Ford Australia to cease manufacturing
by supercity
05/22/13 10:06 PM
"hail damage" - home repair salesmen
by tomcat27
05/22/13 09:35 PM
Rotella T6 $16.99/gallon
by Hollow
05/22/13 09:29 PM
96-01 Lexus ES 300 Mobil 0w-40 sludge prevention?
by Art_Vandelay
05/22/13 09:20 PM
Any VOA/UOA of SAE 30w oils?
by Jocephus
05/22/13 09:19 PM
Air conditioners "warm up"?
by Nick R
05/22/13 08:58 PM
Cutting a "male end" on a 2x4
by JHZR2
05/22/13 08:58 PM
Rec 90 Non Ethanol in daily driver?
by Realtech214
05/22/13 08:38 PM
New road bike
by OVERKILL
05/22/13 08:35 PM
Custom vapour barrier - how thick and butyl tape
by wing0
05/22/13 08:19 PM
My 95 Camry Top End Opened (pic)
by BISCUT
05/22/13 08:13 PM
Kingsford Charcoal @ Walmart
by JPP
05/22/13 07:35 PM
yertle, Kincaid66, StuMcRay, cdenison, BobB
45514 Registered Users
133 registered (Art_Vandelay, antzam, 95busa, AlienBug, 99Saturn, abycat, 8 invisible), 1375 Guests and 245 Spiders online.
45514 Members
64 Forums
193800 Topics
Max Online: 2449 @ 05/13/13 01:57 PM
Page 2 of 6 < 1 2 3 4 5 6 >
#2597957 - 04/12/12 06:54 PM Re: Post your latest upgrade [Re: Popinski]
PandaBear Offline
Loc: Silicon Valley
late Dec / early Jan this year:
AMD Phenom II X2 BE
MSI 880G-E45 motherboard
8GB of DDR3 1600
$150 total after rebate.
"You keep asking questions PandaBear and you'll end up a vegetarian like my wife" - Camu Mahubah
#2597993 - 04/12/12 07:32 PM Re: Post your latest upgrade [Re: Popinski]
xxch4osxx Offline
Loc: Cedarbrae, Ontario
New parts for my desktop: Corsair Force3 GT 120GB SSD
8GB Patriot DDR3-1600 RAM
MSI 880GMA-E35 motherboard
AMD FX Bulldozer Black Edition 6core CPU 3.3ghz
Had the upgrade done at the end of March.
Edited by xxch4osxx (04/12/12 07:33 PM)
2004 Chev Silverado 4x4 using all Amsoil lubricants.
2008 Mazda 3 GS Sport Hatchback (Girlfriend's car)
#2598151 - 04/12/12 10:18 PM Re: Post your latest upgrade [Re: Rand]
Colt45ws Offline
Loc: Central Washington
Originally Posted By: Rand
how much did that cost colt45?
More than it shouldve. 5 bills. Oh well, [censored] it. Its a toy anyway.
Pretty stuffed in there.
It goes:
USB 3.0 card in the top slot.
Modified Creative X-Fi Platinium
XFX 6950 2GB w/ 6970 BIOS
Geforce GT 520 w/ passive cooler (the side fan does plenty well and is one less thing to break)
Slot hole taken by eSATA plate; PCI slot blocked by GT 520 cooler anyway.
Highpoint 3510 RAID controller
Right side
#2598246 - 04/13/12 02:10 AM Re: Post your latest upgrade [Re: Popinski]
Colt45ws Offline
[censored] it. I just put that ceiling fan in a few days ago. A Bitfenix Spectre Pro 230mm. Well, I just stuffed a flashlight into it and blew out two blades. Still works though, just vibrates. Bearings dont like it, Im sure. Just have to roll with it until a new one arrives I guess.
-Colton
2004 Ford Crown Vic LX, 66k "Tank"
Pz Ultra 5W20/+1 RTS 5W40, EAO11
Schaeffer #204SAT
Mobil Delvac 75W90
20% cooler in 10 seconds flat.
#2600728 - 04/16/12 03:52 AM Re: Post your latest upgrade [Re: Popinski]
Colt45ws Offline
4Ghz
Turns out 4GHz is all I can get off this particular chip at reasonable voltage levels. At this point I was already at 1.39 vcore. If I put it under water I could probably get 4.2-4.3? This particular example just isnt a very good clocker.
Still, I got 79ish Gflops out of it. I was getting just under 50Gflops out of my 4GHz 920, so it is more than 1.5x the power.
In theory.
