Idling question
by thunderfog
1 minute 5 seconds ago
Lodge Sportsman Grill
by hatt
33 minutes 14 seconds ago
2016 Honda Civic factory filter, CUT OPEN
by car51
Today at 05:34 PM
Fishing reel drag grease
by bernau
Today at 04:26 PM
Sulfated Ash, wt%, ASTM D 874 test questions
by mbacfp
Today at 04:02 PM
HD radio
by 007
Today at 03:51 PM
Front end repair
by possum328
Today at 03:49 PM
Purolator 10111 Red Can
by FordBroncoVWJeta
Today at 03:30 PM
Carquest #R85372, 2013 E-250 van, 4,500k
by car51
Today at 03:03 PM
Strange failure: Starter AND flywheel cogs ripped
by lars11
Today at 02:22 PM
My email from Castrol about Magnatec
by Tech819
Today at 02:13 PM
Audi 5000 / Known Stop-Leak Compatible w/ CHF 7.1?
by Miles07PT
Today at 01:41 PM
_hashtagusername, larrybroad123, dr_p, CapHead, rowebil
58632 Registered Users
81 registered (aquariuscsm, Alex_V, andrewlg, 2009Edge, anonobomber, bbhero, 6 invisible), 1897 Guests and 7 Spiders online.
58632 Members
66 Forums
252413 Topics
Page 1 of 2 1 2 >
#265369 - 05/07/03 03:29 PM Techron, Gunk, Stp, Lucas, Neutra... Demo
BOBISTHEOILGUY Offline
Loc: Ocala, Florida
Just for the fun of it, I went to my shop and took my new video camera and made a short video clip doing a back yard demo on the lube properties of some fuel additives. I used 5 different fuel additives to show the differences between some.
This might take a few for some to download if you're using a slow server.
Fuel additive demo
#265370 - 05/08/03 09:21 AM Re: Techron, Gunk, Stp, Lucas, Neutra... Demo
Loc: Ocala, Florida
Has anyone had any luck downloading a viewing this video? Just wonder if it's working?
#265371 - 05/08/03 09:59 AM Re: Techron, Gunk, Stp, Lucas, Neutra... Demo
acranox Offline
Loc: Massachusetts
yeah, I downloaded it, and watched it. It's interesting. The motion was a little jerky.
Pardon my ignorance, but why does a fuel additive need lubrication properties? Is it just for upper cylinder lubrication? I guess I figure it's more important for the oil to do that part of the job, and for a fuel additive to clean the fuel system and injectors/carb.
if it is related to upper cylinder lubrication could someone explain that a little to me, and explain why the right oil can't sufficiantly fill this role?
#265372 - 05/07/03 10:04 PM Re: Techron, Gunk, Stp, Lucas, Neutra... Demo
Bogatyr Offline
Loc: Averill Park, NY
Bob,
Works fine for me...I'm on a cable modem, so the download time was slow, but not bad. How big was the file?
Thanks for the info. I've used RedLine Si1 for a while. It would have been interesting to see how that compared. In any case, I have a pantload of Neutra now, so I'll work my way through that now as well.
Bogatyr
#265373 - 05/07/03 10:17 PM Re: Techron, Gunk, Stp, Lucas, Neutra... Demo
Loc: Ocala, Florida
if it is related to upper cylinder lubrication could someone explain that a little to me, and explain why the right oil can't sufficiently fill this role?
There's several reasons, but let me just put this one on the table..
Here is what a basic injector looks like inside, give or take a valve or two.
Now, mind you two things, what does gas do to oil? Cleans it off? So, when you have a mechanical device such as the injector, there's several concerns, one, water or corrosion/rust.. Two, the piston and valves need some sort of lubrication, and three, the tip needs to stay clean and seals need to stay lubed.
Natural lubrication if fuel is from sulfur but the down side is carbon build up from the burning of sulfur. So, in some additives, they will clean, but what you need to ensure that you keep these parts lubricated and maintain a good Resistance to rust and corrosion so all these parts maintain optimal working condition.
