Hard starting LCT snow engine..
by JTK
4 minutes 21 seconds ago
low-temperature oil gelling reversible?
by DrRoughneck
Today at 12:51 PM
I HAD to do it!
by Kuato
Today at 12:24 PM
Why Erin Esurance vanished from TV
by Benzadmiral
Today at 11:39 AM
Engine Light Advice
by coopns
Today at 11:14 AM
Caution UOA - PP 10W30 6881m on 2001 Jeep 4.0
by Donald
Today at 11:09 AM
What happened to the thin oil movement?
by camrydriver111
Today at 10:57 AM
Mastercraft Strategy tires (I'm cheap)
by Bgallagher
Today at 10:41 AM
Mobil Delvac ATF in a regular car transmission
by SuperValue
Today at 10:35 AM
Dumped the smartphone!
by andrewg
Today at 10:27 AM
Need to replace plugs - cooper,Iridium, or Plat?
by MoreCowbellAz
Today at 10:25 AM
Child bicycle trailer?
by Quattro Pete
Today at 09:19 AM
RTS, jhmed80, engus, Rob_Pol, Nick24w
56901 Registered Users
115 registered (05LGTLtd, 19kj57, akela, 87sammy, Al, 99TLC, 11 invisible), 1782 Guests and 199 Spiders online.
56901 Members
66 Forums
244602 Topics
#2610591 - 04/26/12 04:03 PM Alternative to Kubota SUDT & UDT hydraulic fluids?
Jason280 Offline
Loc: GA
I am getting ready to do the 350hr service on my Kubota L4330, and I am curious if there is an equivalent to Kubota's SUDT or UDT hydraulic fluid that I can purchase locally. I have been told that Shell Donax TD is an acceptable substitute for UDT, but cannot find confirmation. The tractor does not have the hydrostatic transmission, it uses the GST (glide-shift). Thanks!
#2610670 - 04/26/12 05:44 PM Re: Alternative to Kubota SUDT & UDT hydraulic fluids? [Re: Jason280]
Texan4Life Offline
Loc: Texas
Shell and Mobil have good tractor trans/hydraulic fluids. I have used Travller brand from tractor supply since that is what is available locally. Have used it in older IH tractors and a newer Mahindra with no problems. I have also heard of ppl using Napa trans/hyd fluid also.
just check the label for the specs it meets.
2005 Dodge Ram 1500, 5.7L
[Current Fill: PP 0w-20][Baldwin B2-HPG]
#2610690 - 04/26/12 06:06 PM Re: Alternative to Kubota SUDT & UDT hydraulic fluids? [Re: Jason280]
Donald Online   content
Loc: Upstate NY
I would use a tractor hydraulic/transmission fluid. You can get it at Walmart, Sams, TSC, NAPA, etc. I have used it in my Bobcat with no problems. If anything it would be more picky about the hydraulic fluid since its hydrostatic drive. My old Kubota L225 had a screen filter for the hydraulic fluid. My Bobcat has two filters (over $100 combined) along with pressure and temp senders.
2015 Subaru Forester 2.5 engine/CVT PP & M1
2001 Jeep Grand Cherokee Laredo 4.0 - PP & M1
1999 Dodge Ram 2500 w/Cummins - Rotella T6 & M1
#2610781 - 04/26/12 07:41 PM Re: Alternative to Kubota SUDT & UDT hydraulic fluids? [Re: Donald]
Jason280 Offline
Loc: GA
No, its the glide Shift Transmission, not the hydrostatic.
#2612423 - 04/28/12 07:25 PM Re: Alternative to Kubota SUDT & UDT hydraulic fluids? [Re: Jason280]
doitmyself Offline
Loc: MI
These are quite different fluids, so you should first find out in your owners manual which one is recommended for that system.
The UDT is just a common universal tractor hydraulic fluid (THF) and if you look at most of these labels, you almost always find UDT listed as one that it "meets the specs."/suitable for, etc.. Here's one, the Shell Donax label that I found in 10 seconds on Google: http://www.canyonstateoil.com/msds-sheets/Shell_Oil/DonaxTD.pdf
The SUDT is a premium multi viscosity THF that is much more expensive, but it lasts longer and handles cold temps. better. Being in Georgia, if your manual recommends UDT, that should work well and be much cheaper. Personally, I would only use the SUDT if I was in a colder climate and/or the particular machine recommended only to use that one, or money was no object whatsoever.
Chevron makes a fluid that meets/exceeds SUDT specifications, but everywhere I read on the interweb says it costs even more.
Respected BITOG member Jim Allen said his testing of a particular "Farm Store" THF's showed it had a weak additive package. Everyone marches to a different drummer regarding what they think will work best in their machine.
Google will answer your questions.
"There are things you do that put food on the table, and there are things you do that feed your soul." I am blessed to have them be the same things.
#2612443 - 04/28/12 07:44 PM Re: Alternative to Kubota SUDT & UDT hydraulic fluids? [Re: Jason280]
doitmyself Offline
Loc: MI
Edited by doitmyself (04/28/12 07:50 PM)
#2617676 - 05/04/12 04:10 AM Re: Alternative to Kubota SUDT & UDT hydraulic fluids? [Re: Jason280]
erikaB Offline
Loc: California, USA
I think the shell is just fine.
#3212469 - 12/10/13 02:53 PM Re: Alternative to Kubota SUDT & UDT hydraulic fluids? [Re: Jason280]
JR Offline
Loc: Michigan born but my heart bel...
I have used supertech brand in the 2004 rtv-900. I am at the 1000hr mark and no complants. that reminds me to get a pail. i have a cv shaft and strut in the front to replace and that requires refill of the diff and brake case. i will change the trans while i am at it. money money money.
i do like sudt and prefer it but it is too price.
Ken
