Recyling Pays Off!
by Delta
08/28/16 04:49 PM
Smitty's $1.69/qt at Kmart this week, until 9/3
by slacktide_bitog
08/28/16 04:47 PM
ONR, what else?
by buck91
08/28/16 04:05 PM
Parking lot accidents involving backing up
by mclasser
08/28/16 03:49 PM
NAPA Gold oil filters 7060
by ZiTS
08/28/16 03:30 PM
Collection of VOAs and UOAs
by dccode
08/28/16 03:12 PM
Monopoly and Innovative
by HTSS_TR
08/28/16 03:12 PM
Vintage in House Gas Incinerator
by Brybo86
08/28/16 02:39 PM
2014 f150 5.0 5w20 pup 7200 miles
by robo339
08/28/16 02:34 PM
Tuff Torq K46 oil question
by BrianF
08/28/16 02:21 PM
by dccode
08/28/16 02:00 PM
Fram Ultra XG8A 6800 miles [Cut Open]
by Run
08/28/16 01:01 PM
DALpilotMike, Safetyfirst, rwood, USARMOR, GV00
58943 Registered Users
83 registered (Bandito440, 2002 Maxima SE, AZjeff, bdcardinal, Atesz792, Astro14, 8 invisible), 1539 Guests and 8 Spiders online.
58943 Members
66 Forums
253681 Topics
Page 1 of 2 1 2 >
#2638828 - 05/28/12 10:24 PM stuck spark plug toyota 4.7 tundra
Highline9 Offline
Loc: ca.
Been trying to get out stuck plug. I have soaked it with wd40 and marvels for 4 hours yesterday. I put some bees wax down in plug hole today with engine good and hot melted in. Gonna try removing plug when engine is cold in the morning. Plug will turn about a half of turn.
2010 challenger R\T
2014 mercedes glk350
2003 hyundai elantra
1992 dodge w250 cummins
#2638880 - 05/28/12 11:35 PM Re: stuck spark plug toyota 4.7 tundra [Re: Highline9]
mechtech2 Offline
Loc: Chicago Area
Go back and forth. Over and over with lube.
Good luck!
#2638887 - 05/28/12 11:52 PM Re: stuck spark plug toyota 4.7 tundra [Re: mechtech2]
tjblacken Offline
Loc: WA, USA
wintergreen oil is the stuff to use.
#2638889 - 05/29/12 12:05 AM Re: stuck spark plug toyota 4.7 tundra [Re: mechtech2]
jorton Offline
Loc: San Antonio, TX
That is scary, good job not breaking it off.
Good luck!
+1
"If everything seems under control, you're just not going fast enough."
- Mario Andretti
#2638914 - 05/29/12 01:47 AM Re: stuck spark plug toyota 4.7 tundra [Re: Highline9]
AVB Offline
Loc: Georgia
I would be afraid the wax would seal the threads so that a good penetrant like kroil can get in now. Any idea how many miles are on the plugs? My grandma went 160,000m on the oem ngks in her BMW. I caught heck trying to get them out, I tried fogging the engine to maybe loosen them from the inside but it didn't help.
#2638947 - 05/29/12 05:40 AM Re: stuck spark plug toyota 4.7 tundra [Re: Highline9]
Trav Offline
Loc: MA, Mittelfranken.de
You need something better than WD40 if you cant get Kroil use PB blaster.
Warm up the engine (not hot) for about 5 min and soak the plug for about 10 min and work it back and forth till it comes out.
Aluminum expands more than the steel plug and warming it will provide the little bit of extra clearance it needs to come out easier.
I suggest once its out you run a spark plug thread chaser down it, you can get this at any parts store and use just a little never seize on the new plugs so you never have this problem again.
When using never seize just snug them up firmly, not need to wrench down on them as the never seize reduces the amount of torque needed.
#2638979 - 05/29/12 07:21 AM Re: stuck spark plug toyota 4.7 tundra [Re: Highline9]
Astro14 Online   content
Loc: Virginia Beach
Trav's got it: PB'laster, warm aluminum, back and forth, gently...if you're forcing it, you're likely messing up the threads.
Get a thread chaser, you can use a tap, but the thread chaser is less aggressive...and you'll want the threads cleaned up once this is out...
32 Packard 15W40
90 4Runner 10W40 Edge
02 Volvo V70 T5 0W40 M1
02 Volvo V70 XC 5W40 PU
05 MB S600 0W40 M1
16 Tundra 1794 TGMO
#2639014 - 05/29/12 08:29 AM Re: stuck spark plug toyota 4.7 tundra [Re: Highline9]
Hokiefyd Offline
Loc: Top of Virginia
I've used electric impact guns to remove plugs before. The hammering action loosens the threads without stripping them. Intuitively, you'd think an impact gun would kill the threads, but it's really the slow, gradual torque of a breaker bar or similar that will twist them.
I used an electric impact gun to zip all eight plugs out of my '97 Cadillac Northstar engine with 140,000 miles on the plugs. They had never been removed prior. They all came out fairly easily with the gun.
Cheers,
Jason
2009 Honda Ridgeline RTL
2005 Acura MDX Touring
#2639019 - 05/29/12 08:42 AM Re: stuck spark plug toyota 4.7 tundra [Re: Highline9]
Highline9 Offline
Loc: ca.
Still stuck but I have more movement. Im gonna let it soak with a penetrant oil overnight next.
2010 challenger R\T
#2639070 - 05/29/12 09:28 AM Re: stuck spark plug toyota 4.7 tundra [Re: Highline9]
Trav Offline
Patience, its going to take time when they are that tight.
The more you can move it back and forth with penetrating oil down there the better.
#2639240 - 05/29/12 12:16 PM Re: stuck spark plug toyota 4.7 tundra [Re: AVB]
mechtech2 Offline
Loc: Chicago Area
Excellent point! [wax is a seal]
But I guess he could use wax with a propane torch to keep it lubed.
#2639293 - 05/29/12 01:07 PM Re: stuck spark plug toyota 4.7 tundra [Re: Highline9]
Highline9 Offline
Loc: ca.
Heated the socket, broke lose the wax. Plug still moves the same amount. I found some liquid wrench in garage, it is soaking.
2010 challenger R\T
#2639296 - 05/29/12 01:10 PM Re: stuck spark plug toyota 4.7 tundra [Re: Trav]
SOHCman Offline
Loc: USA
I have to disagree with "just snug them up" when using anti seize. Decrease the torque by 5 to 10 percent if it makes you feel better, but you should be using a torque wrench to install plugs, and you should be using anti sieze even at full torque setting. I have never had any trouble using full torque+anti sieze On my Japanese aluminum engine heads. Ymmv
Do or do not, there is no try. USA
#2639454 - 05/29/12 04:12 PM Re: stuck spark plug toyota 4.7 tundra [Re: Highline9]
Highline9 Offline
Loc: ca.
Well got the plug out seems like the liquid wrench did its job. Saved my neighbor some cash. Patience was the key. Put new plug in with permatex anti-sieze, threads were not damaged.
2010 challenger R\T
#2639456 - 05/29/12 04:19 PM Re: stuck spark plug toyota 4.7 tundra [Re: SOHCman]
Trav Offline
I'm a big advocate of using a torque wrench but you assume the OP has a torque wrench small enough to be accurate at this low setting and he has room to use it, a 1/2" drive isn't going to cut it.
More importantly you are not taking into account that the thread strength maybe less at this point.
Reducing torque when using never seize is a must on spark plugs.
The last thing the OP needs is to be trying to install time serts in this engine.
Page 1 of 2 1 2 >
