Lubrication Engineers vs Schaeffer's
by Dad2leia
05/04/16 05:49 PM
Tesla reports a worse than expected loss $282.3m
by Nate1979
05/04/16 05:27 PM
Using P/S fluid in a system that takes ATF ok?
by gregk24
05/04/16 05:24 PM
Redoing an old retrofit job headlights please help
by OtisBlkR1
05/04/16 05:19 PM
Mobil at Walmart + Mobil Rebate + Ibotta= $1/quart
by macarose
05/04/16 05:13 PM
Case 2470 tractor oil filters has slits
by njohnson
05/04/16 05:09 PM
Neglected Can Am Spyder
by Panzerman
05/04/16 04:22 PM
Considering a new Lexus ES - Durability?
by David_Corbett
05/04/16 04:02 PM
2016 Audi S4 Factory Fill UOA at 3,793 Miles
by CrazyJeeper
05/04/16 03:25 PM
epoxy to secure asphalt shingle?
by Digital2k2
05/04/16 03:21 PM
$75 Seized engine
by demarpaint
05/04/16 03:19 PM
Question on a VIN number..
by dblshock
05/04/16 03:18 PM
NatedeScate, Bogie69, Cali, Fyko, Palmer
57794 Registered Users
95 registered (AandPDan, 69GTX, 1JZ_E46, Al, 11 invisible), 0 Guests and 1 Spider online.
57794 Members
66 Forums
248471 Topics
Page 1 of 2 1 2 >
#2652771 - 06/13/12 02:23 AM Another non-synthetic 0w-20
The Critic Offline
Loc: Walnut Creek, CA
http://www.castrol.com/castrol/sectiongenericarticle.do?categoryId=9040510&contentId=7061133
I was on the Castrol website earlier and noticed that GTX SynBlend is being offered in a 0w-20. The MSDS was issued on 4/10 so I am guessing that this is a new product.
Obviously, 0w20 can be blended without needing to use mostly synthetic base stocks. So, buyers should not assume that all 0w-20s will always be full-synthetic.
11 Prius - 129k - M1 EP 0w20/OE
07 Accord 2.4 - 111k - M1 5w20/FPS Filter
10 Altima 3.5 - 34k - M1 EP 5w30/FU
92 Previa - 160k - Chevron 5w30/Wix
#2652778 - 06/13/12 03:21 AM Re: Another non-synthetic 0w-20 [Re: The Critic]
Indydriver Offline
Loc: Indiana
Yes, Honda has had house brands in both full syn and blend 0W-20 since they introduced their COP made oils.
That's slicing the market pretty thin, isn't it?
Your thread begs the question for 0W-20 oil users (I now have two late model OE 0W-20 engines): Is saving a couple of bucks a quart ENOUGH for you to use a lower quality oil in your baby?
Edited by Indydriver (06/13/12 03:26 AM)
2014 Camaro 2SS/RS LS3 Vert 10,000 M1
2012 Sienna 50,000 TGMO
2011 Accord V6 50,000 TGMO
2007 Tahoe 90,000 M1
2004 Intrepid 105,000 M1 5W-30
#2652785 - 06/13/12 03:45 AM Re: Another non-synthetic 0w-20 [Re: Indydriver]
The Critic Offline
As of now, Honda/CP and Valvoline Durablend were the only ones with a non-syn 0w-20.
Now Castrol has entered the market in that area.
#2652816 - 06/13/12 06:02 AM Re: Another non-synthetic 0w-20 [Re: Indydriver]
Hokiefyd Offline
Loc: North Carolina
Castrol already offers a 0W-20 in their Edge line; I've seen it at Advance Auto. I didn't notice the price; it likely carries a huge premium there. If Castrol can get this GTX 0W-20 in a jug on the shelves at major discount retailers, for $20/jug, then it should be a great value. "Synthetic" and "semi-synthetic" are largely marketing terms anyway, especially because we don't know the actual blended ratios of the base stocks.
Cheers,
Jason
2009 Honda Ridgeline RTL
2005 Acura MDX Touring
#2652832 - 06/13/12 06:47 AM Re: Another non-synthetic 0w-20 [Re: Hokiefyd]
Indydriver Offline
Loc: Indiana
And this gets to the root of my question. My new Toyota V6 comes with TGMO full syn 0W-20 along with a 10,000 mile OCI. I wonder if Toyota says the design and performance differences beyween full syn and semi-blends don't matter. Note that Toyota specifically advises reducing the OCI in HALF when 5W-20 (presumably conventional) is used. I have no doubt that the cheapest 0W-20 available will find it's way into these engines and I wonder if Toyota engineers left enough safety margin in the performance of blends to go the full OCI.
IMHO, 10,000 miles is pushing the envelope for any oil when designers HAVE NO CLUE how the vehicle is driven every day. Now, they are reducing the margin for shear and viscosity deterioration. Some one is going to take this too far.
