Mower revs up/down when cold
by DrRoughneck
08/24/16 12:14 AM
2015 dodge journey crossroad
by hardcore302
08/23/16 10:17 PM
Looking for new mechanical pencil
by Merkava_4
08/23/16 09:33 PM
Sewer gasses in bathroom
by sxg6
08/23/16 09:13 PM
I am a idiot, a fool or what? UOA coming soon!
by Vern_in_IL
08/23/16 08:57 PM
4ft LED T8 replacement bulbs 6.97$
by Rand
08/23/16 08:35 PM
Low cost sedan looks better than expensive one
by HTSS_TR
08/23/16 08:22 PM
Toyota red in motorcycles/snowmobi
les
by Altydoc
08/23/16 07:42 PM
Looking at some old posts
by Oldmoparguy1
08/23/16 07:35 PM
Towing a heavy trailer
by Donald
08/23/16 07:31 PM
Envelope Budget System
by GMFan
08/23/16 06:37 PM
Saving OPE after a flood?
by Geauxtiger
08/23/16 06:18 PM
Bigford545, FWR132, smancer, FJCurious, kburns
58899 Registered Users
37 registered (CharlieBauer, CKN, BrianF, Chris B., 5 invisible), 834 Guests and 6 Spiders online.
58899 Members
66 Forums
253477 Topics
Page 1 of 2 1 2 >
#2578763 - 03/25/12 07:55 AM Napa Platinum single/multipass efficiency?
blmlozz Offline
Loc: VA
Googled for a few minuites and didn't come up with anything. Did we ever get numbers for this filter? It would appear that I'd be paying $10+ and assuming that because it's fiberglass media that it must be 'good'. I'd rather not 'assume' this.
Edited by blmlozz (03/25/12 07:55 AM)
#2578789 - 03/25/12 08:25 AM Re: Napa Platinum single/multipass efficiency? [Re: blmlozz]
ARCOgraphite Offline
Loc: N.H, U.S.A.
Is there a wix equivalent? WIX show beta.
2014 Nissan Rogue S CVT, OC#4 19671mi-Castrol EDGE EP 5W30+Nissan 15208-9E01A Filter
2015 Forester 6MT 5Door, OC#6 41243mi-M1EP 0W20+Subaru Filter
#2578827 - 03/25/12 09:19 AM Re: Napa Platinum single/multipass efficiency? [Re: blmlozz]
daman Offline
Loc: Bad Axe, MI
No numbers yet that i know of,BUT if there anything like there OTR heavy truck filters like the XD and XE lines(witch I'm sure they are)then they will be very efficient at filtration as the ones we use(XE) are 5 mic nom.
I'm currently using the platinums on my vehicles and they seem like fine quality filters.
"Always"....Mobil 1
Current fill: AFE 0w30
#2578900 - 03/25/12 10:31 AM Re: Napa Platinum single/multipass efficiency? [Re: blmlozz]
blmlozz Offline
Loc: VA
Thanks for the replies. I'll look around some more for a WIX cross-reference. It would be nice if it's as good as the RP filters so I don't have to drive another 20minuites to the pepboys in order to grab one. Although the Fram Ulta's/Extended guard's are in the back of my mind, I'm unsure I'm ready to commit to the brand name on a 550+HP V8 that's going to see track use..
Edited by blmlozz (03/25/12 10:32 AM)
#2579077 - 03/25/12 01:27 PM Re: Napa Platinum single/multipass efficiency? [Re: daman]
ZeeOSix Offline
Loc: PNW
"5 microns Nominal Efficiency" means 50% efficient @ 5 microns. Hard to believe ... have to see published data on that one.
#2579224 - 03/25/12 03:37 PM Re: Napa Platinum single/multipass efficiency? [Re: ZeeOSix]
postjeeprcr Offline
Loc: USA
Why is that hard to believe? If it was a Purolator you would believe it and not need published data.
If I agreed with you, we'd both be wrong.
#2579311 - 03/25/12 05:08 PM Re: Napa Platinum single/multipass efficiency? [Re: blmlozz]
Turk Offline
Loc: MN
Well, I put on a NAPA Platinum on my 500+ HP GTO.
Zero cold start noise. Runs/sounds fantastic.
Curious about the numbers...
03 GMC Sierra 4x4 200k M1 0-40+PU
00 Saturn SL2 89 YO Lady Car 92k, Edge Ext
98 Saturn SC2 Rare "Red Hot" 165k, Edge Ext
97 Camry 245k, Maxlife
#2579333 - 03/25/12 05:26 PM Re: Napa Platinum single/multipass efficiency? [Re: postjeeprcr]
blmlozz Offline
Loc: VA
I believe he's suggesting this as all the fiberglass media filters I've seen thus far publish filter rates worse than typical mid-tier paper based filters. I haven't had a response to this querry in the other thread I asked this specific question about, but I gather the 'tradeoff' is that fiberglass media filters will filter slightly better over very long OCI's(maybe 12K+?), will flow better and have several other minor advantages. Do they filter 'better' or more effectively in the short term though? Everything I've seen points to 'no'
as far as trying to figure out this filter's effeciency based off looking up the comparable wix, all I've found is straight from Wix's website for a 5706053 ;
Beta Ratio: 2/20=6/20
Max Flow Rate: 10-12 GPM
Nominal Micron Rating: 21
The Flow rate matches what napa claims, but I can't imagine a $13 filter is rated for 50% @ 21microns.
