1997 Gand Marquis
by fordman65
56 minutes 56 seconds ago
Better micron rating than a 40u for a 4967/14476?
by ziggy
Today at 02:59 AM
Weapon Shield
by Ws6
Today at 12:33 AM
Amsoil Euro 5W-40 92Benz 190E 2.3L 8V 3889 miles
by IllinoisSparky
Yesterday at 09:11 PM
Which oil?
by SEMI_287
Yesterday at 09:05 PM
Fluid change on my 2015 Accord
by dan_erickson
Yesterday at 08:56 PM
Upgrading brakes
by ram_man
Yesterday at 08:49 PM
Rear end sounds like an airplane
by mclasser
Yesterday at 07:49 PM
GDI engine's and motor oils
by gabriel9766
Yesterday at 07:42 PM
Old toyota Need shocks?
by ceast
Yesterday at 07:27 PM
How to do a clean install
by Oldmoparguy1
Yesterday at 07:21 PM
Troy Bilt Pony
by OSUFan86
Yesterday at 06:43 PM
BlueKelah, threeeightteen, TOADchunks, Longo9596, Roadrunner77z
56889 Registered Users
31 registered (crazyoildude, dlundblad, Char Baby, car51, 6 invisible), 468 Guests and 201 Spiders online.
56889 Members
66 Forums
244533 Topics
#2575977 - 03/22/12 10:52 AM mobil 424
north1 Offline
Loc: north dakota
Have a versatile 305 mfwd tractor with a univance powershift transmission and shared reservoir with the hydraulic system. Have run caseih hytran in the past but want to simplify things and run mobil 424 in this tractor and two others to eliminate contamination of oil from implements the tractors are operating. Also have a Kubota tractor that uses kubota udt and I believe mobil 424 is a direct replacement.
So is mobil 424 as good as hytran and work well in the hyraulic systems in these tractors? Do the specs of mobil and hytran compare favorably? I believe hytran is noted for its ability to keep water in retention without degradation(up to 1%), but can't find any info for mobil 424. This can be a problem in farm equipment because hydraulic systems naturally build condensation and don't heat up enough to burn it off like engines do. Thanks in advance for any and all info.
Edited by north1 (03/22/12 10:54 AM)
#2576190 - 03/22/12 01:48 PM Re: mobil 424 [Re: north1]
Dusty Offline
Loc: Omaha, Ne
Mobilfluid 424 is every bit as good as HYtran, have no worries!
#2585729 - 04/01/12 08:58 AM Re: mobil 424 [Re: north1]
Whitewolf Offline
Loc: MI, USA
Mobil 424 is a good product in my experience. It's a UTTO (Universal Tractor Transmission Oil). The relatively high water tolerance stems from the use of totally different chemistry typically used in either ATFs or traditional gear oils. You might note that there is a Low Temperature version if you can find it. I can honestly say that you should not have a problem with this fluid.
My definition of an expert in any field is a person who knows enough about what's really going on to be scared.
~ PJ Plauger
