F1 - 2016 Belgian Grand Prix
by gofast182
08/24/16 07:55 PM
Ethernet card uograde needed?
by NHHEMI
08/24/16 07:27 PM
2012 Suzuki DL1000 VStrom Oil Recommendations
by RHALL
08/24/16 07:24 PM
Audio/Micro Adapter Help
by coopns
08/24/16 07:18 PM
Purolator boss 2222 6,200 miles
by gabriel9766
08/24/16 06:49 PM
Fram Ultra paint peeling
by Run
08/24/16 06:26 PM
Cell phone mount suction cup doesn't stick
by mclasser
08/24/16 06:02 PM
2008 Nissa Versa 110,000 miles second report.
by Datarock
08/24/16 05:07 PM
Best Oils for Direct Injection & Turbo Engines
by BobsArmory
08/24/16 04:45 PM
cheap upgrade to win 10 from win 7 s/n
by bmwjohn
08/24/16 04:25 PM
trimmer loses power when hot
by motor_oil_madman
08/24/16 04:21 PM
NAPA "GOLD" #1358, 10,080 miles CUT OPEN
by car51
08/24/16 04:01 PM
ShadowSix, warfire, Brutus232, gojoneeded, jimmyangst
58911 Registered Users
118 registered (andrewlg, 2015_PSD, 29662, 2002 Maxima SE, Al, 11 invisible), 1736 Guests and 10 Spiders online.
58911 Members
66 Forums
253509 Topics
#2608603 - 04/24/12 05:20 PM Stihl BG55 bogs at full throttle
nomochevys Offline
Loc: Ky
Had the blower out today with the throttle locked wide open and it started to bog out as if it was starving for fuel. I released the lock and could only get it to run at 1/2 to 3/4 throttle before it would start to bog out. The air filter is new and clean.
I let it cool and ran it some more and it never gave me a problem. Starts fine and idles good and Im a bit miffed by what is causing this. These things always get worse over time. The blower is 13 years old by the way. Any ideas?
#2608608 - 04/24/12 05:24 PM Re: Stihl BG55 bogs at full throttle [Re: nomochevys]
xxch4osxx Offline
Loc: Cedarbrae, Ontario
You using fresh gas?
2015 RAM SXT Crew Cab 5.7 with 6 speed tranny.
2008 Mazda 3 GS Sport Hatchback 5sp MT (Girlfriend's car)
#2608611 - 04/24/12 05:26 PM Re: Stihl BG55 bogs at full throttle [Re: nomochevys]
Tones Offline
Loc: Houston, TX
Have you ever removed the spark arrestor screen from the muffler? These get clogged and cause the symptoms you describe.
'11 Toyota Avalon
'11 Toyota Corolla
'10 Honda Civic
'13 Ford F-150 Supercab 5.0
#2608625 - 04/24/12 05:45 PM Re: Stihl BG55 bogs at full throttle [Re: Tones]
nomochevys Offline
Loc: Ky
I have not but will check that. Before anybody says the gas is bad I run a Stihl chainsaw and Shindiawa weed wacker out of the same jug and both of them run fine. Dealers always blame the gas it seems like.
Anyway, I will check that and pull the plug also. Im thinking maybe the fuel line may be going bad and sucking in too much air?
#2608629 - 04/24/12 05:53 PM Re: Stihl BG55 bogs at full throttle [Re: nomochevys]
Warstud Offline
Loc: MIchigan
Run some fuel system cleaner thru it.
#2608630 - 04/24/12 05:53 PM Re: Stihl BG55 bogs at full throttle [Re: nomochevys]
thorromig Offline
Loc: BerksCounty/Pa.
Gas does go stale after 30 days is what my Stihl dealer told me and with mine which is 2 years old--its true. I find it cheaper and less wasteful to just buy small quantities for specific purpose! What works for me will not work for all im sure!
00 Dodge Ram 5.2L 4x4 Defy 10W40 FU
06 Ford Explorer 4.0L Smittys 5W30 FL820s
08 Acura TL 3.2L PUPP 5W20 BD+
08 Road King Classic 103c.i. Big Bore/6spd
#2608632 - 04/24/12 05:57 PM Re: Stihl BG55 bogs at full throttle [Re: nomochevys]
btanchors Online   content
Loc: Herndon, VA
I'll bet Tones has it figured out. I have a Stihl Blower, not sure if it's the exact model number, but I had the very same symptoms and discovered the spark arrestor completely clogged.
#2608639 - 04/24/12 06:07 PM Re: Stihl BG55 bogs at full throttle [Re: nomochevys]
doitmyself Offline
Loc: MI
Lots of great advice here. Many people don't realize that 2 cycle engines are best run at wide open throttle (chainsaws under load)and they carbon up with excessive idle or mid throttle.
I disagree with the 30 day gas life, especially when using Stihl 2 cycle oil (it has stabilizer). At my workplace we have no problems with months old gas.
Spark plugs do go bad on these hot running OPE, so don't neglect that. And, does this machine have a "high" carb adjustment screw?
Best of luck with the blower.
"There are things you do that put food on the table, and there are things you do that feed your soul." I am blessed to have them be the same things.
#2608655 - 04/24/12 06:28 PM Re: Stihl BG55 bogs at full throttle [Re: nomochevys]
Sluggo0018 Offline
Loc: Long Valley, NJ
I second the vote for the clogged spark arrestor. My Stihl string trimmer was experiencing the same symptoms. After fiddling with the mixture screws I got no improvement. I was ready to replace the carburetor. A trip to the dealer and $25 later, I learned that the spark arrestor was clogged. As a previous poster said, these engines need to be run at full speed or else they will clog. Clean out the arrestor and don't baby it any more. Full speed ahead!
#2608719 - 04/24/12 07:18 PM Re: Stihl BG55 bogs at full throttle [Re: nomochevys]
Happy Birthday 97prizm Offline
Loc: USA
One of the biggest mistakes that happens is using marine stroke oil. I used that and it carboned up my weed trimmer bad. I went to a synthetic 2 strokeoil for small engine/ air cooled engines and what a world of difference.
If at first you don't succeed fail fail again. (Waldorf and Statler.)
1997 Geo Prizm
1984 Mazda RX-7 Spec 7
#2612804 - 04/29/12 10:12 AM Re: Stihl BG55 bogs at full throttle [Re: nomochevys]
Fatboymoe Offline
Loc: Stockton, Ca.
I just had my Stihl SH55 blower apart yesterday for some PM. The spark arrestor screen had very little carbon buildup and the exhaust port was very clean. I bought this blower over 10 years ago and use it weekly.
I used Mobil 1 2T for a long time until I ran out. I now use either Stihl Ultra or Tru-Fuel @ 40-1.
I use Tru-Fuel in all my chainsaws. I know it's expensive, but it's ethanol free and uses a good synthetic oil. It's also 93 octane, which is good for my ported saws with over 185psi compression.
To the OP. Take your muffler off. Check the screen as mentioned and look into the exhaust port. If it's carboned up, remove the carbon. Keep the piston above the exhaust port to prevent that carbon from entering the crankcase. Usually, that's the problem and is easily fixed.
2012 Ford F-150 Lariat, 3.5L Eco-Boost
2003 HD FatBoy
2014 Honda Accord EX-L 2.4
