2006 Charger - rack getting replaced
by OVERKILL
05/06/16 05:38 PM
A Story Worth Living
by LoneRanger
05/06/16 05:37 PM
Snake Oil Detergent - 0.37 Cents
by Greg L
05/06/16 04:35 PM
Wax for silver car
by 007
05/06/16 04:32 PM
Trump's empty picture frames
by SumpChump
05/06/16 04:05 PM
Is 0w40 slightly Thicker than 5w30?
by Greg L
05/06/16 03:53 PM
Keep it simple.
by JustinH
05/06/16 03:28 PM
Pennzoil Ultra Platinum, 5W-30, 5k OCI, 20k total
by Joshua_Skinner
05/06/16 02:26 PM
Amsoil 75w90, 45K, 04 Chevy Tahoe
by dhellman12
05/06/16 02:09 PM
What happened to this kind of oil change?
by OneEyeJack
05/06/16 01:44 PM
OH! OH! Gas/Diesel mixup
by azjake
05/06/16 01:09 PM
VOA Pennzoil Platinum Euro 5w40 - SN
by agpatel
05/06/16 12:36 PM
waldawg, Defcon, drivingaford, funkyheff, Ralph62
57814 Registered Users
90 registered (A_A_G, AZjeff, 2015_PSD, AirgunSavant, AUTOTECH89, 8 invisible), 0 Guests and 1 Spider online.
57814 Members
66 Forums
248557 Topics
#2565693 - 03/12/12 08:55 PM Switch from 5w20 to10w30 for towing
250SD_54V8 Offline
Loc: Albuquerque, NM. USA
I have a 06 Ford F250 SD with a 5.4L gas V8 with 26,000 miles that I have ben using 5w20 NAPA Syn.in.
I am going to start towing a 26' enclosed car hauler on a regular basis untill I can trade up for a Diesel.
This load will stress my little 5.4 a lot.
Will 5w20 protect my engine or should I switch to a 10w30?
A Ford master tech told me I should use 10w30 or even a 10w40!
What do you guys think?
#2565697 - 03/12/12 08:59 PM Re: Switch from 5w20 to10w30 for towing [Re: 250SD_54V8]
JRed Offline
Loc: Virginia
If you have oil pressure/temp gauges and you're not towing on steep grades it may not be a huge deal. 10w-30 won't hurt the truck. 10w-40 probably isn't necessary.
If it's going to be that hard on the engine, it'll probably be just as hard on the transmission. Does your truck have an external trans cooler, or one of those "built into the radiator" jokes?
Edited by JRed (03/12/12 08:59 PM)
06 Subaru Impreza WRX - Sold. The only mechanical thing I'll ever love.
07 Toyota Prius - Cheap synthetic and PureOne filters.
#2565707 - 03/12/12 09:05 PM Re: Switch from 5w20 to10w30 for towing [Re: 250SD_54V8]
250SD_54V8 Offline
The front of this truck is full of coolers it has a seperate engine oil and trans oil cooler. I think it was part of the HD towing package.
#2565708 - 03/12/12 09:07 PM Re: Switch from 5w20 to10w30 for towing [Re: 250SD_54V8]
tig1 Online   content
Loc: Illinois
You may need to be more concerned about the tranny than the engine.
2007 Ford Fusion 179,000 miles
M1 0-20 AFE
2007 Ford Focus 153,000 miles
M1 0-20 AFE
M1 ATF
M1 10-30 in all OPE
MC filters
#2565712 - 03/12/12 09:12 PM Re: Switch from 5w20 to10w30 for towing [Re: 250SD_54V8]
DrDusty86 Offline
Loc: TX
You are FINE! relax and keep it serviced with the 5w20 and service the trans. The SD is a tough truck.
Aside from being a little slow, you'll be just fine
#2565714 - 03/12/12 09:13 PM Re: Switch from 5w20 to10w30 for towing [Re: 250SD_54V8]
OVERKILL Online   content
Loc: Ontario, Canada
Ford tested the poo out of that configuration. Use what they recommend.
