Surf City garage barrier reef products?
by Rolla07
05/25/13 12:17 AM
24 Quarts Honda 0w20 SM Idemitsu
by Cooper
05/24/13 11:48 PM
MC 0W-20 SynBlend FF, 2200 mi, 13 Mustang 5.0
by mahler206
05/24/13 11:13 PM
$1.99 Formula Shell at Menards.
by Topo
05/24/13 10:42 PM
2012 Ram 3500 6.7 Cummins
by hollnagelc
05/24/13 10:23 PM
Fleet Farm Havoline $1.59/Mystic $1.99 Qt MMIR
by MDS
05/24/13 10:03 PM
Lower oil pressure at startup than when warm?
by Cperk
05/24/13 10:02 PM
Need help on finding oil
by Whimis
05/24/13 09:34 PM
diesel pump shuts off early
by motor_oil_madman
05/24/13 09:31 PM
QSUD 5-30, 7688mi, 2.2 Ecotec (04 Saturn Ion)
by MinamiKotaro
05/24/13 09:31 PM
Cigars , whiskey, and aspirin
by CourierDriver
05/24/13 09:08 PM
Quake State UD 5w30 SN, 7400 mi, 07 Subaru EJ25
by dsr70
05/24/13 08:48 PM
TheBiggRooster, btbeme, SideSwipe, Eddie2390, b3av3r
45552 Registered Users
37 registered (c502cid, Art_Vandelay, ABCarr, 901Memphis, asand1, ajchien, 1 invisible), 627 Guests and 229 Spiders online.
45552 Members
64 Forums
193911 Topics
Max Online: 2449 @ 05/13/13 01:57 PM
Page 1 of 2 1 2 >
#2581234 - 03/27/12 10:30 AM 04 Saturn Ion Cooling fan
Barkleymut Offline
Loc: Richmond, VA
Car is overheating when AC is on in stop and go traffic. With warmer temps right around the corner I need to fix this ASAP. I checked the relays and fuses and they are fine. Anyone with info on this car? I've done some searching any havent found the common problem. Guessing I need to test at the connector to see if the fan is getting any juice. If so the fan motor must be burnt out....correct?
04 Saturn Ion 2.2 5spd manual-Supertech 5w30+Pureone 01 Town & Country 3.3L 5w30 Supertech and Supertech filter
#2581235 - 03/27/12 10:31 AM Re: 04 Saturn Ion Cooling fan [Re: Barkleymut]
Barkleymut Offline
Loc: Richmond, VA
BTW the fan never turns on, even with AC running
#2581239 - 03/27/12 10:34 AM Re: 04 Saturn Ion Cooling fan [Re: Barkleymut]
MysticGold04 Offline
Loc: CA
yep, test at the connector for voltage. If you have voltage, it could be the fan motor. If you don't have voltage, maybe the coolant temp sensor?
'06 Focus SES 2.0 85,270 QSUD 5w30
'04 Highlander 2.4 142,374 Frankenbrew 5w35 or so
"God is Great, Beer is Good, and People are Crazy." USA
#2581241 - 03/27/12 10:35 AM Re: 04 Saturn Ion Cooling fan [Re: Barkleymut]
lexus114 Offline
Loc: Easton, PA
faulty sending unit? Do you have access to a scanner? Double check the wiring going to the fan. And pull the plug to the fan, temporarily wire it to see if the motor is good.
Edited by lexus114 (03/27/12 10:36 AM)
2005 Lexus RX 330 AWD
2012 Mercedes-Benz C300 4 Matic Sport Sedan (wife`s car)
#2581242 - 03/27/12 10:35 AM Re: 04 Saturn Ion Cooling fan [Re: Barkleymut]
Barkleymut Offline
Loc: Richmond, VA
where is the coolant temp sensor? can i test it, or is it a cheap part and easy install?
#2581245 - 03/27/12 10:37 AM Re: 04 Saturn Ion Cooling fan [Re: Barkleymut]
lexus114 Offline
Loc: Easton, PA
Not sure where the sensor is. But you can probably find out online.
#2581247 - 03/27/12 10:38 AM Re: 04 Saturn Ion Cooling fan [Re: Barkleymut]
Barkleymut Offline
Loc: Richmond, VA
no scanner but i can run up to autozone and have them test it
#2581253 - 03/27/12 10:45 AM Re: 04 Saturn Ion Cooling fan [Re: Barkleymut]
Barkleymut Offline
Loc: Richmond, VA
how do I temporarily wire the fan? just run a cable from pos terminal of battery to connector on fan??? I'm not an electrical guy at all.
#2581256 - 03/27/12 10:50 AM Re: 04 Saturn Ion Cooling fan [Re: Barkleymut]
Loc: CA
Yup.. also found a pic of the possible location of the ECTS (Engine Coolant Temp Sensor) from redlineforums.com - lover left hand corner of the pic - brass sensor with black plastic top for the connector. That whole housing is where the thermostat is.
http://www.redlineforums.com/forums/problems-troubleshooting/43301-location-ect-sensor.html
#2581282 - 03/27/12 11:26 AM Re: 04 Saturn Ion Cooling fan [Re: Barkleymut]
Barkleymut Offline
Loc: Richmond, VA
Thanks bro, btw God is GREAT, Beer is yummy and people Are Crazy. lol Love that song.
#2581345 - 03/27/12 12:29 PM Re: 04 Saturn Ion Cooling fan [Re: Barkleymut]
Dakota1820 Offline
formerly chevyboy14
Loc: missouri usa
Find the temp sensor and while car is running unplug it if fans come on sensor is bad if they don't come on it the fan motor.
2004 Honda civic vp -m1 5w30
1998 Saturn sl2 -mobil super 5000 5w30
#2581354 - 03/27/12 12:34 PM Re: 04 Saturn Ion Cooling fan [Re: Barkleymut]
Hokiefyd Offline
Loc: North Carolina
The fan should come on whenever the A/C compressor is engaged. The suggestions about checking the coolant temperature sensor are good, but I think if the fan doesn't turn on when the compressor is engaged, you have a mechanical problem with the fan/motor/relay itself.
2008 Honda CR-V - Green Tea - M1 0W-30, PSL14610
2005 Acura MDX - Billet Silver - QSUD 5W-30, PSL14610
#2581356 - 03/27/12 12:36 PM Re: 04 Saturn Ion Cooling fan [Re: Barkleymut]
Hokiefyd Offline
Loc: North Carolina
You can wire the fan do be on all the time, but you would want to do it through a relay, triggered by a wire connected to the IGN circuit in your fuse box. That way, whenever the ignition is on, the fan comes on. If you hard-wired it to the battery, it'd run all the time, even after the car is turned off.
#2581395 - 03/27/12 01:18 PM Re: 04 Saturn Ion Cooling fan [Re: Barkleymut]
Barkleymut Offline
Loc: Richmond, VA
gotcha Hokie, I was just talking about for testing purposes. Time to go to the eye doctor then work on the Saturn. Hopefully ya'lls tips will fix her up.
#2581618 - 03/27/12 05:52 PM Re: 04 Saturn Ion Cooling fan [Re: Barkleymut]
eljefino Offline
Loc: ME
BTW it's hard on your AC to run it without airflow over the condensor. It'll blow cooler when you fix the fan.
Page 1 of 2 1 2 >