I should note, those temps are 'under duress.' I unplugged the side fan and the puller fan on the cpu cooler (top fan); then I laid a cd case on top of it. So it just had the pusher and the rear fan.
Did pretty well for nearly 180W. I noticed the rear fan actually started pulling hot air out after I did this, so it seems to be able to help take up slack in a failure.
Another interesting thing I noticed was, while I was playing around with unplugging a cpu fan I ran just the puller and had the pusher unplugged. This actually ran cooler by 2-3C vs just the pusher. I didnt have the CD case blocking it at this point though. This requires further testing. I had been running with the assumption that pushing air through a cooler would run cooler vs pulling air through it.
Anyway, with it setup the way it normally runs, max temperatures under this stress is in the 70-75C range.
Edited by Colt45ws (04/16/12 03:52 AM)
-Colton
Schaeffer #204SAT
Mobil Delvac 75W90
#2600785 - 04/16/12 07:51 AM Re: Post your latest upgrade [Re: Popinski]
rg200amp Offline
Loc: Phila,PA
Well, the latest upgrade was the new router.
But besides that, my most recent upgrade was to my iMac.
I added two 4gb RAM cards from OtherWorldComputing.com to it, in addition to the stock two 2gb cards. Giving me a total of 12gb of RAM.
Fast does not even begin to explain how this thing rocks. Photo editing in lightroom and video editing is insanely quick.
However, me being like I am, I plan on upgrading the stock cards to two 4gb cards giving me a total of 16gb of RAM.
Once the next gen iMacs come out, I'm going to pick up the i7 ivy bridge. Then I'll up that unit to 32gb of RAM.
// 2013 Subaru WRX //
SOLD:
-11 Volkswagen Jetta
-04 Lincoln LS
-01 Ford F250
-04 Mazda Rx-8
-97 Jeep Wrangler
-97 BMW M3
-97 Nissan Maxima
#2601057 - 04/16/12 02:38 PM Re: Post your latest upgrade [Re: Colt45ws]
Rand Online   content
Loc: NE. Ohio
that seems low.. what program are you using?
I was getting 115GFlop with IBT
your setup should be higher.
edit: just got 107GFlop with about 10 things going on in the background. That I didnt shutdown.
I used the default settings for IBT
Edited by Rand (04/16/12 02:41 PM)
2011 Subaru Forester X Prem. 5MT
#2601122 - 04/16/12 03:53 PM Re: Post your latest upgrade [Re: Popinski]
Colt45ws Offline
IBT.
Gulftown has a lower IPC than SB. Its scaled pefectly with my old Bloomfield. 1.5x the cores and 1.6x the performance.
-Colton
Schaeffer #204SAT
Mobil Delvac 75W90
#2601295 - 04/16/12 08:16 PM Re: Post your latest upgrade [Re: Popinski]
Nick R Online   content
Loc: Saratoga, NY
Pictures of my latest upgrades
Case: Fractal Design Define R3
CPU: Intel Core i5-2500k @ 4.3Ghz (1.275v core under IBT)
Motherboard: ASUS P8Z68-V Pro/Gen3
Ram: 8GB (2x4) Corsair XMS3 DDR3-1333
GPU: 2x XFX Radeon 5770 1GB OC in Crossfire
Storage: 1x Crucial m4 64GB SSD, 1x WD 640GB Blue, 1x WD 1TB Green (recertified w/WDIDLE3 disabled)
PSU: XFX Pro Modular 650W
ODD: 1x Samsung BD-ROM/DVD+RW, 1x LG DVD+RW
Cooling: Corsair H50 w/2x Corsair 120mm fans w/1 bottom intake (120), 1 side intake (120), 2x front intake (120), and one top exhaust (140). All intake fans have filters on them, and are low speed so it's completely silent except when the GPUs are under load.
Intel Burn Test. Don't mind the temps, those are really high for this test for me, only because we don't have the A/C running and ambient temp is already 80f or so. Sandy Bridge ftw
link to fullsize
http://img84.imageshack.us/img84/8256/ibtk.png
And the most recent run of crystaldiskmark from a month or two ago.
Edited by Nick R (04/16/12 08:18 PM)
13 Ford Focus SE 2.0L/6000miles/PP 0W-20/FL-910S
13 Chevy Traverse 3.6L/1500mi/FF
85 Honda Shadow VT500C/33k mi /Castrol powerRS 5W-40
#2601306 - 04/16/12 08:23 PM Re: Post your latest upgrade [Re: Popinski]
Loc: Saratoga, NY
My network file server.
