Kendall GT-1 synthetic oils
by SR5
02/09/16 02:43 AM
2015 F 150
by BISCUT
02/09/16 01:19 AM
Ever have an "old guy" day?
by daves87rs
02/08/16 10:25 PM
Fram Ultra C$11.87 (Ontario)
by dgunay
02/08/16 10:16 PM
dodge 4.7 fram problem?
by joel95ex
02/08/16 09:45 PM
ok until oil change 4.7 dodge
by joel95ex
02/08/16 09:41 PM
0w20 vs 5w20 running on a Mazda 3 2014
by Stewie
02/08/16 09:37 PM
5w20/30 4.4L Castrol Edge WM Canada $24.88
by Stewie
02/08/16 09:31 PM
Back to greasing stuff...
by JHZR2
02/08/16 09:04 PM
Castrol Import Multi question
by Carguy21
02/08/16 08:20 PM
2005 F150 steering rack
by Colt45ws
02/08/16 08:12 PM
Tinkering around today with my Cold Air Intake
by GumbyJarvis
02/08/16 07:51 PM
paulp, ATLjunkcars, jqgz, ukpdxwrx, TerrenceRocks
56865 Registered Users
24 registered (billt460, dec219644, Char Baby, 3800Series, Black, 3 invisible), 498 Guests and 197 Spiders online.
56865 Members
66 Forums
244434 Topics
Page 1 of 2 1 2 >
#2627120 - 05/15/12 02:26 AM Paper gasket,RTV or both?
SkyGod Offline
Loc: Ohio
I usually use RTV on the cover side to keep gasket in place during install.
Some guys prefer gasket only with no sealer.
Some guys prefer RTV only.
Anyone know the correct way?:)
Pennzoil Platinum Fanboy
#2627122 - 05/15/12 03:13 AM Re: Paper gasket,RTV or both? [Re: SkyGod]
Scott_Tucker Offline
Loc: Santa Cruz, Ca.
I don't use rtv on paper gaskets I use the appropriate sealer such as gaskacinch. You can use rtv alone too with good results. It all depends on who is doing the work. It doesn't matter as long as the installer knows what he is doing. The most important thing is that the sealing surfaces be clean and dry.
2012 Honda Civic Si, Dyno Blue Pearl
#2627140 - 05/15/12 05:13 AM Re: Paper gasket,RTV or both? [Re: Scott_Tucker]
demarpaint Offline
Loc: NY
+1 Use one or the other but not both. At least that is what worked best for me over the years.
God Bless Our Troops
#2627157 - 05/15/12 06:35 AM Re: Paper gasket,RTV or both? [Re: SkyGod]
eljefino Offline
Loc: ME
It depends. If it's something like a thermostat gooseneck and someone nicked or scratched the mating surface... getting the old paper gasket off... RTV and the paper gasket will fill that in nicely. I like having the thickness and compressability of a paper gasket. Got one for a hyundai that was a nice thick neoprene type. OT I'm glad after all these years to see o-rings finally used for thermostats a lot more.
Only downside to RTV, IMO, besides dry time is if you get too much down a blind bolt hole it can hydrolock the bolt and keep it from bottoming out properly.
#2627161 - 05/15/12 06:42 AM Re: Paper gasket,RTV or both? [Re: SkyGod]
Trav Offline
Loc: MA, Mittelfranken.de
I use Indian Head on Paper gaskets. Its old school but so are the gaskets, they work well together.
#2627226 - 05/15/12 08:57 AM Re: Paper gasket,RTV or both? [Re: SkyGod]
beast3300 Offline
Loc: Ohio
I like gorilla snot*** for paper gaskets but just to hold in place.
****Gorilla snot aka 3M weatherstrip adhesive.
'03 Regal GS L67 3.29 GR:, PUP 5w30/TG3980, Filtermag
'99 Grand Prix L36: QS Defy 5w30/TG3387A, Filtermag
#2627305 - 05/15/12 10:28 AM Re: Paper gasket,RTV or both? [Re: SkyGod]
dnewton3 Offline
Loc: Indianapolis, IN
I've used paper, RTV, and the combination.
When properly prepared, all three work equally well.
When poorly done, leaks are eminent.
'Nuff said.
