Changed tie rods. Now there are issues.
by weebl
1 minute 43 seconds ago
Castrol Magnatec 10W40 & Edge 10W30 Sale at Repco
by SR5
28 minutes 51 seconds ago
Bosch water injection boosts MPG and cut emissions
by HTSS_TR
Yesterday at 11:09 PM
Nissan tiida/ vesa coolant?
by Nissan101
Yesterday at 10:42 PM
my Buick 03 lesabre has a flashing radio light?
by snake123
Yesterday at 10:25 PM
5000 miles in the Caprice
by ls1mike
Yesterday at 10:01 PM
Copper Reactivity and BMW Blue Coolant
by TXCarGeek
Yesterday at 09:24 PM
lubegard biotech xle
by mobilaltima
Yesterday at 09:05 PM
Schaeffer 5w-40 in Jeep 4.0
by JeepWJ19
Yesterday at 08:53 PM
PP and PU 45% off this wk at CT !!!
by ST2008
Yesterday at 08:49 PM
Photographic evidence of HDEO / synth oil cleaning
by OldEuroCarLover
Yesterday at 08:35 PM
Limited Slip Additive needed for G80?
by Nick1994
Yesterday at 08:28 PM
JoeI, binarycache, MarkieB, albertson, Chevy538487
58973 Registered Users
30 registered (4WD, akela, carlprop, daves87rs, CKN, david_ES2, 4 invisible), 946 Guests and 5 Spiders online.
58973 Members
66 Forums
253841 Topics
#2588282 - 04/03/12 01:18 PM Oil for engines running LPG, CNG, or Propane
Loobed Offline
Loc: Northern California, USA
I noticed on the Valvoline website that they have an engine oil specifically for Compressed Natural Gas, Liquid Petroleum Gas, and Propane. There is nothing special in their PDS http://www.valvoline.com/pdf/premium_blue_geo.pdf What makes this oil different (besides marketing)?
http://www.valvoline.com/products/commercial-industrial-products/oem-endorsed-products/71
Engine: 2001 GM 5.3L LM7
Current Fill: Valvoline Synpower 5w-30 w/Pure-One PL25288 filter
I.M.N Oil Enthusiast
#2588341 - 04/03/12 01:58 PM Re: Oil for engines running LPG, CNG, or Propane [Re: Loobed]
carwreck Offline
Loc: CT
Valvoline’s Premium Blue® GEO meets the "Natural Gas Engine Oil – CES 20074 Cummins Specification"
http://www.cumminswestport.com/pdf/technical_bulletins/2009-05_Natural_Gas_Engine_Oil.pdf
"Do not use diesel engine oil in a natural gas engine. If diesel engine oil is used, valve torching, piston scuffing, and reduction in spark plug life will occur."
#2588360 - 04/03/12 02:13 PM Re: Oil for engines running LPG, CNG, or Propane [Re: Loobed]
Rob_Roy Offline
Loc: Northern, NY
Take a look at the ash content.
2015 Subaru Legacy 3.6
2014 Subaru Outback 2.5
1999 Ford F350, V10 workhorse
#2588376 - 04/03/12 02:23 PM Re: Oil for engines running LPG, CNG, or Propane [Re: Rob_Roy]
Loobed Offline
Propane produces a lot of water. Would the reduction in sulfated ash reduce the formation of acids?
#2588438 - 04/03/12 03:19 PM Re: Oil for engines running LPG, CNG, or Propane [Re: Loobed]
mechtech2 Offline
Loc: Chicago Area
Burning gasoline in an engine produces a lot of water.
#2589007 - 04/03/12 10:02 PM Re: Oil for engines running LPG, CNG, or Propane [Re: Loobed]
Garak Offline
Loc: Regina, Saskatchewan, Canada
Some of the oils marketed towards LPG and so forth have lower TBN, too. These fuels eliminate the problem of fuel dilution, among other things.
Plain, simple Garak.
2008 Infiniti G37 coupe - Mobil Delvac 1 ESP 5w-40, Wix 51358
1984 F-150 4.9L six - Quaker State GB 10w-30, Wix 51515
#2589020 - 04/03/12 10:12 PM Re: Oil for engines running LPG, CNG, or Propane [Re: Loobed]
3311 Offline
Loc: Fl
IIRC those engines combustion burn hotter and require different ash levels?
04 2500hd 6.0 278k/1k Pen HM 5w30 10w40 mix XG3675 VML ATF Dex
03 C7500 Dmax7.8l 134k ST 15w40,M1ATF Dex
06 2500hd 6.0 220k ? 5w30 ST DexVI PGL
#2589031 - 04/03/12 10:25 PM Re: Oil for engines running LPG, CNG, or Propane [Re: Loobed]
Garak Offline
That might be part of the issue, too, 3311. However, when running a propane taxi fleet, I never bothered with any CNG/LPG/Propane oils. It was simple Quaker State conventional 10w-30 at 6,000 mile OCIs.
The biggest issue on propane at the time was the same as the introduction of unleaded gas. Hardened valves of the time weren't as "hard" as they should be, and in the early years, didn't stand up as well as they should have, whether on unleaded or on propane. Heat might have been a bit of an issue, but there certainly was no problem with carbon deposits.
#2589037 - 04/03/12 10:31 PM Re: Oil for engines running LPG, CNG, or Propane [Re: Loobed]
3311 Offline
Loc: Fl
I think Dino FS is suitable for propane as well.
#2589206 - 04/04/12 07:12 AM Re: Oil for engines running LPG, CNG, or Propane [Re: Loobed]
A_Harman Offline
Loc: Michigan
Gas engine oils are formulated for low or no ash. Ash deposits in the combustion chambers form over time and lead to detonation or preignition in high-BMEP gas engines. Since most gaseous fuels have no sulfur, high TBN is not needed, so the oils can be formulated to produce no or very little ash. The main problem with converting gasoline engines to run on propane or natural gas is intake valve seat wear due to "dry" conditions in the intake system. Hard valve seats are required; materials such as Stellite or Triballoy are popular in such applications.
Edited by A_Harman (04/04/12 07:12 AM)
1985 Z51 Corvette track car
2002 Camaro Z28 LS1/6-speed
2001 Dodge Ram 2500 diesel
1972 GMC 1500 shortbed project truck
#2589952 - 04/04/12 07:02 PM Re: Oil for engines running LPG, CNG, or Propane [Re: Loobed]
Garak Offline
Also, the mention about not using diesel oil in an LPG/CNG engine is a bit odd, and certainly has no context. I would certainly advise against using a diesel only engine oil in a sparker. Do they mean not to use the latest diesel specs? When was the quote written?
Back in the day, most PCMOs had a diesel specification as well, and were used without issues in propane engines.
