64859 Members
68 Forums
282398 Topics
#2529291 - 02/08/12 09:19 AM
2006 Pontiac Vibe - Amsoil XLF - 9000km
Loc: Mississaga, On
Took a sample to make sure the oil is still fit for use in an extended OCI of this vehicle. New Wix air filter installed with the oil and using a Mann ML1009 full flow oil filter. * = Severity 1
** = Severity 2
Iron 4
Chromium 0
Nickel 0
Aluminum 3
Copper 0
Lead 0
Tin 0
Cadmium 0
Silver 0
Vanadium 0
Silicon 8
Sodium 9
Potassium 0
Titanium 0
Molybdenum 67 **
Antimony 0
Manganese 0
Lithium 0
Boron 121 **
Magnesium 8
Calcium 2249
Barium 0
Phosphorous 655
Zinc 749
Fuel Dilution 2.9%
Vis @100C 9.1 *
TBN 3.26 **
Oxidation 11
Nitration 24
Lube Time 8,884 km
Unit Time 174,999 km
Notes: Flagged data does not indicate an immediate need for maintenance action. Continue to observe the trend and monitor equipment and fluid conditions. FUEL DILUTION is at a MODERATE LEVEL; FUEL DILUTION has caused viscosity to decrease slightly below grade; Total Base Number is MODERATELY LOW; Flagged additive levels are different than what should be present for the lubricant that is identified for this unit. (This does not imply that the lubricant does not meet proper API, SAE, or ISO classifications.); Oil is suitable for continued use. Re-sample in 3,500 miles or 65 hours.
Things look fine to me except for a bit of fuel dilution and some additives that OA isn't aware of in the reformulation of XLF. Going to run it another 5,000-km and sample again to confirm the OCI for this vehicle. We've had a pretty warm winter but there are still cold morning starts. This vehicle drives 100km on the 401 in Toronto every day. I messed up taking the sample from the dipstick and pulled the oil from near the top of the sump instead of the middle. Not sure if that would affect the fuel dilution and viscosity numbers. Cheers, Chris {removed non-site sponsor link}
Edited by Bill in Utah (02/08/12 10:34 AM) Edit Reason: removed non site sponsor link
#2529295 - 02/08/12 09:25 AM
Re: 2006 Pontiac Vibe - Amsoil XLF - 9000km
[Re: Nesser]
Loc: Kitchener, Ontario, Canada
Ya, looks really nice except the fuel, although I think we've seen other Vibe's with fuel. Look forward to the next analysis! Thanx!
Funny I was just looking at the Amsoil website yesterday and concidering trying it. I think my biggest problem is i enjoy changing the oil!
Dodge Charger|Pennzoil Platinum 5w20|Mopar MO-744 Pontiac G6 GT|Mobil 1 0w40|Mobil 1 M1-101
#2529372 - 02/08/12 10:36 AM
[Re: Nesser]
Loc: PA
Looks like my corolla with all that fuel in it.
#2529397 - 02/08/12 10:52 AM
[Re: Nesser]
Loc: Merritt Island FL, USA
Very good wear numbers considering the fuel dilution and thinning. This is a high quality oil. Was the engine oil up to normal operating temp when you took the sample? Thanks for posting.
'12 Charger SXT QSUD 5w30 OEM filter
'12 Charger SXT Edge FST EP 5w30 OEM (Mine;)
'11 Hyundai Sonata GLS QSUD 5w20 OEM Filter
#2529624 - 02/08/12 02:54 PM
[Re: Nesser]
Loc: WA
Maybe I missed it, but is this 5w30?
M_C
2012 Mazda5 Touring 2.5l A/T 2005 Vibe 1.8l AWD 1998 Ranger 2.5l A/T 1978 Honda CB400A (A/T)
#2529976 - 02/08/12 08:37 PM
[Re: chubbs1]
Loc: Mississaga, On
Consolidating a few questions. While I don't mind changing the oil in our vehicles I don't have a covered/protected area to work so that makes me a fair weather mechanic which usually does not include winter. I'm a big fan of the idea of a twice a year oil changes which looks like it may be possible. Was the engine oil up to normal operating temp when you took the sample? I sampled about 10-15 minutes after the car was shut down. It would probably be a good assumption that it was stop and go for some of the 45 minute rush hour commute. Maybe I missed it, but is this 5w30? Sorry, yes this is the mid-range AMSOIL 5W-30 product.
#2530580 - 02/09/12 12:54 PM
[Re: Nesser]
Loc: Canada
The new Amsoil XL is a fantastic oil, I should be in line to do my next UOA in the next four months or so and that one will include two back-to-back XL changes with the RP filter.
I'm considering stepping up to the full synthetic next for the next couple of rounds.
#2530790 - 02/09/12 03:55 PM
[Re: Nesser]
Loc: Vinegar Hill ON
Chris, where does one obtain Mann filters in the Toronto area? And is this particular one the higher capacity filter?
Edited by 21Rouge (02/09/12 04:06 PM)
#2531133 - 02/09/12 09:37 PM
[Re: 21Rouge]
Loc: Canada
Chris, where does one obtain Mann filters in the Toronto area? And is this particular one the higher capacity filter? He probably ordered that from Amsoil as well.
#2531195 - 02/09/12 10:55 PM
[Re: qr25de]
Loc: Mississaga, On
and using a Mann ML1009 full flow oil filter. Chris, where does one obtain Mann filters in the Toronto area? And is this particular one the higher capacity filter? He probably ordered that from Amsoil as well. Correct, ordered from Amsoil. You can talk to Pablo or use the dealer locator to find a local dealer close to you. I'll disclose that I'm a dealer but I do it on the side for fun, not full time. http://www.amsoil.com/locator/I wouldn't say it is high capacity since it looks like every other oil filter I've put on the car, but I'm not sure. There are some specs on the Mann website if it helps you: https://www.mann-hummel.com/mf_prodkata_usa/index.html?ktlg_page=6&prdsl=11009
#2531266 - 02/10/12 01:28 AM
[Re: Nesser]
Loc: WatUpDoc
Lame fuel dilution, otherwise looks good. Only 8 Si for 5,500+ miles or so is good air filtration.
I wonder what soot or insols would be...can the lab test for either?
92 Civic Hatch (stolen  RIP) 07 Honda Fit Sport (A/T) WELCOME
#2531362 - 02/10/12 06:51 AM
[Re: Nesser]
and using a Mann ML1009 full flow oil filter. And is this particular one the higher capacity filter? I wouldn't say it is high capacity since it looks like every other oil filter I've put on the car, but I'm not sure. I wasnt very clear, For my 2005 Vibe with the base 1ZZFE engine I try to buy the higher capacity filter used on the Vibe GT. With this longer filter, the sump (+ filter) takes a 4L jug perfectly. I will go to the Mann site and get the part no. for this larger/longer filter.
Edited by 21Rouge (02/10/12 06:53 AM)
#2531683 - 02/10/12 12:29 PM
[Re: Nesser]
Chris, where does one obtain Mann filters in the Toronto area? Correct, ordered from Amsoil. Can Mann filters also be obtained at traditional auto parts, 'brick and mortar' locations in Ontario?
#2531759 - 02/10/12 01:34 PM
[Re: 21Rouge]
Loc: Duvall WA - Pacific NW USA
Chris, where does one obtain Mann filters in the Toronto area? Correct, ordered from Amsoil. Can Mann filters also be obtained at traditional auto parts, 'brick and mortar' locations in Ontario? How far away is this: Toronto, ON 6625 Tomken Rd Units 12-14 Mississauga, ON L5T 2C2
