Typically I change my oil 300-600mi before the 5k mark. Otherwise I can get busy & beyond 5k. This sample was right at 5k, the factory recommended interval.
Guessing 3-4mo on this oil. Drove mostly highway, 20mi 1-way. Also a few mile shopping trips. I've driven some mountain roads, no trails, on this oil. Every once in a while I will put the pedal to the medal & try to shift before 'redline'.
Warranty was 5yr, so OEM TOY 5w30 was used until then & much after...I have a contact at dealership & can get oil changed for a tip. I've used PP or PU (Platinum/Ultra) a few times. Mostly PP. Next change will be with PU & I will get another UOA done. The 3rd will be done much later, 100k+
I've used Bosch oil filters but will change back to OEM tall filter out of convenience & piece of mind. Everything except shocks/coils (off FJ Cruiser) are OEM. Will be switching to Bilstein HD this fall/next spring.
