BW-44-44 Transfer Case special fluid
by -SyN-
06/25/16 02:27 PM
mini inspection camera for androi phone
by bmwjohn
06/25/16 02:15 PM
Cause of noisey serpentine belt
by 007
06/25/16 01:48 PM
Purolator Boss 14610 C and p
by bbhero
06/25/16 01:33 PM
Ear hair - remove, ignore, trim ???
by Mr Nice
06/25/16 01:04 PM
Best Oil for [censored] Intek 19 HP Mower
by beadvised
06/25/16 12:43 PM
by bbhero
06/25/16 12:42 PM
Was the original Mobil 1 a Straight 20?
by Gene K
06/25/16 12:23 PM
Valvoline Maxlife 0w20 Synth blend?
by HKPolice
06/25/16 12:11 PM
Walmart Canada (GTA) Valvoline MaxLife 0w20 $18.88
by HKPolice
06/25/16 11:49 AM
Makita B04510 Palm Sander - Fix?
by user52165
06/25/16 11:41 AM
Red Arrows
by Whitewolf
06/25/16 11:20 AM
accobra66, Diehl, Hotrodls1, Koloa, codeman021
58257 Registered Users
79 registered (86cutlass307, -SyN-, 360kid, 69GTX, 007, 2015_PSD, 10 invisible), 2027 Guests and 11 Spiders online.
58257 Members
66 Forums
250798 Topics
#2623408 - 05/10/12 06:17 PM Delo 400LE synthetic 5w-40 ok for gas engine ?
rkpatt Offline
Loc: SE
I found a pretty good price on Delo 400LE 5w-40 and want to use it my Honda (obviously a gasser ) instead of the Valvolene Synpower 5w-30 synthetic. Would this be an ok substitute ? - Thanks
#2623418 - 05/10/12 06:24 PM Re: Delo 400LE synthetic 5w-40 ok for gas engine ? [Re: rkpatt]
Lead Shoes Offline
Loc: Mn
5w40 is over kill for any stock Honda, its only useful in a Honda when you are burning a lot of oil, have some pretty through internal engine modification or a turbo.
Even with a turbo or N/A build, plenty of people run 5w30 in their 300whp civics and have no lucubration failures.
You can certainly run it though, I'm running HDEO in my civic right now and it performs the same and hasn't lost any MPG, so if the price is right, do it.
Edited by Brenden (05/10/12 06:25 PM)
1992 BMW 325i 176k
Castrol 0w40/Mahle
#2623422 - 05/10/12 06:26 PM Re: Delo 400LE synthetic 5w-40 ok for gas engine ? [Re: rkpatt]
Chris142 Offline
Loc: apple valley, ca
Ya I wouldn't run it in a Honda. I would put it in my 4.0L Jeep though.
02 Wrangler super-s 10w30
87 F250 delo 15w40
04 Tahoe super-s 5w30
Z400 Lucas 10w30
KLR250 Maxima 10w40
Can am maveric delo 5w40
#2623437 - 05/10/12 06:43 PM Re: Delo 400LE synthetic 5w-40 ok for gas engine ? [Re: rkpatt]
artificialist Offline
Loc: Florida
When Xw40 gets used in an N/A Honda engine, it makes the engine feel like it is weighted down.
I would only use it in an engine that specifies an Xw40 oil, or is rebuilt not to factory specs.
2010 Lancer Ralliart Sportback
#2623479 - 05/10/12 07:24 PM Re: Delo 400LE synthetic 5w-40 ok for gas engine ? [Re: artificialist]
abycat Offline
Loc: grande prairie AB
I use the same oil in a bunch of stuff. A lawn mower 3x generators, twin cyl kohler, 1989 propane chev 350, but if an engine didnt spec it i would not especially a honda. If you honda was used alot on a track or autocross with some power adders or if it is worn maybe.
Arent those things easy on oil? Id throw some cheap dino and change it per manual. If concerned about cost. Just my 2
Edited by abycat (05/10/12 07:26 PM)
2004 f350 6.0
2011 nissan versa hb
#2623630 - 05/10/12 09:36 PM Re: Delo 400LE synthetic 5w-40 ok for gas engine ? [Re: rkpatt]
GoalieFergy53 Offline
Loc: Tacoma, Wa
I'm 300 miles away from my next oil change (current fill is Delo 400LE 5w40 and next fill will be the same). My current fill will have run 5k and I plan to get a UOA to see the status of my engine since it will be my first UOA since owning it.
Many Saab owners run Rotella T-6 with excellent results, so same should be for Delo. Saabs are spec'd for 40wt though.
