Pick my oil '75 Plymouth Gran Fury 400 big block
by gallydif
06/30/16 08:40 PM
Spark plug resistance R5 vs R6
by Ndx
06/30/16 08:39 PM
Firestone TF2876 C&P
by holdorf333
06/30/16 08:38 PM
Castrol High mileage or Valvoline Maxlife
by NH73
06/30/16 08:30 PM
Got to experience cornering ABS today
by LoneRanger
06/30/16 08:10 PM
Engine Heat Soak - What causes sluggishness
by ryan2022
06/30/16 08:03 PM
What product was that?
by another Todd
06/30/16 07:19 PM
choice between reciprocating corded saws
by edwardh1
06/30/16 07:04 PM
Is the driving experience getting worse?
by fdcg27
06/30/16 06:24 PM
Scratched wheel
by gabriel9766
06/30/16 05:52 PM
Gear oil added to motor oil in engine
by TiredTrucker
06/30/16 05:52 PM
Purolator 10111 Cut Open- Red Can- NEW
by FordBroncoVWJeta
06/30/16 05:51 PM
MNfarmer33, doublegarage, goatrancher, jameson223, graywolf001
58322 Registered Users
111 registered (69GTX, andyd, AMC, 2002 Maxima SE, 901Memphis, 2015_PSD, 11 invisible), 1709 Guests and 7 Spiders online.
58322 Members
66 Forums
251062 Topics
#2631296 - 05/20/12 12:37 AM A/C High Vacuum Pump Oil
Fitz98 Offline
Loc: Florida
I have an A/C High Vacuum Pump and am looking for an oil alternative that I can use for a day to pull a vacuum on my Expedition A/C. I cannot find AC high vacuum pump oil locally on a Sunday. Napa has one, but are closed. Home Depot has an ISO 68 CAT Pump oil. WOuld that do the trick? Any other recomendations?
#2631565 - 05/20/12 01:22 PM Re: A/C High Vacuum Pump Oil [Re: Fitz98]
ryan_of_the_e34 Offline
Loc: gainesville, florida
Sorry that I can't help you out with where you could get Vacuum Pump oil on a sunday afternoon (short of stealing a bottle out one of the vacuum pump boxes at harbor freight)...
What I can suggest (which might help):
Is your vacuum pump really fancy? Would you be opposed to using a cheaper model? If you don't really care about the "quality" of the vacuum being drawn, you can always go down to your local autozone and rent (for some deposit between 100 and $200) one of their pumps, and procure the oil during the hours that a napa/grainger/&c. would be open. I don't think I've been to an Autozone in Florida (within the last 7 or 8 years) that didn't rent vacuum pumps. Might want to call for availability, though, in the event that a particular store's unit has been made unavailable.
Edited by ryan_of_the_e34 (05/20/12 01:23 PM)
#2631613 - 05/20/12 02:37 PM Re: A/C High Vacuum Pump Oil [Re: ryan_of_the_e34]
AVB Offline
Loc: Georgia
I never thought about vacuum pump oil. I think it should be fine with any a/c oil, I would use what ever the a/c system uses. I would make sure to use an oil that was compatable with the refrigerant you are using.
#2631635 - 05/20/12 03:00 PM Re: A/C High Vacuum Pump Oil [Re: Fitz98]
mechtech2 Offline
Loc: Chicago Area
If you vacuum it wrong, you can end up with refrigerant oil in the pump.
#2631680 - 05/20/12 04:41 PM Re: A/C High Vacuum Pump Oil [Re: ryan_of_the_e34]
Fitz98 Offline
Loc: Florida
I got the CAT Oil at Home Depot. I was able to draw the vacuum down to -22Hg. The target is -29 min. Is it possible that the type of oil affects the amount of vacuum that can be obtained? Pump is a Fast Vac DV 42.
#2631742 - 05/20/12 05:58 PM Re: A/C High Vacuum Pump Oil [Re: Fitz98]
Kestas Offline
Loc: The Motor City
Vacuum pump oil is a refined oil that has the light weight molecules removed, and is left with only heavy weight molecules. The idea is that you don't want the oil to start vaporizing from the pump oil on the vacuum side, and contaminating the components in the vacuum. Once the oil starts vaporizing, that's the ultimate vacuum you can achieve. Conventional oils aren't as clean in that respect.
I always have vacuum pump oil available to me. I've never chanced using anything else.
