O'Reillys: did you find something new?
by Hokiefyd
05/21/13 11:43 AM
2014 Forester - Top Scoring SUV
by buster
05/21/13 11:15 AM
machining rotors
by Donald
05/21/13 11:08 AM
Life Expectancy of Storing New Oil Filters
by 147_Grain
05/21/13 09:55 AM
Plug for Honda Mowers Pre-gapped?
by gofast182
05/21/13 09:33 AM
How clogged is clogged.
by GreeCguy
05/21/13 08:04 AM
Shoplifting, way out of hand here
by CourierDriver
05/21/13 07:18 AM
Honda HR214 Transmission
by firefighter11
05/21/13 07:01 AM
J B WELD
by browning300wsm
05/21/13 06:00 AM
5W-40 - semi or full synthetic....
by Shannow
05/21/13 05:37 AM
friction stir welding
by SteveSRT8
05/21/13 05:14 AM
Fuchs GT1 XTL 0W20 - 1,674km- 2010 Honda CR-V 2.4L
by IPCOlsenVZ
05/21/13 04:36 AM
Kevinfc, toolhead, tempsho, JD2, oledad86
45483 Registered Users
138 registered (01rangerxl, 1999nick, 4DVette, anonobomber, andyd, 99Saturn, 13 invisible), 1707 Guests and 257 Spiders online.
45483 Members
64 Forums
193710 Topics
Max Online: 2449 @ 05/13/13 01:57 PM
#2644375 - 06/04/12 12:59 AM MityVac bleeders
ARB1977 Offline
Loc: North Texas
Im interested in the MV6830. Would a 12 gallon compressor be enough to supply air for the bleeder?
2002 Tacoma 3.4L 147K (as of 03-13-13)
M1 HM 5W30 / M1 Filter
2008 CRV 2.4L 86K (as of 03-23-13)
PP 5W20 / Purlator Synthetic Filter
#2644567 - 06/04/12 09:48 AM Re: MityVac bleeders [Re: ARB1977]
Gabe Online   happy
Loc: Chicago, IL
They don't really use that much air; your compressor should be able to keep up without draining the tank.
Also of note, they barely have any suction. A warm differential will take around 3-5 minutes to drain. It does not bleed brakes very well either.
#2644572 - 06/04/12 09:53 AM Re: MityVac bleeders [Re: Gabe]
ARB1977 Offline
Loc: North Texas
Interesting. Why would it not bleed brakes very well?
#2644600 - 06/04/12 10:24 AM Re: MityVac bleeders [Re: ARB1977]
Gabe Online   happy
Loc: Chicago, IL
It takes too long to get it started draining. The MityVac cannot be lower than bleed screw since the air bubble raise faster than the brake fluid comes out. If the MityVac is placed on top of the fender, then it does not have enough suction to pull the brake fluid up.
By the time I get it draining right, I could have done all four by hand.
#2645358 - 06/05/12 01:10 AM Re: MityVac bleeders [Re: Gabe]
ARB1977 Offline
Loc: North Texas
Would keeping it just above the bleed screw work?
#2645359 - 06/05/12 01:13 AM Re: MityVac bleeders [Re: Gabe]
ARB1977 Offline
Loc: North Texas
Or would getting the hand pump work better? Thanks for the help.
#2645800 - 06/05/12 02:01 PM Re: MityVac bleeders [Re: ARB1977]
HTSS_TR Offline
Loc: Irvine, CA
Mityvac MV6830 is too expensive and only do one job. Mityvac 7201 costs less and do many jobs, all you need for brake bleeding with 7201 is get a sturdy flexible hose that fit the bleed screw.
'94 LS400 300,000+ miles
'00 E430 140,000+ miles
'04 S2000 40,000+ miles
