Why is the flashpoint so low? Should I be concerned?
Code:
Blackstone Labs Used ATF Analysis
3/29/2012
Comments: Thanks for the notes about the new Honda ATF you're using. It looks like it's working pretty well so
far in your Civic's transmission. Our universal averages show typical wear for this type of transmission after
~18,500 miles of oil use, and most of your wear metals are reading at a fraction of those levels, so we don't
see any signs of problems developing. The flashpoint was quite a bit lower than we'd expect for an ATF, but
we don't see any contaminants or other problems that might give a reason for that. The TAN was 1.6, not
too acidic. No problems here.
Mi/Hr on Oil: 7,800
Mi/Hr on Unit: 56,200
Sample Date: 3/21/12
Make up oil added: 0
Sample Universal Averages
Aluminum 6 30
Chromium 0 1
Iron 20 65
Copper 6 15
Lead 2 2
Tin 0 1
Molybdenum 1 1
Nickel 0 0
Manganese 1 1
Silver 0 0
Titanium 0 0
Boron 226 221
Silicon 6 11
Sodium 0 8
Calcium 362 343
Magnesium 222 168
Phosphorus 26 111
Zinc 278 283
Barium 1 3
Sample Values Values Should Be
SUS Vis.210F 44.9 43-51
cSt Vis.100C 5.68 5.1-7.9
Flashpt F 285 >335
Water % 0.0
Insols 0.0
TAN 1.6
Code:
3/29/2012
Mi/Hr on Oil: 7,800
Aluminum 6 30
Chromium 0 1
Iron 20 65
Copper 6 15
Lead 2 2
Tin 0 1
Molybdenum 1 1
Nickel 0 0
Manganese 1 1
Silver 0 0
Titanium 0 0
Boron 226 221
Silicon 6 11
Sodium 0 8
Calcium 362 343
Magnesium 222 168
Phosphorus 26 111
Zinc 278 283
Barium 1 3
Flashpt F 285 >335
Water % 0.0
Insols 0.0
TAN 1.6
