Dust caps needed to protect wheel bearings?
by Drew99GT
05/29/16 09:51 PM
2014 Mazda CX5 SkyActiv
by Matt_V
05/29/16 09:38 PM
getting rid of pwc with intermittent problem?
by motor_oil_madman
05/29/16 08:36 PM
Difference between silicone caulking ?
by Merkava_4
05/29/16 06:15 PM
The Top Dexos2 Oil Available in the USA is What?
by Best F100
05/29/16 05:24 PM
Virgin Puro L14006 [Cut open]
by Run
05/29/16 05:13 PM
The 17 year cicada is here. (locust) PIC HEAVY.
by Rand
05/29/16 04:23 PM
How long is sealed coolant good for?
by addyguy
05/29/16 04:08 PM
4T65E 2006 Buick Lucerne Normal decel gear banging
by deanm11
05/29/16 03:41 PM
California drought and 3" fish delta smelt
by HTSS_TR
05/29/16 03:18 PM
High SAPS & DPF Re-Gen
by userfriendly
05/29/16 02:50 PM
Decent little string trimmer
by Papa Bear
05/29/16 02:24 PM
Moutainman31282, AlaninPA, z0bug33, smitty31, jimshep
58013 Registered Users
95 registered (29662, 04SE, 901Memphis, adolan21, 2015_PSD, 2002 Maxima SE, 6 invisible), 1370 Guests and 311 Spiders online.
58013 Members
66 Forums
249575 Topics
Page 1 of 2 1 2 >
#2575597 - 03/21/12 11:23 PM Car has 2 catalytic converters. If I remove one...
Klutch9 Offline
Loc: Rochester, MI, US, World
Will I get a CEL? This is for down the road, should one of them fail. My Focus is a PZEV so it has 2 catalytic converters. AFAIK, the second o2 sensor (post cats) just measures a change in temperature. So if one cat was still there, I think the sensor would still be happy. Also, I think the PZEV model makes 5 less hp because of that 2nd cat; I know they're quite restrictive. I might even pick up an mpg or two.
'11 Fusion 2.5L - 60k miles - Napa 0w20, Fram TG filter
'08 Sedona LWB 3.8L - 96k miles - Napa 0w20, K&N PS filter
#2575609 - 03/21/12 11:28 PM Re: Car has 2 catalytic converters. If I remove one... [Re: Klutch9]
motor_oil_madman Online   content
Loc: Houston, Texas
If their is an 02 sensor after the second cat then I bet it would throw a CEL.
2007.5 dodge cummins 6.7 liter. Chevron Delo400 15w40. 7000 mile or 250-300hr intervals.
#2575613 - 03/21/12 11:31 PM Re: Car has 2 catalytic converters. If I remove one... [Re: motor_oil_madman]
Klutch9 Offline
There is, but that one cat will still reduce EGT's, which is what the second o2 sensor is usually looking for.
#2575614 - 03/21/12 11:32 PM Re: Car has 2 catalytic converters. If I remove one... [Re: Klutch9]
Chris142 Offline
Loc: apple valley, ca
Yes it will throw a CEL. Usually removing a cat decreases power and economy since the computer is designed with both cats in and working.
02 Wrangler super-s 10w30
87 F250 delo 15w40
04 Tahoe super-s 5w30
Z400 Lucas 10w30
KLR250 Maxima 10w40
Can am maveric delo 5w40
#2575641 - 03/21/12 11:55 PM Re: Car has 2 catalytic converters. If I remove one... [Re: Klutch9]
stephen9666 Offline
Loc: USA
This is a little confusing to me.
If the "second o2 sensor" only measured temperature, then it would be a temp sensor, not an oxygen sensor.
#2575650 - 03/22/12 12:04 AM Re: Car has 2 catalytic converters. If I remove one... [Re: Klutch9]
tommygunn Offline
Loc: usa
Secondary sensors measure O2 after the cat and compare it to the upstream. The way cats work there should be a different amount of oxygen in contrast to the upstream, as the reaction causes O2 to go up (or down, I can't remember the exact reaction...but it should be different at any rate).
If O2 levels are the same before and after the cat its reasonable to assume the cat is no longer functioning and the CEL goes off.
So, is there still a cat between your upstream and downstream? Good. It could be fine if thats still the case. But obviously if you change it who knows what it could do.
Obviously if its a straight pipe between upstream and downstream eventually it'll complain.
It does nothing to measure temperature.
i am a [censored] who hides behind bugmenot.
i also like applying negative pressure to a certain male appendage.
#2575654 - 03/22/12 12:05 AM Re: Car has 2 catalytic converters. If I remove one... [Re: Klutch9]
rpn453 Offline
Loc: Saskatchewan
The oxygen sensor measures oxygen. It's not looking for temperature changes, it's looking for a smoothing of the oxygen readings. That's why a spark plug anti-fouler can often compensate for converter removal. By removing the sensor from the direct stream, the changes it sees occur less rapidly.