Edited by blmlozz (03/25/12 05:32 PM)
#2579350 - 03/25/12 05:36 PM Re: Napa Platinum single/multipass efficiency? [Re: postjeeprcr]
ZeeOSix Offline
Loc: PNW
I do read published data from Purolator, so it's not "hearsay" performance from them. It's based on ISO testing standards. Do you even have any kind of reference at all that shows this 'Nominal Efficiency = 5 microns'?
#2579364 - 03/25/12 05:46 PM Re: Napa Platinum single/multipass efficiency? [Re: blmlozz]
ZeeOSix Offline
Loc: PNW
Well, looking at the data above, apparently the line that says "Nominal Micron Rating: 21" means something different to WIX than what it means as defined by the Filter Manufacturers Council (experts) as "Nominal Efficiency".
I say this because the Beta Ratio data above shows "2/20=6/20", which means 50% efficiency at 6 microns and 95% efficient at 20 microns. Confusing to the consumer.
So in one place "nominal efficiency" is 6 micron, and in another it's 21 microns.
#2579383 - 03/25/12 06:07 PM Re: Napa Platinum single/multipass efficiency? [Re: blmlozz]
flstffxe Offline
Loc: MN, USA
Try firing off an Email and see what if they respond.
http://www.napafilters.com/contact/
I have also had good luck getting some Ultra8 filter info via my local Napa Genuine Part(Warehouse/Distribution Center). Called asked who to talk to, was bumped over to a manager. Manager gave me a Email contact of who to ask. Sent a Email in the morning and had a reply with my info when I got home from work.
#2579397 - 03/25/12 06:23 PM Re: Napa Platinum single/multipass efficiency? [Re: blmlozz]
Sayjac Offline
Loc: The Old North State
Quote:
.....as far as trying to figure out this filter's effeciency based off looking up the comparable wix, all I've found is straight from Wix's website for a 5706053 ;....
I can't find that number on the Wix site and afaik at this point, Wix has not introduced a comparable full synthetic filter, so unlike the Wix/Napa Gold oil filter comparison, there would be no actual direct spec comparison.
Just speculating, but the specs are likely similar to the new Puro Synthetic, Amsoil Synthetic, and RP. Just fine imo, and not to fret using it for extended ocis. That said, I'm sure that won't satisfy the Bitog inquisitive, which is ok. Hopefully they will publish specs.
Also, nominal rating has been discussed here before, I too have been under the impression the 50% is generally considered the 'nominal' rating. As long as I can see a beta or efficiency that's enough for me, but for those that care, below is a thread regarding 'nominal' rating and differences in definition.
http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=1730250&page=1
#2579462 - 03/25/12 07:09 PM Re: Napa Platinum single/multipass efficiency? [Re: blmlozz]
blmlozz Offline
Loc: VA
it's the number pulled from their popup page under a 2012 CTS-V.
It would indeed be nice to know, since my OCI's usually fall between 9-11K it seems, and since middle tier paper filters are good for that long, I'm wondering if a glass media filter like this, RP or an Amsoil EAO would acutally end up filtering the same or worse since it's not being strung out to 15K or more..
They've been asked before. The defacto response seems to be no response at all. I believe the most informative posts came from one of the managers of a Napa chain and the best he could manage for us was;
Quote:
Ok here's the scoop. This filter will be a direct competition to Amsoil Ea line. I saw one cut apart today and they are identical. Full synthetic wire backed medium, silicone anti-drainback valve, nitrile gasket, coil spring, and high flow area (when applicable). Napa will be offering 3 lines now, all made by Wix. Platinum, Gold (regular re-packaged Wix) and a Silver line which compares to fram and a few others to name a few. They will still offer their [censored], leaky, proselect. (not made by Wix) and the NASCAR line is discontinued.
PS I work at Napa.
If you believe he acutally works for Napa that is..
http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=2304026&page=3
Edited by blmlozz (03/25/12 07:19 PM)
#2579499 - 03/25/12 07:54 PM Re: Napa Platinum single/multipass efficiency? [Re: blmlozz]
Sayjac Offline
Ok, the Wix # is 57060, the 53 is footnote to, available in master pack, thus why I couldn't find it. The main thing I was pointing out though is that's a standard Wix, so no direct comparison to the Napa Plat. Synthetic. And as you obviously know Napa lists no 'efficiency' specs for any Platinum on their site.
Can't answer the strung out to 15k question, but even if beta was listed I'm not sure the multipass ISO test is conducted in that manner. In any case, the only answer now is there are no published specs, until there are I don't think those questions can be answered. That said, if it were me I'd have no worries using it for a 9-11+k oci depending on oil an driving profile. But, that's just me. Good luck in your quest.
#2579867 - 03/26/12 07:40 AM Re: Napa Platinum single/multipass efficiency? [Re: blmlozz]
cp3 Offline
Loc: Kitchener, Ontario, Canada
I was quoted a 70 nominal rating for the Platinum from Wix but that was all I could get. He did also state that Wix will be bringing out their own line of synthetic/wire filters but not this year.
Dodge Charger|Pennzoil Platinum 5w20|Mopar MO-744
Pontiac G6 GT|Mobil 1 0w40|Mobil 1 M1-101
Page 1 of 2 1 2 >
