Brake Pad Shims a MUST?
by SavagePatch
08/28/16 01:34 AM
Bean Counters vs Swedish Engineering
by Y_K
08/28/16 12:04 AM
Interesting website for comparing guns
by 901Memphis
08/27/16 11:45 PM
Android clear cached data
by expat
08/27/16 11:07 PM
Worm gear vs spring type hose clamps?
by TheLoneRanger
08/27/16 10:35 PM
Factory fog lights...common wiring and wattage?
by ryan2022
08/27/16 10:32 PM
2 Hyundai/Kia OEM Filters cut open
by KD0AXS
08/27/16 10:30 PM
Preferred SUV for snow: Large FWD or smaller AWD?
by Carbon12
08/27/16 09:55 PM
Chevron 5W-20 $10/5-quart at WM
by wgtoys
08/27/16 09:15 PM
Best alternative to FL500S
by buck91
08/27/16 09:11 PM
New router?
by Quattro Pete
08/27/16 08:44 PM
MPV 7100 Hybrid Mower
by spk2000
08/27/16 08:17 PM
DALpilotMike, Safetyfirst, rwood, USARMOR, GV00
58943 Registered Users
20 registered (Bandito440, dec219644, berniedd, dccode, 3 invisible), 692 Guests and 34 Spiders online.
58943 Members
66 Forums
253657 Topics
Page 1 of 2 1 2 >
#2597409 - 04/12/12 08:06 AM k&n oil filters
hemitruck Offline
Loc: new jersey
time to change the oil again in my 2011 hemi p/u. used wix filters and m1 for years in past vehicles. since this truck was new i have been using penzoil ultra and kn filters. doing 7000 oci, long for me. i am paranoid about using new products, any reason to change brand of filter?
#2597415 - 04/12/12 08:14 AM Re: k&n oil filters [Re: hemitruck]
chubbs1 Offline
Loc: Merritt Island FL, USA
They don't appear to have changed much if any. I would use without hesitation for your planned 7k OCI.
'12 Charger SXT
QSUD 5w30 OEM filter
'12 Charger SXT
Edge FST EP 5w30 OEM (Mine;)
'11 Hyundai Sonata GLS
QSUD 5w20 OEM Filter
#2597473 - 04/12/12 09:25 AM Re: k&n oil filters [Re: chubbs1]
barlowc Offline
Loc: Southeast Michigan
Can't go wrong with K&N, WIX, or M1. The only downside is the relatively high cost of K&N and M1.
2013 BMW 335i xDrive Sport Line (36K Miles)
#2597485 - 04/12/12 09:31 AM Re: k&n oil filters [Re: hemitruck]
Bandito440 Online   content
Loc: NYS
I use a K&N in my motorcycle with good results. The nut welded to the end makes changes easy, as the filter is enclosed in a housing and can't be easily removed otherwise.
That being said, I use Purolator PureOnes on my other vehicles. K&N is good too, but perhaps a bit overpriced.
'14 Grand Cherokee EcoDiesel
Pennzoil Euro L & OEM filter
#2597492 - 04/12/12 09:43 AM Re: k&n oil filters [Re: hemitruck]
earlyre Offline
Loc: Lima, Ohio, USA
Dunno if this will help your decision or not, but i posted a UOA 10 days ago, using PYB, & a K&N oil filter. nearly 7k hard city miles.
http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=2587486#Post2587486
Edited by earlyre (04/12/12 09:44 AM)
Edit Reason: wrong mile figure
Mine:
09 Mercury Sable : 6qts QSAD 5w20,WIX 51516
Mine to Maintain:
03 Pontiac Vibe : 4.5qts QSAD 5w30,WIX 51394
#2597497 - 04/12/12 09:50 AM Re: k&n oil filters [Re: earlyre]
barlowc Offline
If I'm not mistaken, Insolubles % is a partial indicator of oil filtering performance. While 0.4 is good, I've gotten the same or lower using less expensive DENSO or PureONE filters. There are a lot of variables in the overall equation; I'm just not sure the UOA really contains anything to really indicate how good of a job the K&N oil filter did.
#2597581 - 04/12/12 11:14 AM Re: k&n oil filters [Re: hemitruck]
Jim Allen Offline
Loc: NW Ohio
K&N filters are a high quality unit but cannot be considered a high efficiency filter based on the beta ratio info I have seen on several part numbers. Their filtering efficiency is between the average filters and the high efficiency ones. Better than average,but only just. If you read their advertising info, they emphasize flow, so if you want a well constructed filter that will not go into bypass (on cold starts or high rpms) and have a long OCI capability, it's a good choice.
Of the brands you mentioned, the M-1 is a more efficient filter, on average, than a K&N or a Wix. Remember filtering efficiency sometimes changes between part numbers within a brand. Wix is usually only slightly above OEM efficiency but well constructed. If you want efficiency, go with the M-1.
