Sweden Trials Electric Higway for Trucks
by Y_K
46 minutes 35 seconds ago
17 yo deutsch filter?
by robo339
Yesterday at 11:07 PM
Ford Focus wrecked
by tig1
Yesterday at 10:13 PM
Valvoline Maxlife vs Supertech Synthetic vs QSED
by mazdamonky
Yesterday at 09:56 PM
Lexus seats in a Camry
by Nick1994
Yesterday at 09:52 PM
shop rechecking work after front end parts replace
by motor_oil_madman
Yesterday at 09:50 PM
M1-EP vs vanilla M1
by Atomic
Yesterday at 09:29 PM
Supertech Synthetic and Citgo
by RRLJR
Yesterday at 09:28 PM
Gun Belt Wanted
by FirstNissan
Yesterday at 08:24 PM
car wash soap for pressure washer
by Donald
Yesterday at 08:16 PM
Deep tranny pan worth it?
by rsylvstr
Yesterday at 07:20 PM
Which oil for my old BMW and why?
by fdcg27
Yesterday at 06:20 PM
Josh_Westwood, Brogan, Superlatives, Ruturaj, derfderfgoose
58280 Registered Users
26 registered (CR94, bbhero, Chewie, DeafBrad, 76sixer, Boczech), 1091 Guests and 16 Spiders online.
58280 Members
66 Forums
250854 Topics
Page 1 of 2 1 2 >
#2555202 - 03/03/12 07:59 AM How To Protect Battery Terminals From Corrosion ?
ChrisD46 Offline
Loc: GA.
I just cleaned the light layer of green colored corrosion from my battery terminals - what's the best , most cost effective coating I can apply to protect against future corrosion ?
#2555205 - 03/03/12 08:06 AM Re: How To Protect Battery Terminals From Corrosion ? [Re: ChrisD46]
NHGUY Offline
Loc: USA
Use those felt washers under the clamps,and spritz a little Fluid Film on each terminal.It stays wet.
#2555223 - 03/03/12 08:33 AM Re: How To Protect Battery Terminals From Corrosion ? [Re: ChrisD46]
LargeCarManX2 Offline
Loc: Up here in the NorthWest
Vasoline!
It's true and cheap.
"Success is the ability to go from one failure to another with no loss of enthusiasm."
Sir Winston Churchill
#2555231 - 03/03/12 08:42 AM Re: How To Protect Battery Terminals From Corrosion ? [Re: ChrisD46]
Trav Offline
Loc: MA, Mittelfranken.de
In addition to greases,felt washer, etc throw a copper penny (not aluminum one) next to the post.
It wont move and will draw all that stuff to it instead of the post.
Chances are if you really have a lot of corrosion the seal between the post and the case is broken.
This is usually from over tightening.
#2555235 - 03/03/12 08:43 AM Re: How To Protect Battery Terminals From Corrosion ? [Re: LargeCarManX2]
Jimmy9190 Offline
Loc: Clermont, Florida
Originally Posted By: LargeCarManX2
Vasoline!
+1 on Vaseline. It is cheap and lasts a long time on the terminals. I have no experience with the felt washers, but I have been using vaseline on my battery terminals for over 20 years and have never had a corrosion or green fungus problem. I put it on the battery posts and the inside and outside of the cable clamps.
Jimmy9190
2013 Honda Civic LX Sedan
Napa Synthetic 0W20, Napa Gold 7356
#2555238 - 03/03/12 08:45 AM Re: How To Protect Battery Terminals From Corrosion ? [Re: Jimmy9190]
Corvette Owner Offline
Loc: Waldorf, Maryland
I use those felt washers and special battery terminal spray.
Vehicles:
98 Corvette
06 Murano
96 Chevy Van (Custom Conversion)
14 Chevy Impala
10 Starcraft Boat
13 Buick Enclave
#2555266 - 03/03/12 09:07 AM Re: How To Protect Battery Terminals From Corrosion ? [Re: ChrisD46]
Donald Offline
Loc: Upstate NY
I like the felt washers. Clean it with baking soda first. Vaseline or the red battery spray stuff. Put some chassis grease or never-seeze on the threads of hold down hardware.
+1 on the cracked battery case if you keep getting corrosion back after cleaning it.