Case: Antec 300
CPU: AMD Phenom II X4 965BE undervolted idle 800Mhz at 0.850v
RAM: 4GB (2x2) Crucial DDR3-1333
Motherboard: ASUS M4A88TD-V Evo/USB3
Storage: 1x 320GB Hitachi Deskstar (boot, application), 1x Samsung Ecogreen 500GB (Music, Pictures), 1x WD 2TB Green (w/WDIDLE Disable)
PSU: Antec Neo Eco 400C (80PLUS)
Cooling: Stock AMD Phenom II CPU cooler (lapped), 2x Intake 120mm fans, 1x 120mm rear exhaust and 1x 120mm intake side
GPU: Integrated 880G
#2601308 - 04/16/12 08:26 PM Re: Post your latest upgrade [Re: Popinski]
Loc: Saratoga, NY
And my Lenovo Z565-4311 Laptop
CPU: AMD Phenom II N660 (Dual Core, 3Ghz)
RAM: 6B (4+2) Crucial DDR3-1333
HDD: WD 320GB Scorpio Blue
Wireless: Intel Centrino Advanced-N 6230
#2609176 - 04/25/12 08:50 AM Re: Post your latest upgrade [Re: Popinski]
Virtuoso Online   content
Loc: Cow town, NE
Just ordered:
Intel Core i3-2100 Sandy Bridge 3.1Ghz
GigaByte GA-Z77-DS3H and
G.SKILL Ripjaws X 8GB DDR3 1600 kit
This is replacing an Athlon 64 3700 on a ASUS A8N5X with 2gb of DDR 400. Should be a good upgrade! I'd post pics but it's nothing most of you haven't seen before.
Next up? SSD's. It was *really* hard not to order them with this stuff, but I'm trying to wait for a hard drive failure. These Western Digital's just won't die!
#2610091 - 04/26/12 05:03 AM Re: Post your latest upgrade [Re: Popinski]
lyle Offline
Loc: Minneapolis MN
I replaced the HD's in my laptop and my "play" home system with SSD's. These made an astonishing jump in performance, especially on the laptop (C2Duo), less so on the home i5 box.
Also installed 32GB of RAM on the home box. The 'egg had a sale on DDR3 awhile ago, 2 x 8GB sticks for $89, so I bought a bunch and only just now installed them. It's just insane...
#2639585 - 05/29/12 06:57 PM Re: Post your latest upgrade [Re: Popinski]
Loc: Saratoga, NY
Today, May 29th 2012
I'll let the pictures speak for themselves.
smile
upgrading FROM:
Netgear WNDR3700v2 w/dd-wrt
2x XFX Radeon 5770 (1GB) in crossfire
Corsair H50 watercooling kit
Full system specs for refresher
Intel Core i5-2500k OC 4.3Ghz
ASUS P8Z68-V Pro/Gen3 Motherboard
XFX Double Dissipation Radeon HD 7850 OC
Crucial m4 64GB SSD Boot
WD 1TB Green (Storage), WD 640GB blue (Games)
XFX 650W Pro Modular 80PLUS Bronze PSU
Fractal Design Define R3 case
So far, so good. Got everything set up and hooked up and it works perfectly. I especially like the newfound 5Ghz range with the new N66U. laugh
Also, I have to post this just because lol
fullsize
http://img220.imageshack.us/img220/4047/lolbench.png
Note that the 7850 is overclocked to 1050Mhz core (860 Stock) and 5.4Ghz Memory clock. Better than 7870 and 6970 for $250, can't really be beat.
Picture of the bottom of the card, borrowed frmo overclockersclub
You can actually check out the full review of this card here
http://www.overclockersclub.com/reviews/xfx_hd_7870_7850_dd/
Edited by Nick R (05/29/12 07:04 PM)
#2837091 - 12/16/12 04:36 PM Re: Post your latest upgrade [Re: Popinski]
Eric Smith Online   happy
Loc: Kansas City, KS
Going to revive a old thread!
No PC upgrades yet just the network..
In TL-WDR4300 (Don't pay attention to the house long-term project!)
Replaced a old Linksys WRT45G. Nothing wrong it didn't support "N" or have a gig network connection. The difference is more than I would of thought. Also added a TrendNet 8 port gigabit switch about a month ago. Really helped the WD NAS 2TB that only averaged 5-6 over a standard 100Mb connection. Now it's 10 average on our clients with 100Mb connections.. no gig cards yet. Now thinking about computer upgrades.. our newest which is laptop was purchased in 2009.
04 Escape 125k (PP 5w20)
02 Focus 109k (PP 5w20)..annoying little sister
91 Festiva 154k (Mobil HM 10w30)
