New Supertech jugs?
by dlundblad
06/26/16 06:16 AM
Fram ph3657 cut open
by jhellwig
06/26/16 05:07 AM
Don't discount coal for a long while yet...
by Shannow
06/26/16 03:10 AM
Decent Wireless Computer Headset?
by 99Saturn
06/25/16 11:41 PM
Need Fuel Pump Assembly for Camry
by Nick1994
06/25/16 11:36 PM
2015 Accord V6 VCM engine UOA 36,680 mi / 9812 OCI
by TNM1982
06/25/16 10:55 PM
Why did Toyota recommend a winter and summer oil?
by BrianApp
06/25/16 10:00 PM
Fram TG 7317 6k miles
by bbhero
06/25/16 09:57 PM
Sta-Lube Moly-Graph Grease
by JHZR2
06/25/16 09:20 PM
Dead battery locks me out of Altima!
by Tom NJ
06/25/16 08:56 PM
Second lawn mower blade
by greasegunn
06/25/16 08:11 PM
Echo weed trimmer - carb issue?
by ryan2022
06/25/16 07:13 PM
paul2005tb, Martyaus, carmelo, Shellman, SSO
58272 Registered Users
50 registered (BobFout, bbhero, alcyon, b1amgm47, car51, BigRalphie, 2 invisible), 967 Guests and 15 Spiders online.
58272 Members
66 Forums
250821 Topics
#2600776 - 04/16/12 07:34 AM RX For 95 Camry Stock Headlights
BISCUT Offline
Loc: NewYorkistan
95 Camry headlights have seen better days. Housing is yellowins and the beam isn't all that great.
Go with stock replacement housing? Or recommend a good qualty aftermarket?
Open to suggestions!
2015 F150 Lariat M1 0-20 FRAM ULTRA (12k)
2007 Maxima M1 5-30 FRAM ULTRA (113k)
#2600784 - 04/16/12 07:51 AM Re: RX For 95 Camry Stock Headlights [Re: BISCUT]
LargeCarManX2 Offline
Loc: Up here in the NorthWest
Go to NAPA and get the micropolish for plastic headlight lenses. You will save $$$$
"Success is the ability to go from one failure to another with no loss of enthusiasm."
Sir Winston Churchill
#2600786 - 04/16/12 07:55 AM Re: RX For 95 Camry Stock Headlights [Re: BISCUT]
Coprolite Offline
Loc: TX
There are any number of good polishing headlight restorers out there. If the lights aren't bright enough once the haze is gone, look into replacement bulbs.
If you want HID, I'm sure that there are some ballast and bulb kits out there for your model.
#2600839 - 04/16/12 09:16 AM Re: RX For 95 Camry Stock Headlights [Re: LargeCarManX2]
BISCUT Offline
Loc: NewYorkistan
The polish actually works? I've thought it a gimiick.
#2600841 - 04/16/12 09:18 AM Re: RX For 95 Camry Stock Headlights [Re: BISCUT]
Smokescreen Offline
Loc: Alberta, Canada
OEM stock replacement housing.
If you go HID kit route, know that its illegal and destroys the beam pattern rendering the lamp into a source of really bright light vomiting in front of your car uncontrolled.
Here is a site that is correct and helpful you should find instructions and even successes on the best kit to restore if you go that route: http://www.candlepowerforums.com/vb/forumdisplay.php?87-Automotive
09 Corolla 1.8L-300Kkms(187Kmi)-PP,Denso
05 LeSabre 3.8L-235Kkms(146Kmi)-F1,Delco
03 Sierra 6.0L-194Kkms(121Kmi)-F1,Delco
All with mpg > EPA
#2600845 - 04/16/12 09:26 AM Re: RX For 95 Camry Stock Headlights [Re: BISCUT]
typ901 Offline
Loc: N. 'Burbs of Chicago, IL
The Polish system does work. Not as good as new, but very close. I used it on our '98 5-Series and it worked out very well. Eliminated the haze and they polished up near new.
#2601027 - 04/16/12 02:03 PM Re: RX For 95 Camry Stock Headlights [Re: BISCUT]
HTSS_TR Offline
Loc: Lake Forest, CA
I used 3M headlight restore and it works very well on 2000 E430, and 1991 Mercury Tracer. It doesn't restore to new but fairly close, about 80-90%.
'00 MB E430
'04 Honda S2000
'06 Volvo V70
'14 Honda Accord LX
"Throwing food away is like stealing it from the poor and hungry" Pope Francis
#2601260 - 04/16/12 07:33 PM Re: RX For 95 Camry Stock Headlights [Re: BISCUT]
Yes it works great. I purchased 6 pre-microglazed discs and a drill adapter (as a kit) and was amazed how well it worked.
#2601367 - 04/16/12 09:22 PM Re: RX For 95 Camry Stock Headlights [Re: BISCUT]
mikered30 Offline
Loc: PA
I would try the aggressive polish kit. Follow up with a good sealant as the UV coating is shot and will start to yellow in a few months if left unprotected. Might consider upgrading to HIR bulbs for highs and lows. I don't think anyone makes a good high quality aftermarket housing. Most of them are made in China had have poor optics.
#2601414 - 04/16/12 10:00 PM Re: RX For 95 Camry Stock Headlights [Re: BISCUT]
HTSS_TR Offline
1995 Camry value is probably around $1,000-1,500 I would not spend upward $100 or more for 4 HIR light bulbs, while he can get a pair Phillip Vision Plus 9006 for $16 from Amazon, after polishing the head light cover with 3M Headlight Restoration kit for $13.65 (with subscribe&save), and get $5 rebate from 3M.
'00 MB E430
'04 Honda S2000
'06 Volvo V70
'14 Honda Accord LX
#2601431 - 04/16/12 10:13 PM Re: RX For 95 Camry Stock Headlights [Re: HTSS_TR]
Klutch9 Offline
Loc: Rochester, MI, US, World
Meguire's ScratchX works wonders on plastic headlight lenses. I'm guessing the PlastX does too, although I've never used it.
'11 Fusion 2.5L - 61k miles - Napa 0w20, Fram TG filter
'08 Sedona LWB 3.8L - 96k miles - Napa 0w20, K&N PS filter
#2601543 - 04/17/12 02:39 AM Re: RX For 95 Camry Stock Headlights [Re: LargeCarManX2]
ankaka Offline
Loc: uk
car lighting car lighting
Orange Contender Elite 50-60# GTX 31" draw
digital hd video camera
#2601559 - 04/17/12 05:31 AM Re: RX For 95 Camry Stock Headlights [Re: HTSS_TR]
mikered30 Offline
Loc: PA
Camry only has 64K miles on it, should easily fetch $3,500. Philips HIR 9012 go for $22 per bulb and Philips HIR 9011 go for $19 each on amazon and have way better output than any other bulb that can be put into the socket. 3M kit works really well.
It would be cheaper to polish and put in HIR bulbs than buy Chinese made headlights and keep the stock bulbs and the HIR setup probably would have better output too.
#2601728 - 04/17/12 10:23 AM Re: RX For 95 Camry Stock Headlights [Re: mikered30]
BISCUT Offline
Loc: NewYorkistan
Camry is old, but in great shape. Garaged all it's life (until me). 69k on it now! With my driving needs, and $4.15 gallon gas this Camry is saving me $160-200 a month over my F-150 gas costs. Loving that!
Some great ideas guys, thanks. Glad to know the lenses can be saved.