2015 Ford F250 w/Powerstroke
2001 Jeep Grand Cherokee Laredo 4.0- sold
1999 Dodge Ram 2500 w/Cummins- 4-sale
#2555294 - 03/03/12 09:27 AM Re: How To Protect Battery Terminals From Corrosion ? [Re: ChrisD46]
rob6773 Offline
Loc: NY
Pennie and grease both work. Also check alternator voltage because a situation of overcharging create more gases.
#2555329 - 03/03/12 09:50 AM Re: How To Protect Battery Terminals From Corrosion ? [Re: Trav]
Chris142 Offline
Loc: apple valley, ca
X2 or you have an Exide made battery. I've seen brand new ones on the shelf with a green corrosion all over the posts.
02 Wrangler super-s 10w30
87 F250 delo 15w40
04 Tahoe super-s 5w30
Z400 Lucas 10w30
KLR250 Maxima 10w40
Can am maveric delo 5w40
#2555355 - 03/03/12 10:15 AM Re: How To Protect Battery Terminals From Corrosion ? [Re: ChrisD46]
jim302 Offline
Loc: Raleigh, NC USA
Deka or Johnson Controls batteries tend not to corrode the terminals much if any as long as they haven't been over-tightened. This includes not just the battery cables, but the hold-down mechanism as well. I have seen people tighten them down so much that they actually deform the battery case slightly. This is also why I don't take advantage of free battery installation at automotive supply stores. The ones without removable caps for checking the water level (for example, most Deka batteries) seem to be the absolute best about not corroding possibly due to the vent design.
Remember that batteries are not wheels and they don't need 90 ft lbs of torque. Once you can't move the cables by pulling them gently, they are probably tight enough.
The felt terminal protectors and a protector spray seem to help out as well. I use the CRC terminal protector spray, and one can will last for many years. However if the case or seal is cracked, this will only be a temporary fix and they will corrode again soon.
Edited by jim302 (03/03/12 10:17 AM)
2006.5 Kia Optima V6 - Valvoline 5w-20 - Kia 26300-35503 filter
#2555593 - 03/03/12 01:49 PM Re: How To Protect Battery Terminals From Corrosion ? [Re: jim302]
ChrisD46 Offline
Loc: GA.
Thanks for the replies ! ...I have only slight green layer on one terminal which cleaned up nicely with baking soda & water ...now just want to keep 'em looking nice .
#2555766 - 03/03/12 04:09 PM Re: How To Protect Battery Terminals From Corrosion ? [Re: ChrisD46]
3311 Offline
Loc: Fl
Although many do, I personally don't like the felt washers. I feel they can become a magnet for dirt, corrosion and shorting if they become saturated/neutralized with acid.
I just clean the terminals when I replace the battery. Vaseline is much better protectant IMO than that red spray junk as well. And it certainly cleans easier.
04 2500hd 6.0 278k/1k Pen HM 5w30 10w40 mix XG3675 VML ATF Dex
03 C7500 Dmax7.8l 134k ST 15w40,M1ATF Dex
06 2500hd 6.0 220k ? 5w30 ST DexVI PGL
#2555842 - 03/03/12 05:14 PM Re: How To Protect Battery Terminals From Corrosion ? [Re: ChrisD46]
Jarlaxle Offline
Loc: New England
Coat them with ordinary wheel-bearing grease. It will last for years.
#2555874 - 03/03/12 05:50 PM Re: How To Protect Battery Terminals From Corrosion ? [Re: ChrisD46]
Rick in PA Offline
Loc: Southeastern, PA
I'm a felt washer guy. Every so often I'll put a little squirt of oil on top of the terminal and on the clamp bolt. Yes, the battery top gets a little oily, and no, I've never had corrosion. Been doing this for 35 years, no problem.
A wise man told me:
"Heat is your friend." and "Any oil is better than no oil."
#2556233 - 03/03/12 11:17 PM Re: How To Protect Battery Terminals From Corrosion ? [Re: Rick in PA]
AITG Offline
Loc: USA
I like the felt washers along with a coating of Permatex High Tack (red, aerosol spray).
However, GM side terminal batteries just get torqued to spec.
Page 1 of 2 1 2 >