This would probably be vehicle-dependent. Check a more specific forum to see if anyone has experimented with this on a similar Focus.
2004 Mazda3 GT Hatch 75k
#2575693 - 03/22/12 12:58 AM Re: Car has 2 catalytic converters. If I remove one... [Re: Klutch9]
pzev Offline
Loc: arctic
Might have been changed for O7, but on the earlier Focus Duratecs, there was only 02 sensors on the upstream "mani-cat" (exhaust manifold/catalytic converter combination). The second did not have any accompanying 02 sensors, which means you can remove it without worry of a CELL.
However, they could have changed that in later model years. The bottom line is this...if there are 02 sensors after the second catalytic converter, then yes, you'll throw a CELL if you remove it.
#2575696 - 03/22/12 01:05 AM Re: Car has 2 catalytic converters. If I remove one... [Re: Klutch9]
strongt Offline
Loc: So. Utah
I'm betting if you remove the 2nd Cat you'll trip the CEL. Besides why remove it? I'm sure Ford put some pretty low restriction Cat's on that model. It would make them look bad on the green side for selling a PZEV clean air car that get worse MPG's for being a "Green" model.
Shoot my Jeeps got 3 Cat's. 2 Pre-Cats by the engine and a Cat after those.
2001 Oldsmobile Aurora 4.0 102,000 Miles
Mobil Super 5000 5W30
#2575731 - 03/22/12 05:08 AM Re: Car has 2 catalytic converters. If I remove one... [Re: Klutch9]
NHGUY Offline
Loc: USA
They added the 2nd sensor to check up on the cat.With OBDII it has to sense and report any condition that may cause excess emissions.But I really bet they added it after all those years of people hollowing out the cats to appear legit but in actuality do nothing at all.People cant do that anymore (and thats a good thing for emissions overall).
#2575802 - 03/22/12 07:42 AM Re: Car has 2 catalytic converters. If I remove one... [Re: rpn453]
dwcopple Offline
Loc: Michigan
This. buy 'em at Advance Auto and remove the cat.
2015 Chevrolet Silverado All-Star edition 4.3 Ecotec3 V6
2011 Chrysler 200 Limited 3.6L V6
#2575866 - 03/22/12 09:06 AM Re: Car has 2 catalytic converters. If I remove one... [Re: Klutch9]
lexus114 Offline
Loc: Easton, PA
Dont mess with the emissions system. Your car isnt going to run that much better anyway, if at all. You might pick up a little low end, but the top end will suffer. Today`s Catalytic Converters are not nearly as restrictive as they used to be. I remember my Mom`s 77 Pontiac Gran Prix, when you would floor it, all you would hear was air from the exhaust. It had that pancake style converter on it, and they always seemed to clog up.
Edited by lexus114 (03/22/12 09:09 AM)
2012 Mercedes-Benz C300 4matic
2015 Lexus RX350 AWD
#2575886 - 03/22/12 09:28 AM Re: Car has 2 catalytic converters. If I remove one... [Re: Klutch9]
JTK Offline
Loc: Buffalo, NY
What are you trying to gain by removing one of the CCs?. It's a Focus and it's relatively new being a 2007 w/ only 38Kmi? You're not going to get a noticeable performance or economy gain.
You've got years and miles left on your Federal emissions warranty coverage anyway. If something should happen to the remaining CC w/in the 7/70 Fed warranty and they see you hacked the exhaust, your SOL.
Joel
Edited by JTK (03/22/12 09:30 AM)
2016 Subaru Forester 2.5, CVT. 2013 Dodge Grand Caravan SE (Babe magnet III)
#2575987 - 03/22/12 10:58 AM Re: Car has 2 catalytic converters. If I remove one... [Re: lexus114]
jeepman3071 Offline
Loc: Storrs, Connecticut
This. Plus it is against federal law. I'm surprised your post is still here, as most online forums prohibit the discussion of removing cats and emission equipment. hornets
2000 Jeep Cherokee Sport 4.0L (163k) - Pennzoil HM 10w30, Napa Gold 1516, Magnefine trans filter
#2575993 - 03/22/12 11:01 AM Re: Car has 2 catalytic converters. If I remove one... [Re: Klutch9]
Hokiefyd Offline
Loc: North Carolina
Guys...re-read his first post. He's simply asking a theoretical question should one of his converters eventually fail 100k miles down the road. He never said he has plans to remove it.
Cheers,
Jason
2009 Honda Ridgeline RTL
2005 Acura MDX Touring
Page 1 of 2 1 2 >
