Here is part of the Auto-Trak MSDS.
CHEMISTRI 10/29/02
DISPLAY MATERIAL SAFETY DATA SHEET 16:47:56
SCREEN QA06__ KEY 0000862844,0000000018______________________
FID#: 00343326 VER-DT: 05/07/99
SECTION 01: CHEMICAL PRODUCT & COMPANY ID
PRODUCT PRIMARY NAME: RDL 3239B
CHAT SYNONYMS: AUTO-TRAK II
> RDL 3239B
> 12378508
> 773494
> 88900402
> 9986186
SAFE USE CATEGORY AND DESCRIPTION: 04 -METAL WORKING FLUIDS
AND LUBRICANTS
LAST UPDATED DATE: 1999-05-07
MANUFACTURER'S ID (MID): 000553637
MANUFACTURER'S NAME: PETRO-CANADA
MANUFACTURER'S EMERGENCY PHONE NUMBER/TEXT: CA 403-296-3000
MANUFACTURER'S MAILING ADDRESS:
P.O. BOX 2844
CALGARY AB T2P3E3
CA
PRODUCT USE: AUTOMATIC TRANSMISSION FLUID DESIGNED PRIMARILY
FOR SATURN VEHICLES BUT SUITABLE ALSO FOR OTHER VEHICLE MAKES
AND AS A HYDRAULIC
AND POWER STEERING FLUID FOR MOBILE EQUIPMENT.
SECTION 02: COMPOSITION & INGREDIENT INFO
CAS# FORMULATION W/V CHEMICAL NAME
000100414 T 0.0000/ 0.0000% W BENZENE, ETHYL-
001330207 T 0.0000/ 0.0000% W XYLENE
007446095 T 0.0000/ 0.0000% W SULFUR DIOXIDE
064741884 = 1.8600/ 0.0000% W MINERAL OIL, PETROLEUM DISTILLATES
* , SOLVENT-REFINED (severe) HEAVY P
* ARAFFINIC
064741975 < 0.0000/ 1.0000% W MINERAL OIL, PETROLEUM DISTILLATES
* , SOLVENT-REFINED (severe) LIGHT N
* APHTHENIC
064742650 = 1.8600/ 0.0000% W MINERAL OIL, PETROLEUM DISTILLATES
* , SOLVENT-DEWAXED HEAVY PARAFFINIC
* (severe solvent-refining and/or h
* ydrotreatment)
068171506 = 4.3800/ 0.0000% W 2-Propenoic acid, 2-methyl-, dodec
* yl ester, polymer with methyl 2-me
* thyl-2-propenoate and tetradecyl 2
* -methyl-2-propenoate
072623848 = 12.6200/ 0.0000% W Lubricating oils, petroleum, C15-3
* 0, hydrotreated neutral oil-based,
* contg. solvent deasphalted residu
* al oil
072623860 = 74.3600/ 0.0000% W Lubricating oils, petroleum, C15-3
074499368 T 0.0000/ 0.0000% W 9,10-Anthracenedione, 1,4-diamino-
* , N,N'-mixed 2-ethylhexyland Me an
* d pentyl derivs.
989915788 = 5.0200/ 0.0000% W MINERAL OIL
989922365 < 0.0000/ 1.0000% W ACRYLIC COPOLYMER
989981804 < 0.0000/ 1.0000% W HETEROCYCLIC ETHER
SECTION 2 - OTHER INFORMATION: THIS PRODUCT CONTAINS THE
FOLLOWING ADDITIVE PACKAGES: ACRYLOID 4115, ACRYLOID 1265,
HITEC 437, LUBTIZOL 730, AND BLUE DYE #1.
THRESHOLD LIMIT VALUE: 8-HOUR TLV-TWA OF 5 MG/M3 RECOMMENDED
BY MANUFACTURER BASED ON ACGIH TLV FOR OIL MISTS. CONSULT
LOCAL AUTHORITIES FOR ACCEPTABLE EXPOSURE LIMITS.
CERCLA (SUPERFUND) REPORTABLE QUANTITY (LBS): NONE
AUTO-IGNITION TEMPS: = 202.00C/ 395.00F
FLASH POINT TEMPS: = 182.00C/ 359.60F
FLASH POINT METHOD: COC
FLASH POINT METHOD TEXT: OPEN CUP; CLEVELAND OPEN CUP TESTER, ASTM D9.2.
