45569 Members
64 Forums
193964 Topics
Max Online: 2449 @ 05/13/13 01:57 PM
#2542355 - 02/19/12 10:09 PM
Re: Lubegard Red in both cars & my impressions
[Re: Klutch9]
Loc: Midwest
In another thread Trav mentioned using two bottles, so I decided to add a second one. Difference was almost immediate (vs. 50 miles for the first bottle) and shifts smoother still. LG says a second bottle is fine, that you can't OD the stuff.
You can overfill the tranny if not careful. If you top your tranny with the specified ATF and then add 20 oz of LGR, that's almost a quart over capacity. For transmissions that use the newer low viscosity fluids, I don't think aftermarket fluids are needed. The newer low vis fluids have improved anti-oxidants and better friction modifiers and better viscosity index numbers.
"Crisis is the rallying cry of the tyrant." Jame Madison
#2542375 - 02/19/12 10:36 PM
[Re: Klutch9]
Loc: USA
I've had positive results also, great product!
2004 Jeep Grand Cherokee 4.0 I-6 at 109k PYB 10w30 and a FRAM PH3600 2012 KIA Sedona 22k Castrol Edge FST Ti 5w20 Napa Gold
#2542449 - 02/20/12 01:00 AM
[Re: MolaKule]
Loc: Roswell GA
You can overfill the tranny if not careful. If you top your tranny with the specified ATF and then add 20 oz of LGR, that's almost a quart over capacity. For transmissions that use the newer low viscosity fluids, I don't think aftermarket fluids are needed. The newer low vis fluids have improved anti-oxidants and better friction modifiers and better viscosity index numbers. I didn't overfill it. Just drained a bit to compensate each time. I had installed a drain plug on the pan for easier draining. Probably should have clarified that part. I don't know about the better low-viscosity fluid's characteristics, only that in two-for-two the LG made noticeable differences.
#2542555 - 02/20/12 08:11 AM
[Re: Klutch9]
Loc: Oconomowoc Wi
That is a great price from a very good seller... I just purchased from them 4 weeks ago but have not used it yet. Great product that does work.
#2542566 - 02/20/12 08:31 AM
[Re: MolaKule]
Loc: MA, Mittelfranken.de
I have a question maybe you know the answer. With synthetic Dex IV i noticed using a scan tool a temp drop of over 20f consistently when using this product, why is this?
I know quite a few rebuilders and one (family owned high volume shop in business since 1952) in particular has literally cases of this product stacked up, they don't let a unit go out the door without it.
ASE L1, Master. Deutsch Meisterbrief
#2542587 - 02/20/12 08:56 AM
[Re: Klutch9]
Loc: Minnesota
Lots of O'Reilly Auto Parts stores stock it on the shelves. If they don't have it, they usually can get it in a day. That's been my source for 10 oz bottles. Price is up to $10.99 now though. http://www.oreillyauto.com/site/c/search/Trans+Additive/N0444/C0207.oap?mn=Lubegard&mc=LBG
2004 Buick Rendezvous Mobil 1 5w-30 EP, Mobil 1 Filter 2007 Honda Accord - Mobil 1 0w-30 AFE, Mobil 1 Filter
#2542610 - 02/20/12 09:25 AM
[Re: Trav]
Loc: Rochester, MI
I know quite a few rebuilders and one (family owned high volume shop in business since 1952) in particular has literally cases of this product stacked up, they don't let a unit go out the door without it. I'm not sure how it works, but LGR does say right on the bottle that it lowers operating temperatures in the tranny.
'07 Focus 2.0 - 51,xxx mi - Havoline conv 5w-20 '11 Fusion 2.5 "Sterling" - 26,xxx mi - Service Pro blend 5w-20
#2542616 - 02/20/12 09:31 AM
[Re: Klutch9]
Loc: Oconomowoc Wi
I usually use it with Maxlife ATF and will add it within the next week to two vehicles. I changed out the ATF fluid two months ago but was out of LGR...
#2542738 - 02/20/12 12:01 PM
[Re: Trav]
Loc: stl
I know quite a few rebuilders and one (family owned high volume shop in business since 1952) in particular has literally cases of this product stacked up, they don't let a unit go out the door without it. Less slip = less friction = less heat Just my assumption.
#2543473 - 02/21/12 03:42 AM
[Re: Klutch9]
Loc: Rochester NY
Is the new DEXRON ATF called DEX IV or DEX VI?
If it's IV, then I have been refering to it incorrectly!
"The hurrier you are, the behinder you get!"
#2543484 - 02/21/12 04:43 AM
[Re: Klutch9]
Loc: Sunny Florida
DEX VI or DEX 6.
"In a democracy, dissent is an act of faith." J. William Fulbright Best ET-12.79 @ 111 mph 4340 pounds, Street tires Just like we go to Publix
#2543503 - 02/21/12 06:41 AM
[Re: SteveSRT8]
Loc: Rochester NY
Ah, thanks SRT, I glad I wasn't refreing to it incorrectly!
#2544147 - 02/21/12 05:32 PM
[Re: Klutch9]
Loc: Oklahoma
Just changed the fluid & filter in my 1994 Astro van and added 10ozs. of Lubegard red & yes, it make a huge difference in the smoothness of shifting. It has my approval but it could be a combination of new filter, fluid and Lubegard, I'm happy.
#2548199 - 02/25/12 03:32 PM
[Re: 94astro]
formerly tpitcher
Loc: MN
I just drained & put in Lubegard RED with 5 qts Amsoil ATF.
Shifts fantastic!
03 GMC Sierra 4x4 185k PU 00 Saturn SL2 89 YO Lady Car. 56k Miles! PU 97 Camry 185k ML Full Syn 06 GTO Supercharged 6M 500 rwhp/tq. *Amsoil Z-Rod*
#2548260 - 02/25/12 04:33 PM
[Re: Klutch9]
Loc: Michigan
^in the Splat-urn?
2007 Ford Fusion SEL AWD 2006 Mercury Montego Luxury