Edited by Indydriver (06/13/12 06:54 AM)
#2652881 - 06/13/12 07:42 AM Re: Another non-synthetic 0w-20 [Re: The Critic]
buster Offline
Loc: NJ
I'm not so sure about this. You do need mostly syn base oils.
From Mobil.com FAQ:
10. Are all 0W-20 viscosity oils synthetics? Yes. The 0W-20 viscosity grade requires synthetic-base oils to meet low-temperature performance standards. >>back
Most if not all 0w20's are synthetic. I am not sure if I believe you can make a 0w20 blend of mostly GrpII+.
#2652894 - 06/13/12 08:02 AM Re: Another non-synthetic 0w-20 [Re: Indydriver]
Hokiefyd Offline
Loc: North Carolina
Right now, the "cheapest 0W-20 available" is Mobil 1 AFE 0W-20, if by cheapest you mean most inexpensive. Now, if by cheapest you mean the poorest quality, I revert back to my belief that the differences in "synthetic" and "semi-synthetic" are largely in marketing, and anything meeting the 0W-20 specification is going to have very good performance properties.
And for another data point, Hondas are out there doing 10k mile OCIs on conventional 5W-20. I'd say that even the worst quality 0W-20 out there will be sufficient for Toyota's 10k mile OCIs.
Cheers,
Jason
#2652923 - 06/13/12 08:48 AM Re: Another non-synthetic 0w-20 [Re: The Critic]
ARCOgraphite Offline
Loc: N.H, U.S.A.
Indydriver:
ILSAC GF-5 "conventional" must beat a PAO synthethic standard test oil in fuel mileage and must also be OLM capable and pass TEOST deposit test (for turbo and ring area deposits) in the heavier grades. So what is compromised? And what would be the "real" higher group(iv+v)synthetic you are buying that's not a specialty or racing product? Amsoil Signature? I cant think of ANY major player currently that advertises as "fully synthtetic" that uses only group iv and higher.
2014 Nissan Rogue S CVT, OC#4 13740mi-Castrol Magnetec 5W30+Nissan 15208-9E01A Filter
2015 Forester 6MT 5Door, OC#5 31478mi-PEAK 0W20+Subaru Filter
#2652935 - 06/13/12 09:08 AM Re: Another non-synthetic 0w-20 [Re: The Critic]
DrDusty86 Offline
Loc: TX
ARCO- RP AZO....
#2653015 - 06/13/12 11:04 AM Re: Another non-synthetic 0w-20 [Re: The Critic]
Loc: N.H, U.S.A.
I think that's a nyet on the RP for their street oils.
#2653037 - 06/13/12 11:42 AM Re: Another non-synthetic 0w-20 [Re: ARCOgraphite]
Indydriver Offline
Loc: Indiana
Originally Posted By: ARCOgraphite
Indydriver:
Are you saying that you believe there is no performance difference in the 0W-20 viscosity between an oil marketed as "full synthetic" and one priced two bucks lower labeled "synthetic blend" (within brand)?
Edited by Indydriver (06/13/12 11:45 AM)
#2653050 - 06/13/12 11:56 AM Re: Another non-synthetic 0w-20 [Re: The Critic]
addyguy Offline
Loc: Canada
Nice to see another option in the 0W-20 grade.
Castrol now has 3 0W-20's - they have Edge 0W-20, Edge w/SPT (black bottle) 0W-20, and Syntec Blend 0W-20.
However, I doubt we will ever see it up here, we still only have a tiny bit of Edge 0W-20 up here, no mainstream stores carry it.
2003 Mazda Tribute LX V-6, 196,850 miles...DEAD.
MM F1 5W-20 conventional + Bardahl + top-offs.
MM MPH2 filter.
#2653948 - 06/14/12 08:45 AM Re: Another non-synthetic 0w-20 [Re: Indydriver]
Loc: N.H, U.S.A.
Indydriver:
Maybe a marginal cold crank improvement and hopefully a small VI improvement. Otherwise they meet the same spec.
#2653967 - 06/14/12 09:02 AM Re: Another non-synthetic 0w-20 [Re: The Critic]
05Blazer Offline
Loc: Illinois
Hokie
"I'd say that even the worst quality 0W-20 out there will be sufficient for Toyota's 10k mile OCIs" (Hokiefyd).
I bet that Peak 0W20 wouldn't make it to a 10kOCI without some significant wear. Have you seen the VOA on that stuff, yuck!
12 GMC Yukon SLT 4WD 5.3L 8K
Mobil1 EP 5W30 AC DELCO PF48
11 Honda Pilot EX 4WD 3.5L 20k
Penn Plat 0W20 OEM filter
#2654580 - 06/14/12 08:19 PM Re: Another non-synthetic 0w-20 [Re: The Critic]
ottotheclown Offline
Loc: new york
Me, I face a $80 bill for Subaru syn 0-20 for my 2012 Forester at the stealer. Guess what I am going to do???
ottotheclown
Page 1 of 2 1 2 >