98 Saab 900S Delo400LE 5w40-NG/Wix-RL MTL
94 Chevy LLV Delo400LE 10w30-NG/Wix
97 Go-4 Interceptor Delo400LE 10w30-NG/Wix
#2623804 - 05/11/12 04:42 AM Re: Delo 400LE synthetic 5w-40 ok for gas engine ? [Re: rkpatt]
dnewton3 Offline
Loc: Indianapolis, IN
First of all, neither your post nor your signature gives us any indication of what kind of gasser you have (age, design, model, condition, operating parameters, fuel mileage goals, OCI plan, yada yada yada ...)
Also, you need to define what "an ok substitue" means to you ...
Will a 5w-40 HDEO syn work "well enough" in a gasser made for light oils? Sure. It will likely protect from wear, as most any decent API "S" rated oil would do as long as it's in spec for the engine.
Will a 5w-40 HDEO syn be "optimum" in a small gasser? No. The engines and lubes are designed in concert with each other. Other products "will work" but may not be "optimum". All things considered, I'm doubt Honda designed your engine with a 40 grade in mind. It may not hurt, but it's probably not "optimum".
So, the questions:
Why are you seeking a syn HDEO 40 grade? Are you (falsely) presuming that an HDEO is going to be "better" somehow?
Have you established a base-line of UOA performance, to judge how much "better" you perceived change will be?
Have you analyzed your cost basis, relative to the alternatives, to see where the ROI might lay?
Are you trying to commonize your oil stash to one lube, to reduce shelf and storage complexity? (could be a reason to do so, depending upon your fleet)
Or, are you just winging it because you think HDEOs are "better" somehow, for all applications?
Edited by dnewton3 (05/11/12 04:43 AM)
Conventionals vs. Synthetics isn't about which is "better"; it's about which lasts longer, while assuring safe operation, in relation to cost. Any product can be over or under utilized. The same applies to filters.
Make an informed decision; first consider your operating conditions, next determine your maintenance plan, and then pick your lube and filter. Don't do it the other way around ...
#2623815 - 05/11/12 05:21 AM Re: Delo 400LE synthetic 5w-40 ok for gas engine ? [Re: dnewton3]
rkpatt Offline
Loc: SE
That's the main reason. I have a diesel too .
"Are you trying to commonize your oil stash to one lube, to reduce shelf and storage complexity? (could be a reason to do so, depending upon your fleet)"
From what I see here , I will continue using the 5w-30 synthetic .
#2624047 - 05/11/12 11:05 AM Re: Delo 400LE synthetic 5w-40 ok for gas engine ? [Re: rkpatt]
dnewton3 Offline
What diesel do you have?
Have you considered T5 in 10w-30? It has the same cold crank properties of 5w-40 T6, is in about every WalMart, and has a decent price. It's approved for gasser and diesel app's; hard to beat for an "all around" lube in a mixed fleet.
#2624060 - 05/11/12 11:18 AM Re: Delo 400LE synthetic 5w-40 ok for gas engine ? [Re: rkpatt]
m37charlie Offline
Loc: Alaska
As I have stated elsewhere in this forum, Mobil 1 0W40 has more detergent/TBN (11.8 vs about 10) and approx. equal Zn/P compared to virtually any CJ4 HDEO. Assuming that's what you're after in running an HDEO in a Honda. And unparalleled viscometrics.
Charlie
05 Unimog U500/Unicat camper/Delvac 1 SHC ACEA E4/E5
09 BMW X5 35d/Delvac1 LE 5W30
88 Toyota OJ50LV OM314 motor D1 SHC
52 Dodge M37/Hercules diesel
#2624265 - 05/11/12 02:35 PM Re: Delo 400LE synthetic 5w-40 ok for gas engine ? [Re: rkpatt]
dnewton3 Offline
True, but it's only CF rated:
http://www.mobil.com/USA-English/Lubes/PDS/GLXXENPVLMOMobil_1_0W-40.aspx
That may or may not be an issue depending upon his diesel application.
Edited by dnewton3 (05/11/12 02:38 PM)
#2624382 - 05/11/12 05:29 PM Re: Delo 400LE synthetic 5w-40 ok for gas engine ? [Re: dnewton3]
m37charlie Offline
Loc: Alaska
Yes - if it is a European diesel car, pre DPF, it will be fine.
If it is a US pickup type, obviously not.
Charlie
#2627326 - 05/15/12 11:01 AM Re: Delo 400LE synthetic 5w-40 ok for gas engine ? [Re: rkpatt]
benjy Offline
Loc: pa
over weight AKA viscosity rob power for sure, read oil 101-02 etc on this site, even though my 275hp modified 1.8T jetta spec 5-40 i ran 10-30 atm amsoil @ 10,000 change intervals, changed filter @ 5,000 when i started driving less-retired, until i traded in at 199,xxx, still had 20" of vac and only took oil at hi, 25 lb boost
