'91 Mazda B2600i transfer case and trans oil?
by Jason280
46 minutes 9 seconds ago
How to cut power to breaker box ?
by Merkava_4
Today at 02:21 AM
Spark plugs in hi-per applications
by mjoekingz28
Today at 01:07 AM
OK, before I lube it ...
by BrocLuno
Today at 12:53 AM
Toyota Japan Fluid SDS
by SXE10
Yesterday at 11:28 PM
Online Oil Viscosity Selectors
by Merkava_4
Yesterday at 11:25 PM
Considering a differential swap
by buck91
Yesterday at 10:18 PM
HVAC Evaporator Cleaning Results
by sleddriver
Yesterday at 09:51 PM
Car Acronyms
by Marco620
Yesterday at 09:46 PM
Vibration with new tires - your thoughts
by Bandito440
Yesterday at 09:41 PM
Carpet cleaning methods.
by Run
Yesterday at 09:26 PM
Fram XG16 4522mi 5.7 Hemi
by AntsinmyEyes
peg, CornbreadMan, JoelB, alostaunau, alanwayne1908
58295 Registered Users
31 registered (Char Baby, Atesz792, b1amgm47, 1foxracing, crainholio, 4 invisible), 732 Guests and 13 Spiders online.
58295 Members
66 Forums
250918 Topics
#2584524 - 03/30/12 11:42 PM Bosch Premium vs Denso first time fit
1604169 Offline
Loc: Alberta, Canada
I recently purchased a Denso first time fit instead of my typical Bosch Premium and wanted to know which filter is better for my application. Both have metal end caps, silicone ADBVs and 8 holes in their base plates.
Denso First Time Fit (150-1006)
Cost: $6.59
98% efficiency > 40 microns
Taller & stiffer canister than Bosch.
Linear steel tube
Bosch Premium with Filtech (3312)
Cost: $4.44
99.9% efficiency > 20 microns
Spiral-wound center tube
These are used on my 96 Civic and 02 Acura MDX with Mobil 1 5W-30. OCIs are 10,000 km (6,500 miles) in cold winters and moderate summers. My wife and I drive are pretty tame drivers.
#2584558 - 03/31/12 01:24 AM Re: Bosch Premium vs Denso first time fit [Re: 1604169]
Garak Offline
Loc: Regina, Saskatchewan, Canada
I'd suggest they would both do the job admirably. Both are rather highly regarded here. Go with what's cheapest and/or most easily available.
Speaking of which, where in Canada did you stumble across Denso aftermarket filters?
Plain, simple Garak.
2008 Infiniti G37 coupe - Mobil Delvac 1 ESP 5w-40, Wix 51358
1984 F-150 4.9L six - Quaker State GB 10w-30, Wix 51515
#2584561 - 03/31/12 01:37 AM Re: Bosch Premium vs Denso first time fit [Re: Garak]
1604169 Offline
I get them both from autopartsway.ca
Very happy with their service over the past 3 years.
#2584570 - 03/31/12 02:19 AM Re: Bosch Premium vs Denso first time fit [Re: 1604169]
ZeeOSix Offline
Loc: PNW
Cost: $6.59
Cost: $4.44
No brainer ... the better filtering performance filter is also the cheaper one.
A filter's brand name doesn't matter ... what's inside does.
#2584622 - 03/31/12 05:40 AM Re: Bosch Premium vs Denso first time fit [Re: 1604169]
Garak Offline
Okay, that explains it. I get my Bosch Premiums from there. They don't stock the Densos for my G, just the Bosch ones. They did stock a lot of Mann, German Bosch, and Mahle for the old Audi. All of them are at a pretty good price.
I've ordered a boatload of stuff from there, too. They kept the Audi running long into old age.
#2584639 - 03/31/12 06:06 AM Re: Bosch Premium vs Denso first time fit [Re: 1604169]
Sayjac Offline
Loc: The Old North State
+1 for the BP 3312, PL14459 equivalent. $4.44 is a low price for BP, more than $2 less and better rated efficiency. Also, I believe the BP efficiency is 99.9@ 20um. A minor point perhaps, but with many of the filter's going to the > __um, it does leave some opening to interpretation of spec, imo.
As for can thickness/stiffness, I've never had that be an issue. Unless you regularly go off road, and the filter is located at very bottom of engine, not an issue imo. Based on your stated driving profile, not a factor.
#2584672 - 03/31/12 06:59 AM Re: Bosch Premium vs Denso first time fit [Re: Sayjac]
barlowc Offline
Loc: Southeast Michigan
You can see a DENSO FTF that I cut open here. And you can see a Bosch Premium that I cut open here. Both are very good filters. But like ZeeOSix said, the Bosch Premium is cheaper AND has better filtering specs, so I would probably pick it. With that said, the difference in filtering specs isn't really going to make a practical difference. Both will perform just fine for 10K kilometer intervals.
2013 BMW 335i xDrive Sport Line (34K Miles)
#2584722 - 03/31/12 08:27 AM Re: Bosch Premium vs Denso first time fit [Re: Sayjac]
1604169 Offline
Thanks, you are correct.
Other than the stiffer can and the "torque stopper" feature on the Denso FTF, are there any advantages I'm not seeing? Neither of these are worth paying $2 extra for, imo.
I guess I'm old school in thinking the more expensive one must be better in some way.