Conventionals vs. Synthetics isn't about which is "better"; it's about which lasts longer, while assuring safe operation, in relation to cost. Any product can be over or under utilized. The same applies to filters.
Make an informed decision; first consider your operating conditions, next determine your maintenance plan, and then pick your lube and filter. Don't do it the other way around ...
#2627485 - 05/15/12 02:42 PM Re: Paper gasket,RTV or both? [Re: SkyGod]
INDYMAC Offline
Loc: Magnolia, TX
I have found RTV to be very difficult to clean off before re-applying. Absolutely nothing wrong with its sealing capability though.
2013 Toyota Tundra DC 4X4 5.7L FFV
2012 Toyota 4Runner 2WD SR5
2004 Honda S2000
#2627506 - 05/15/12 03:06 PM Re: Paper gasket,RTV or both? [Re: SkyGod]
I have had an absolute ton of cars come in leaking coolant because RTV was used to seal something like coolant under pressure so be very careful. The best seal comes from a paper gasket with proper cement or an o-ring. It can be done with RTV, just be very careful. Let it dry before adding coolant and starting the engine.
#2627784 - 05/15/12 09:22 PM Re: Paper gasket,RTV or both? [Re: SkyGod]
umungus1122 Offline
Loc: PA
I've always preferred a gasket with the gasket adhesive.
"Just walk away, and I promise you safe passage out of the wasteland."
'95 Chevy 1/2t 305 200k - Mobil semi-syn 7500 5w-30, Motorcraft filter
#2627832 - 05/15/12 10:43 PM Re: Paper gasket,RTV or both? [Re: SkyGod]
MolaKule Offline
Loc: Iowegia - USA
For differential covers, defintately Gasket plus the Black RTV.
Coat the gasket with a thin layer of RTV, wait a few minutes, and then apply while slightly tacky.
Above all, make sure the surface has been wiped clean with a solvent to remove the oil film.
And wait at least 1/2 hour before filling.
Edited by MolaKule (05/15/12 10:45 PM)
Monday Plan: Drink coffee, be awesome, and ignore negativity. smile
#2627838 - 05/15/12 11:03 PM Re: Paper gasket,RTV or both? [Re: SkyGod]
Knox Offline
Loc: Kansas, USA
If the gasket is silicone (neoprene), i use just the gasket.
If it's a paper gasket, i just use a little RTV to hold it. (assuming both surfaces are even and in good shape)
If the manufacture calls for RTV, then i lay a 1/4" bead all the way around and on both sides of the bolt holes. Place the cover on and hand tighten, wait "at least" a hour and then tighten to spec.
If it's a cork gasket, i throw it away and just use RTV. Unless it requires a gasket for clearance. Then Use a thin layer of RTV on both sides and apply while tacky.
2009 Subaru Legacy (Special Edition)
Delo XLE 10w-30 and Napa Gold 7712
#2627909 - 05/16/12 04:41 AM Re: Paper gasket,RTV or both? [Re: SkyGod]
demarpaint Offline
Loc: NY
If I use a paper gasket I spray it with Permatex Red. That stuff is great, the gasket sticks in place and I've never had it leak. RTV works well in certain instances. For example if a valve cover gasket lip is distorted from someone trying to pry it off and bends it. Or your favorite parts store doesn't have a gasket you need and you're in a bind to get a job done. The trick is to be patient and allow the product to dry before running the engine.
#2627911 - 05/16/12 04:43 AM Re: Paper gasket,RTV or both? [Re: SkyGod]
Jim Allen Offline
Loc: NW Ohio
Overall, I prefer paper and RTV BUT it depends on the cover. Some covers were designed for RTV ONLY and some were designed for paper. The ones designed for paper don't do as well with RTV only, while the ones for RTV do fine with just RTV of course but OK with paper added (assuming a gasket is available). Neoprene/silicon gaskets are great if they are available for the application.
Jim Allen
Keepin' the Good Old Days of Four Wheeling Alive
#2628291 - 05/16/12 01:59 PM Re: Paper gasket,RTV or both? [Re: dnewton3]
mechtech2 Offline
Loc: Chicago Area
'Nuff said.
This is right.
And you can get RTV off later - it can be very tough with other sealants.
If it leaks, it was not clean, or you did not let it set up before refilling and running it.
And TV is the EASIST to clean of, no
Page 1 of 2 1 2 >
