Fishing reel drag grease
by bernau
16 minutes 11 seconds ago
Sulfated Ash, wt%, ASTM D 874 test questions
by mbacfp
39 minutes 54 seconds ago
HD radio
by 007
51 minutes 21 seconds ago
Front end repair
by possum328
53 minutes 17 seconds ago
Purolator 10111 Red Can
by FordBroncoVWJeta
Today at 03:30 PM
Carquest #R85372, 2013 E-250 van, 4,500k
by car51
Today at 03:03 PM
Strange failure: Starter AND flywheel cogs ripped
by lars11
Today at 02:22 PM
My email from Castrol about Magnatec
by Tech819
Today at 02:13 PM
Audi 5000 / Known Stop-Leak Compatible w/ CHF 7.1?
by Miles07PT
Today at 01:41 PM
Observations on Workplace corrosion
by Vdubuk
Today at 12:15 PM
Oil filter change NIGHTMARE
by MetalSlug
Today at 12:08 PM
First time flushing an 05 Tacoma
by Back40
Today at 11:53 AM
_hashtagusername, larrybroad123, dr_p, CapHead, rowebil
58632 Registered Users
80 registered (2oldtommy, 440Magnum, Al, 97f150, 901Memphis, 8 invisible), 2092 Guests and 11 Spiders online.
58632 Members
66 Forums
252411 Topics
#2507810 - 01/27/12 07:18 PM 5w-30 vs 10w-40
awoess Offline
Loc: Maryland
with my oil pressure fluctuating someone suggested using 10w-40 instaed of 5w-30? is this bad advice? 2005 nissan frontier nismo 6 cylinder
2007 Honda Ridgeline
#2507813 - 01/27/12 07:20 PM Re: 5w-30 vs 10w-40 [Re: awoess]
OVERKILL Offline
Loc: Ontario, Canada
Is this fluctuation observed through a stock gauge or a reliable aftermarket mechanical one?
02 Expedition
06 Charger R/T
14 Charger SRT-8
#2507814 - 01/27/12 07:20 PM Re: 5w-30 vs 10w-40 [Re: awoess]
JRed Offline
Loc: Virginia
Considering that you live in Louisiana it won't make much of a difference.
Go for it, I guess.
Edited by JRed (01/27/12 07:21 PM)
06 Subaru Impreza WRX - Sold. The only mechanical thing I'll ever love.
07 Toyota Prius - Cheap synthetic and PureOne filters.
#2507816 - 01/27/12 07:22 PM Re: 5w-30 vs 10w-40 [Re: awoess]
CATERHAM Online   content
Loc: Burlington, Ontario, Canada
Possibly yes.
OP does of course rise with engine rpm bur at a steady rpm it should be stable.
Under what conditions does it fluctuate?
74 Lotus Europa, 5W-50
86 Porsche 928S, TGMO 0W-20 25% / M1 0W-40 75%
96 BMW 328i, Idemitsu/TGMO 0W-20 70% / M1 0W-40 30%
94 Caterham 7, FUCHS 0W-20
#2507850 - 01/27/12 08:05 PM Re: 5w-30 vs 10w-40 [Re: awoess]
awoess Offline
Loc: Maryland
stock gauge... when i stop at a red light it goes just above the L and goes just above middle when driving? never reaches H level
#2507856 - 01/27/12 08:10 PM Re: 5w-30 vs 10w-40 [Re: awoess]
That just normal oil pressure behaviour.
Stick with the 5W-30 grade oil.
#2507859 - 01/27/12 08:12 PM Re: 5w-30 vs 10w-40 [Re: awoess]
aquariuscsm Offline
Loc: South Texas,USA
10W40 won`t hurt a thing. Is this a VQ? I know the VQ Maxima`s FSM lists anything from 5W30-20W50.
1996 Nissan 300ZX 5-speed,Arctic Pearl(#175 of 300)
Syntec 10W40/Fram Ultra
Amsoil MTG(tranny)
Amsoil 80W90 GL5(rear diff)
Mobil 1 ATF
Redline Water Wetter
#2507938 - 01/27/12 09:16 PM Re: 5w-30 vs 10w-40 [Re: aquariuscsm]
Merkava_4 Offline
Loc: Clovis, CA
What about startup wear? That 10W-40 takes a full 5 minutes to reach all
the bearings on startup, but 5W-30 only takes 2/100ths of a second. grin2
#2508228 - 01/28/12 08:37 AM Re: 5w-30 vs 10w-40 [Re: Merkava_4]
Garak Offline
Loc: Regina, Saskatchewan, Canada
What about startup wear? That 10W-40 takes a full 5 minutes to reach all the bearings on startup, but 5W-30 only takes 2/100ths of a second. grin2
Of course, there's always that issue of immediate, catastrophic wear. wink
Aside from that, while CATERHAM has eloquently stated his case for 10w-30 being an obsolete synthetic grade, I'd argue that 10w-40 is about as obsolete a grade as one could possibly imagine, particularly in conventional. It was terrible oil years ago, and while oil certainly has improved, specifications have changed.
Any vehicles that currently specify a 40 weight oil are either diesels which spec HDEO (10w-40s tend to meet older diesel specs, not modern ones) or European cars, which have their own specifications, which the run of the mill 10w-40 certainly cannot meet. I can't think of any mainstream vehicle currently being sold in North America that would call for 10w-40 as the preferred grade in the manual.
For something well out of warranty that is speced for a 40 weight oil, 10w-40 would be at the bottom of my list of choices, unless it was dirt cheap. Up here at least, 5w-20, 5w-30, and 10w-30 are the grades that go on sale. So, my old truck and the Audi got 15w-40 at a much more attractive price than what 10w-40 goes for.
I know it takes 5 minutes for 10w-40 to reach all the bearings on start up, and probably double that for 15w-40, and maybe triple that north of the border. wink The 15w-40 was cheaper though.
Plain, simple Garak.
2008 Infiniti G37 coupe - Mobil Delvac 1 ESP 5w-40, Wix 51358
1984 F-150 4.9L six - Quaker State GB 10w-30, Wix 51515
#2508608 - 01/28/12 03:23 PM Re: 5w-30 vs 10w-40 [Re: awoess]
mechtech2 Offline
Loc: Chicago Area
It will still fluctuate, but in a different range.
Oils viscosity changes when hot/cold, and different RPM affect the pressure also.
#2508720 - 01/28/12 05:43 PM Re: 5w-30 vs 10w-40 [Re: awoess]
dave1251 Online   happy
Loc: Maricopa, AZ
Does your check engine light come on? If not I suspect you do not have a low oil pressure.
don't use.
#2508733 - 01/28/12 05:57 PM Re: 5w-30 vs 10w-40 [Re: dave1251]
TFB1 Offline
Loc: VA
I'm yet to see a "check engine light"(the amber one operated by the PCM), that was triggered by low oil pressure... A low oil pressure light will be red and operated by a sender that connects directly to the light circuit...
#2508848 - 01/28/12 07:39 PM Re: 5w-30 vs 10w-40 [Re: TFB1]
awoess Offline
Loc: Maryland
my check engine light does NOT come on.... i think i'm over reacting a little bit? thanks for the advice.. i'll stick with 5w-30 Royal Purple
