Making tacos at home
by Reddy45
07/25/16 12:41 PM
Wiring a new garbage disposal
by Hokiefyd
07/25/16 11:38 AM
Power Steering Fluid
by DWC28
07/25/16 10:07 AM
Troy-Built 4.5hp running problem
by Kestas
07/25/16 09:26 AM
Conventional oil instead of synthetic
by corndogzombie
07/25/16 08:05 AM
kohler courage 15 issues
by tomm22
07/25/16 07:58 AM
Small overlap crash test?
by Huie83
07/25/16 07:39 AM
Top Tier Fuels and Tailpipe deposits
by virginoil
07/25/16 07:20 AM
Honda GX35 question
by dirtydannyd
07/25/16 02:08 AM
Need advices for oil filter inspection
by ST2008
07/25/16 01:45 AM
Supertech- ST3387- Virgin cut open
by FordBroncoVWJeta
07/25/16 01:06 AM
Clean battery with garden hose?
by SavagePatch
07/24/16 11:55 PM
Ken_Clifton, HotDog15, curiousaboutoil, 01CAMRY, corndogzombie
58589 Registered Users
96 registered (Andrei, Al, 182RG, 3Phase, Alfred_B, ABerns, 3 invisible), 1869 Guests and 15 Spiders online.
58589 Members
66 Forums
252230 Topics
#2530501 - 02/09/12 11:33 AM Fuel System Cleaner's and Maintenance Doses.
Lakersguy Offline
Loc: The OC
In a new car, if you run a maintenance dose of letís say Redline S-1 EVERY fill up. Would you ever need to do a full bottle treatment again? In a used car, once you run a full treatment of something like Redline S-1 or Techron, then you run a maintenance dose of letís say Redline S-1 EVERY fill up. Would you ever need to do a full bottle treatment again? I personally do a maintenance dose every fill up with Redline S-1 and every other fill up a maintenance dose of MMO in both my vehicles.
2007 4x4 Lincoln Mark LT
2004 4x4 Lincoln Navigator
#2530517 - 02/09/12 11:47 AM Re: Fuel System Cleaner's and Maintenance Doses. [Re: Lakersguy]
JHZR2 Offline
Loc: New Jersey
Likely not, but it wouldnt really hurt to do a real dose once in a long while, just in case.
I prefer maintenance doses, with the basis that "less is more" as the means of dosing.
I think you are on the right track.
#2530528 - 02/09/12 12:02 PM Re: Fuel System Cleaner's and Maintenance Doses. [Re: Lakersguy]
rjacket Offline
Loc: CA
Yeah maintenance dose is all you should need.
Personally I don't want to have the hassle, so I plan on using Chevron (not just top tier) instead and then putting in cleaner once a year.
#2530582 - 02/09/12 01:03 PM Re: Fuel System Cleaner's and Maintenance Doses. [Re: Lakersguy]
gathermewool Offline
Loc: New England
To answer your question: I don't see any benefit to using a full bottle if you've been adding maintenance doses for an extended period.
I ran a 3-5 oz maintenance dose of SI-1 every fillup in my STI. It got to be too much work, so I'm reverting back to 15 oz every 10-15k or so. It'll be cheaper and I don't think there will be ANY negative effect. I certainly didn't notice any positive effect after using an entire case over nearly a year.
14 Forester XT
PUPPP + Subie blue filter
08 Civic LX (Auto)
VWB 5W-20 + Fram Ultra (3rd OFI)
#2530844 - 02/09/12 05:08 PM Re: Fuel System Cleaner's and Maintenance Doses. [Re: Lakersguy]
Lakersguy Offline
Loc: The OC
This is what i thought but wanted to confirm. It really doesn't bother me putting Maintenance doses in at fill up. It bothers me more creating the doses in my 4oz bottles I use.
Also, the reason for this is I use Costco gas here in So Calif. to save some cents per gallon and get % rebates from American Express on the charges.
#2530848 - 02/09/12 05:13 PM Re: Fuel System Cleaner's and Maintenance Doses. [Re: Lakersguy]
Boss302fan Offline
Loc: Oconomowoc Wi
I run a bottle of Redline at the end of an OCI... Usually every 5K.
John P
Wisconsin
2006 Lexus LS 430
1990 Jaguar XJS V12
2011 Hyundai Santa Fe V6
Other fun cars
#2535503 - 02/13/12 07:16 PM Re: Fuel System Cleaner's and Maintenance Doses. [Re: Lakersguy]
hardcore302 Offline
Loc: Suffolk County, NY
I do a dose of either Gumout Regane or Chevron Techron Every 5k oci with a mmo dose every other fillup or so.
2007 Ford Mustang GT - Motorcraft filter, Castrol GTX SynBlend
2011 Chevy Equinox LT - Driveworks filter, Pennzoil Platinum
