Another G-Oil UOA where wear #s look great but viscosity appears to have sheared down to 20wt territory:
Code:
Miles on car 120,000 118,500 116,400
Miles on oil 1500 50 5000
Oil in use G-Oil G-Oil Mobil1 0-40
aluminum 2 1 3
chromium 0 0 0
iron 3 1 9
COPPER 4 2 15
LEAD 0 0 0
TIN 0 0 0
MOLYBDENUM 62 61 71
NICKEL 1 0 0
POTASSIUM 3 0 3
BORON 126 155 114
SILICON 29 10 9
SODIUM 0 0 10
CALCIUM 1823 1729 2911
MAGNESIUM 158 116 27
PHOSPHORUS 718 644 1136
ZINC 741 759 1141
SUS@210°F 55.3 57.8 no test
cST@100°C 8.86 9.6 12.62
Flashpoint°F 360 415 no test
Fuel% TR
Antifreeze% 0 0 0
Water% 0 0
Insolubles% 0.3 0.2 (ox 25, nit 10.4)
TBN 5.6 no test no test
I ran these tests to verify that it is up to the task. If G-Oil can handle a 1.8T it should perform well in practically everything. I'm mixed about these results, great wear protection, questionable service life with shearing being the main concern. I will most likely test again in 1500 miles and if wear continues to be low and visc remains above 8.0 or so I will probably keep using it.
Code:
aluminum 2 1 3
chromium 0 0 0
iron 3 1 9
COPPER 4 2 15
LEAD 0 0 0
TIN 0 0 0
MOLYBDENUM 62 61 71
NICKEL 1 0 0
POTASSIUM 3 0 3
BORON 126 155 114
SILICON 29 10 9
SODIUM 0 0 10
ZINC 741 759 1141
Fuel% TR
Antifreeze% 0 0 0
Water% 0 0
