45538 Members
64 Forums
193856 Topics
Max Online: 2449 @ 05/13/13 01:57 PM
#2552981 - 02/29/12 10:36 PM
Re: TOTAL Quartz Energy 9000 5W40
[Re: CATERHAM]
Loc: MA
Yes that's a good way of putting it; a 0W-20 trumps the 5W-20 grade.
One main advantage of synthetic oils is their inherently higher VI's. Many 5W-20 mineral oils (dino) have a VI of at least 150. The 5W-20 is a dino grade that is unique to North America. In the rest of the world all 20wt oils are 0W-20's. There really isn't much point in making a synthetic oil with a VI no better than what a dino already provides.
To my way of thinking, unless a synthetic oil has a VI greater than 165 it's a poor value. And do you prefer the 0w-20 to be group III or group IV , or does this not matter at all given that the Visc index is >165 ?
#2553006 - 02/29/12 11:26 PM
[Re: fpracha]
Loc: Burlington, Ontario, Canada
I couldn't care less if it's GP III or GP IV athough if it contains a significant amount of GP V that would get my attention.
It's the performance spec's that count plus the add' pac'.
'74 Lotus Europa - 5W-50,VSOT '86 Porsche 928S - TGMO 0W-20/M1 0W-40 blend '96 BMW 328i - Idemitsu 0W-20/M1 0W-40 " '94 Caterham 7 - Sustina 0W-20
#2553151 - 03/01/12 08:07 AM
[Re: CATERHAM]
Loc: Michigan
Which 0w20 would you recommend for a 2008 Ford Edge (25K miles) and a 2005 Honda Odyssey (110K miles)? Both are daily drivers with a majority of highway miles with some short trips mixed in around town.
#2553352 - 03/01/12 11:56 AM
[Re: clevel]
Which 0w20 would you recommend for a 2008 Ford Edge (25K miles) and a 2005 Honda Odyssey (110K miles)? Both are daily drivers with a majority of highway miles with some short trips mixed in around town. Ignoring price heres an off the top of my head list starting with my first choice: Toyota 0W-20 Mazda and Mitsubishi 0W-20 Honda 0W-20 QSUD/PP 0W-20 Mobil Super 0W-20 Valvoline 0W-20 M1 AFE 0W-20 The rest of the OTC 0W-20s
#2553357 - 03/01/12 12:00 PM
[Re: CATERHAM]
Oh and you can place RP 0W-20 between the Idemistu made Mazda and the CoP made Honda 0W-20s.
#2553397 - 03/01/12 12:39 PM
[Re: CATERHAM]
Loc: Michigan
Thank you for the information. I think I will switch both verhicles to the 0w20 based on your information. Is the dealer the best place to purchase the Toyota or Honda 0W20 or is there an online source to purchase from?
#2553418 - 03/01/12 12:55 PM
[Re: clevel]
Yes every Toyota/Lexus and Honda/Acura dealer of course carries the OEM oil. Shop around and the best price can usually be negotiated on a 12 bottle case. BTW, if you're close to the Cdn border prices here can be cheaper and the Honda 0W-20 is the preferred Idemitsu made oil.
It is also available on line from some Toyota and Honda parts discounters.
#2553436 - 03/01/12 01:10 PM
[Re: CATERHAM]
Loc: Michigan
Thanks. Just found it locally for $7.25/quart. Honda wanted $8.90/quart for their version so Toyota it is. Toyota oil in a Ford, oh boy.
#2553665 - 03/01/12 05:48 PM
[Re: clevel]
Toyota oil in a Ford, oh boy. If it makes you feel any better, think of it as a SN GF-5 USA made Mobil oil that just happens to meet Toyota spec's.
#2553671 - 03/01/12 05:58 PM
[Re: CATERHAM]
Loc: Toronto, ON
It's the performance spec's that count plus the add' pac'. In addition to VI, what other ' performance specs ' would place an emphasis / focus on ? And do you know if the commonly referenced technical specs for that Toyota 0W-20 has been detailed elsewhere on BITOG somewhere ?
Edited by Terra_Nova (03/01/12 06:01 PM)
#2554054 - 03/02/12 06:37 AM
[Re: clevel]
Loc: Toronto, ON
Which 0w20 would you recommend for a 2008 Ford Edge (25K miles) and a 2005 Honda Odyssey (110K miles)? Both are daily drivers with a majority of highway miles with some short trips mixed in around town. This question would probably make a good thread topic in the PCMO forum and draw a much larger amount of feedback / suggestions from the BITOG membership I'd suspect..
#2554062 - 03/02/12 06:56 AM
[Re: CATERHAM]
Loc: Duvall WA - Pacific NW USA
Unless that VI is achieved with low grade VII's and PPA's. To me, this is the weakness of using VI as a guide for choosing motor oils.
#2554080 - 03/02/12 07:37 AM
[Re: Pablo]
Loc: Toronto, ON
Unless that VI is achieved with low grade VII's and PPA's. To me, this is the weakness of using VI as a guide for choosing motor oils. Is it reasonable to assume that in order for Toyota to get a 0W20 VI of 216, this very high VI was achieved primarily by mean of the heavy use of Viscosity Index Improver additives ? So, if you had a Group 3 base stock, the additives would help drive the VI to such a high number of 216 ? And I suppose with an Amsoil oil with a Group 4 base stock, the inherent nature of the Group already has a naturally high VI to begin with and may not degrade as quickly as an additive enhanced VI might.? Could a Group 3 base stock with such a high VI, derived primarily ( I assume ) from additives sustain that VI spec over an extended drain interval in your view ? Welcome your thoughts.
#2554106 - 03/02/12 08:15 AM
[Re: CATERHAM]
Loc: Michigan
So I was set to go with the Toyota 0w20 for $7.25/quart (Need six quarts) however, I just found Mobil 1 AFE 0w20 in a 5 quart jug for $32.99 (Includes M 1 filter) with 25% off an additionl quart. Total cost for M 1 with filter would be about $40 + tax. Toyota cost would be $42 + tax + filter or about $15 more using the same M 1 filter. Even though I don't want cost to be the only factor, does it make for sense to go with the Mobil 1 AFE due to the deal from AAP?
Edited by clevel (03/02/12 08:21 AM)
#2554225 - 03/02/12 10:13 AM
[Re: clevel]
Loc: Toronto, ON
So I was set to go with the Toyota 0w20 for $7.25/quart (Need six quarts) however, I just found Mobil 1 AFE 0w20 in a 5 quart jug for $32.99 (Includes M 1 filter) with 25% off an additionl quart. Total cost for M 1 with filter would be about $40 + tax. Toyota cost would be $42 + tax + filter or about $15 more using the same M 1 filter. Even though I don't want cost to be the only factor, does it make for sense to go with the Mobil 1 AFE due to the deal from AAP? What is your oil change interval going to be like with that oil and filter - i.e you going to go by some fixed miles / months extended drain interval or simply follow the oil life monitor ?
