Code:
OIL M10w20 uniavg
MILES IN USE 10k 5.4k
MILES 40k
SAMPLE TAKEN 1/24/12
ALUMINUM 7 3
CHROMIUM 0 0
IRON 22 8
COPPER 2 2
LEAD 0 1
TIN 0 1
MOLYBDENUM 146 74
NICKEL 0 0
MANGANESE 0 1
SILVER 0 0
TITANIUM 0 0
POTASSIUM 0 1
BORON 83 40
SILICON 14 14
SODIUM 3 33
CALCIUM 2433 2214
MAGNESIUM 8 85
PHOSPHORUS 820 706
ZINC 826 838
BARIUM 0 0
INSOLUBLES 0.3
WATER 0.0
FLASHPOINT ºF 385
SUS VIS 210ºF 49.1
cSt @ 212ºF 6.99
Fuel % trace
Antifreeze 0.0
TBN 2.6
This was my first UOA for my 2010 Prius. A little background on my car, commute, driving, etc
I got the car in March 2010. I have a 70 mile commute (roundtrip) which is about 80% highway. There is usually about 2-3 miles (each way) where I'm in slow and go traffic. I try to keep my top highway speed at 60 mph or less (scangauge shows RPM's around 1200 +/- 100 depending on speed and wind (assuming fairly level road)).
The car has had a total of 4 oil changes, per Toyota specs. This is the oil that was removed between 30k and 40k. On this particular oil sample, the car was driven from my house to the shop. About 8 minutes over surface streets. It likely waited in their parking lot for about 30 minutes prior to being brought into the garage for its oil change. Thus the engine oil was not fully warmed up, nor was it cold.
I'm not intending on stretching the oil interval past 10k miles. Question is, should I be changing more often? I've driven my last two cars for about 11 years and 200,000 miles each, so I am interested in the long term health of my engine.
Lifetime MPG (calculated) = 59.4 (woot!)
OIL M10w20 uniavg
MILES 40k
ALUMINUM 7 3
CHROMIUM 0 0
IRON 22 8
COPPER 2 2
LEAD 0 1
TIN 0 1
MOLYBDENUM 146 74
NICKEL 0 0
MANGANESE 0 1
SILVER 0 0
TITANIUM 0 0
POTASSIUM 0 1
BORON 83 40
SILICON 14 14
SODIUM 3 33
CALCIUM 2433 2214
MAGNESIUM 8 85
PHOSPHORUS 820 706
ZINC 826 838
BARIUM 0 0
INSOLUBLES 0.3
WATER 0.0
FLASHPOINT ºF 385
SUS VIS 210ºF 49.1
cSt @ 212ºF 6.99
Fuel % trace
Antifreeze 0.0
TBN 2.6
