I do run it pretty hard. 75mph is 3000 rpm and thats where I run it on the fwy.
Reading around on the net it's not uncommon for the 6.9 to use some oil especially if worked hard. Some people say that the valve stem seals are the cause. I'm thinking of putting in 2 qts of high milage oil when it gets 2 qts low and seeing if that improves it any.
02 Wrangler Chevron 10w30
87 F250 napa 15w40
04 Tahoe super-s 5w30
Z400 Lucas 10w30
KLR250 Maxima 10w40
Can am maveric delo 5w40
#2651590 - 06/11/12 08:34 PM Re: Burning/Using Delo 400 [Re: Chris142]
Jim Allen Offline
Loc: NW Ohio
It won't but I guess you have to try. ( : < )
Jim Allen
#2656304 - 06/16/12 08:28 PM Re: Burning/Using Delo 400 [Re: Chris142]
Chris142 Offline
OK it burned the 2nd qt real fast. down 2 qts in 1100 miles
87 F250 napa 15w40
Z400 Lucas 10w30
KLR250 Maxima 10w40
#2660921 - 06/21/12 02:36 PM Re: Burning/Using Delo 400 [Re: Chris142]
addyguy Offline
Loc: Canada
Here's an idea...tad expensive, but MAY be worth a shot.
Drain the oil, and do an OC with a full-synthetic 15W-40 or 5W-40, a real high-quality one, like Amsoil DEO, M1 TDT, or Valvoline Premuim Blue Extreme 5W-40.
I'm wondering if a higher-quality lube will resist volatility and burn-off better, or if it cleans deposits and lets the rings seal better.
Might be worth a shot, Chris?
2010 Kia Soul 2U - 2.0L I-4, auto, 89k miles.
MM Supreme 5W-30; QS 14612 filter.
#2664076 - 06/24/12 10:50 PM Re: Burning/Using Delo 400 [Re: Chris142]
Chris142 Offline
I ran the truck pretty hard today and last Saturday. So far the level seems to have not dropped much if any. I think that the valve stem seals are the problem. It runs and starts too good to be sick IMO.
87 F250 napa 15w40
Z400 Lucas 10w30
KLR250 Maxima 10w40
#2664718 - 06/25/12 05:26 PM Re: Burning/Using Delo 400 [Re: Chris142]
LeakySeals Offline
Loc: MA
Are you checking the level at the same time and place? The diff between 5mins after shutting down and and checking in the morning after sitting could be up to 1/2 qt. Checking on uneven ground can do that too.
02 Camry XLE 2AZ-FE 352k M1 HM 5w30 (RIP, broke pist rod 7/2/2016)
06 Escalade 135k. M1 5w30
#2664865 - 06/25/12 07:37 PM Re: Burning/Using Delo 400 [Re: addyguy]
TFB1 Offline
Loc: VA
Originally Posted By: addyguy
I'm wondering if a higher-quality lube will resist and burn-off better, or if it cleans deposits and lets the rings seal better.
99.99% of the time burning oil is not a volatility problem, poor ring seal due to worn or stuck rings allows oil to escape by them and into the cylinder... But for viscosity, this condition cares not about what oil is being used...
If it is stuck rings(my bet it isn't), a oil with good detergents could help over the long term...
#2664946 - 06/25/12 08:48 PM Re: Burning/Using Delo 400 [Re: LeakySeals]
Chris142 Offline
Ya I'm checking it in the morning after I drive it to work. Same Level Parking spot every time.
87 F250 napa 15w40
Z400 Lucas 10w30
KLR250 Maxima 10w40
#2666684 - 06/27/12 12:40 PM Re: Burning/Using Delo 400 [Re: Jim Allen]
NOSPRK Offline
Loc: Santa Rosa, Ca
Originally Posted By: Jim Allen
A quart in 800 is not great but here are some tips:
1) Check your CDR valve (Crankcase Depression Regulator), which functions as a crankcase ventilation device and when inoperative, will cause the engine to consume more oil. The CDR is designed to separate the liquid oil from the crankcase blowby gasses and returns the oil to the engine. The CDR mounts to the back of the intake manifold. If you see a lot of oil in the intake, it's probably a bad CDR, though sometimes it just gums up. Mine has just failed for the first time since new.
2) Don't top off with this engine. When it reaches the add mark, it takes two quarts to bring it up to the full mark. When it reaches that point, only add one quart. That upper quart will burn off quickly but the second one much more slowly. Been doing this with mine since I was given that tip by a fellow Ford tech back in the '80s.
Over the 25 years I've owned 6.9L, it has used oil... no matter what oil... in regular amounts. You can safely say they were designed to use some oil. I've used both Delo and Rotella, both 15W40 and 10W30 and there is no significant difference in the amount used. I even had some 15W40 Royal Purple in there for one OCI and it even slurped some of that. I think you will find the same with the Tection.
Here is something from an old Ford TSB:
ENGINE OIL LEVEL CHECKING PROCEDURE for LIGHT TRUCK 1983-86 E AND F SERIES TSB:
In order to measure engine oil levels consistently and accurately, it is useful to employ the following recommendations:
Park vehicle on level surface. Low oil level readings will be obtained if the vehicle is sloped away from the dipstick.
Have engine at normal operating temperature as oil expands at the rate of one percent per 25~F (14~C) change and the dipstick is calibrated to the engine at normal operating temperature. In addition, allow at least a fifteen (15) minute engine shutdown period to assure that oil contained in the upper parts of the engine has returned to the oil pan.
Have dipstick loop directed inboard as this eases installation and minimizes wiping action on oil level gauge.
Read oil level on both sides of gauge and use highest level (reading) for the actual engine oil level.
jim here hit the nail on the head...
also the 6.9L engines had "loose" valve seals compared to 7.3L engines. some put them on 7.3L engines when rebuilding. it does burn a little more oil but some people would rather have well lubed valves then fork out some more oil.
drove a $500 81 240d mercedes 4000miles from northern cali to the TX/LA border (orange, TX) and back.. burned 2 gallons of oil the whole trip. got a REAL MPG of 28-34. that car never smoked. just consumed oil.
#2691566 - 07/22/12 09:26 AM Re: Burning/Using Delo 400 [Re: Chris142]
Chris142 Offline
update: the 2qts of maxlife has slowed the oil consumption a lot. roughly 2000 miles and it's still over 1/2 way up the stick. I'm going to run it another 500 miles or so then dump it since its not a diesel oil
87 F250 napa 15w40
Z400 Lucas 10w30
KLR250 Maxima 10w40
Page 2 of 2 < 1 2