You don't get a huge indication from a UOA on filtering efficiency unless you have a bypass system installed. The spectrographic analyzer only "sees" particles under five microns and that's below the filtering threshold of most filters. They may catch some in that range, perhaps enough to effect the number, but usually only slightly. In order to evaluate filter performance, you need to do before and after particle counts, I.E. run 5K miles on filter A, do a particle count, then run 5K on the better filter B with fresh oil and compare the results.
"Insolubles," as Blackstone lists, includes everything, including carbon, oxidation byproducts, large chunks of metal, additive fallout and anything else. I don't think it's an accurate enough tool to make any usefully graduated evaluations on filter efficiency. It can say "OK" or "Not OK" but I don't think it can tell the difference between two filters that aren't just light years apart in efficiency.
Edited by Jim Allen (04/12/12 11:15 AM)
Jim Allen
Keepin' the Good Old Days of Four Wheeling Alive
#2597594 - 04/12/12 11:21 AM Re: k&n oil filters [Re: hemitruck]
hemitruck Offline
Loc: new jersey
thanks all,
jim allen, thought the m1 filter and kn filter were the same, chose kn because of the nut. am i mistaken that they are the same? tks.
#2597692 - 04/12/12 01:15 PM Re: k&n oil filters [Re: hemitruck]
Jim Allen Offline
Loc: NW Ohio
Same manufacturer (Champ Labs) but different filter media?? Sufddenly I can't find my M-1 spec to verify. I was working from memory, so if I misspoke, I apologize. Maybe someone has some M-1 specs to post.
Here are the two K&N Specs I have at hand. Different apps and different specs so I think you need to find your part numbers for both brands and e-mail K&N and Mobil to get the specs.
K&N HP-1004 (per ISO 16889):
100% at 40 microns
100% at 35 microns
100% at 30 microns
99.4% at 25 microns
98.9% at 20 microns
97.1% at 15 microns
92.3% at 10 microns
82.5% at 5 microns
HP-6001 (Ford Powerstroke Filter):
10 um- 53.1 %
20 um- 95.4 %
30 um- 99.9 %
Capacity- 55.4 grams
Hydrostatic Burst- 558 psi
Element Collapse- 175 psid
Flow Rate- 20 GPM (J-806)
Betas- 10/20/30=2.1/21.7/1000
Jim Allen
#2597738 - 04/12/12 02:14 PM Re: k&n oil filters [Re: hemitruck]
ltslimjim Offline
Loc: WatUpDoc
@Jim, at most to the naked eye they seem nearly identical filters between K&N and the M1. I've never gotten a real confirmation that their media is 'exact' other than by appearance only.
I'd imagine looking at the same filters and comparing bypass relief settings might give a clue, other than that what to do without efficiency numbers? shrug
Heard some really weird suggestions that a K&N was causing VTEC problems on some Hondas from a shop last summer. ???
http://bobistheoilguy.com/forums/ubbthre...698#Post2300698
PS: Not that I believe this. I think these guys were racing Hondas with K&N filters and had at least a 40 SAE grade oil(like a 10w-40 etc)
92 Civic Hatch (stolen frown RIP)
07 Honda Fit Sport (A/T) WELCOME thumbsup
#2597762 - 04/12/12 02:49 PM Re: k&n oil filters [Re: ltslimjim]
barlowc Offline
Our Saturn VUE has the Honda-manufactured 3.5-liter V6 that GM called the L66. (Honda called it the J35A3.) I'm 99% sure it has VTEC and I've used K&N oil filters (i.e. HP-1010) without any issues (i.e. at least none that I noticed).
#2597813 - 04/12/12 03:58 PM Re: k&n oil filters [Re: Jim Allen]
hemitruck Offline
Loc: new jersey
100% at 40 microns
100% at 35 microns
100% at 30 microns
99.4% at 25 microns
98.9% at 20 microns
97.1% at 15 microns
92.3% at 10 microns
82.5% at 5 microns
10 um- 53.1 %
20 um- 95.4 %
30 um- 99.9 %
thanks jim.
#2597872 - 04/12/12 05:18 PM Re: k&n oil filters [Re: hemitruck]
Ken2 Offline
Loc: Washington St.
By the way, K&N motorcycle oil filters are made by HiFloFiltro in Thailand. The only visible difference with a HiFlo brand filter is the color of the media, the box, and the nut on the end...and the price.
Every gun that is made, every warship launched..a theft from those who hunger and are not fed, those who are cold and not clothed.
Gen. Eisenhower
#2597939 - 04/12/12 06:34 PM Re: k&n oil filters [Re: Ken2]
fxrider Offline
Loc: Wyoming
anything else sick
#2601090 - 04/16/12 03:14 PM Re: k&n oil filters [Re: hemitruck]
hemitruck Offline
Loc: new jersey
i still like the nut on the end of the filter so i used another k&n. thanks all
Page 1 of 2 1 2 >