02 Expedition
06 Charger R/T
14 Charger SRT-8
#2565726 - 03/12/12 09:23 PM Re: Switch from 5w20 to10w30 for towing [Re: OVERKILL]
95busa Offline
Loc: Tennessee
When I worked on wind turbines we would pull massive trailers full of 14,000 pounds of scrap 45 miles to the scrap yard with our F250 Quad Cab 5.4 SD service trucks. They weren't too enthusiastic about it, but they did it for well over 100,000 miles with the cheapest bulk 5w-20 there is. I wouldn't sweat it, those things are tough as [censored].
2005 Ford F250 Super Duty 4x4
2009 Dodge Grand Caravan
2014 Kia Forte KOUP- totaled by a drunk driver
#2565744 - 03/12/12 09:33 PM Re: Switch from 5w20 to10w30 for towing [Re: 250SD_54V8]
2015_PSD Online   content
Loc: SE Texas
I have 65,000+ on my F-150 FX4 with a 5.4L and it has only seen 5W-20 and at least 15,000 of those miles have been towing and all of my UOAs have been quite ok. I tow a 28' enclosed trailer and I would not switch to 10W-30 or 10W-40 as I have found no need. 10W-30s and 10W-40s shear into a 20 in short order anyway.
I think the Ford Master Tech needs to take a refresher on the specifications on the engine in question. Strictly speaking, Ford specified 5W-20 for all gasoline engines in the 2006 F-250 with nothing noted as an exception for towing.
2015 F-250 PSD.................Kendall 15W-40 CJ-4 + CQ
2014 Explorer LTD.............PUP 5W-20 SN + FU
2010 Kawasaki BF750 4x4....RT6 5W-40 + OEM
#2565751 - 03/12/12 09:39 PM Re: Switch from 5w20 to10w30 for towing [Re: 250SD_54V8]
crazyoildude Online   content
Loc: New Jersey
use 5w20 5w30 wont hurt but 5w20 is ideal. 5w20 will let the bearings run cooler because the engine will have less drag
5w20 also get everywhere faster hot or cold
#2565826 - 03/12/12 10:43 PM Re: Switch from 5w20 to10w30 for towing [Re: 250SD_54V8]
RISUPERCREWMAN Offline
Loc: RHODE ISLAND
Yup stay with 5W-20!
2014 Ram 2500 HD 5.7 Hemi 4x4 7K miles
8'Boss SuperDuty Plow
2015 Harley Davidson Ultra Limited 1500 miles
2009 Toyota V6 XLE Camry 49 Kmiles
#2566028 - 03/13/12 08:21 AM Re: Switch from 5w20 to10w30 for towing [Re: 250SD_54V8]
tig1 Online   content
Loc: Illinois
20wt oil should be fine, but I would switch to a higher quality synthetic if it were me.
M1 0-20 AFE
M1 0-20 AFE
M1 ATF
M1 10-30 in all OPE
MC filters
#2566075 - 03/13/12 09:06 AM Re: Switch from 5w20 to10w30 for towing [Re: 250SD_54V8]
Jeff_in_VABch Offline
Loc: Virginia
I agree with the others that the transmission will pop way before the engine. That engine dosent make enough power to hurt itself.
Interests - motorsports/engine building/tuning
Background - Performed work at refineries and several oil blending plants.
Occupation - Mech Engr
#2566171 - 03/13/12 10:49 AM Re: Switch from 5w20 to10w30 for towing [Re: 250SD_54V8]
RWDIII Offline
Loc: ariz
I have a F150,2006,5.4 and towing package.I dont tow as much wt as you do but since I tow in hotter area.Ariz desert,I was also concerned.I use 5qts MC5-20 blend and 2nqts 5-30 PP.Seems to do the trick. The trans seems to be the weak link in the 06 pickups followed by the bad spark plugs. mad
#2566588 - 03/13/12 06:44 PM Re: Switch from 5w20 to10w30 for towing [Re: JRed]
mechtech2 Offline
Loc: Chicago Area
Good advice.
#2566655 - 03/13/12 07:31 PM Re: Switch from 5w20 to10w30 for towing [Re: 250SD_54V8]
JRed Offline
Loc: Virginia
If it has a decently-sized external engine oil AND trans oil cooler then you're probably golden. As others have said, that's not an engine with a high power density so it should be fine.
Transmission will probably be fine too.
Whole truck will probably be fine. It may not act like it's enjoying every moment of towing, but hey.