There is horror stories from some of the local ford dealerships where someone puts in a fuel additive,(powerstrokes) and this messes up the injectors, mainly from seal damage. Reason is the lubrication is broke down, seal gets damaged and injectors start to fail. Lubrication is very important to a proper fuel system where motor oil cannot go to as that is not a primary side of the motor. Thats just a glimpse of why a fuel additive should have some type of lubrication qualities among other things.
#265374 - 05/08/03 06:41 AM Re: Techron, Gunk, Stp, Lucas, Neutra... Demo
Tom Smith Offline
Loc: Indianapolis, IN USA
Great Video! Almost 66mb but it downloaded in 4 minutes with my cable modem [Wink] Thank God for Broadband.
Nice Job on the Video!
Tom in INdy
#265375 - 05/08/03 06:53 AM Re: Techron, Gunk, Stp, Lucas, Neutra... Demo
digitaldrifter91 Offline
Loc: cali
great video! i downloaded it in 2.4 minutes. hehe cable is great, u get what u paid for.
#265376 - 05/08/03 09:24 AM Re: Techron, Gunk, Stp, Lucas, Neutra... Demo
quadrun1 Offline
Loc: Fairfield County, CT
Good server you got there, Bob! Where's it located?
IE said I got a fast 500 KB/sec to Long Island, New York (cable modem; ISP=optimumonline.net).
65.6 MB in 2 min 12 sec.
Thanks,
Jason
#265377 - 05/08/03 08:45 PM Re: Techron, Gunk, Stp, Lucas, Neutra... Demo
Loc: Ocala, Florida
Thanks for the reply's.
For those of you with slower systems, I broke them down into smaller segments..
Here is
131 Neutra
Gum Out
Stp
Lucas
Techron
and here is the End Summary from these little tests
Hopefully I'll figure a way to resize these file to a smaller size. See if this will make it easier to run.
To answer the service question....
Goto my front page, Http://www.bobistheoilguy.com and click on the yellow banner at or near the top.
[ May 09, 2003, 11:48 AM: Message edited by: BOBISTHEOILGUY ]
#265378 - 05/09/03 09:08 AM Re: Techron, Gunk, Stp, Lucas, Neutra... Demo
Mystic Offline
Loc: Colorado
It was worth it to download the videos. It may have been simple tests, but very revealing. I am using Neutra now as a fuel system cleaner and it works well. It was fascinating to see the differences in just a few fuel system and injector cleaners. What a difference!
It would be interesting to see additional fuel system and injector cleaners tested-such as Berryman B-12, BG44K, Redline and Amsoil.
One thing I have noticed since I started to use Neutra is that I seem to have better fuel mileage. And the car runs much better.
#265379 - 05/09/03 06:07 AM Re: Techron, Gunk, Stp, Lucas, Neutra... Demo
GSV Offline
Loc: Utah
[Cheers!]
Bob, this is a great website. Thank you for the efforts you have made to spread good information to others on the internet.
I downloaded this video at work and 3 other guys watched it and learned something from it.
[Patriot]
Greg
#265380 - 05/09/03 08:29 AM Re: Techron, Gunk, Stp, Lucas, Neutra... Demo
GimmeTorq Offline
Loc: IL
quote:
That would be cool!!
#265381 - 02/02/05 04:56 AM Re: Techron, Gunk, Stp, Lucas, Neutra... Demo
sxg6 Offline
Loc: ME
is there any chance of these videos becoming available again?
#265382 - 02/02/05 08:11 AM Re: Techron, Gunk, Stp, Lucas, Neutra... Demo
kcryan Offline
Loc: Rochester NY
i too would love to see them
#265383 - 02/02/05 09:08 AM Re: Techron, Gunk, Stp, Lucas, Neutra... Demo
OdinsRageSS Offline
Loc: Schaumburg
id love to see the lucas one!
Page 1 of 2 1 2 >
