NAPA Gold oil filters 7060
by ZiTS
8 minutes 16 seconds ago
Collection of VOAs and UOAs
by dccode
26 minutes 17 seconds ago
Monopoly and Innovative
by HTSS_TR
26 minutes 40 seconds ago
Vintage in House Gas Incinerator
by Brybo86
59 minutes 48 seconds ago
2014 f150 5.0 5w20 pup 7200 miles
by robo339
Today at 02:34 PM
Tuff Torq K46 oil question
by BrianF
Today at 02:21 PM
by dccode
Today at 02:00 PM
Fram Ultra XG8A 6800 miles [Cut Open]
by Run
Today at 01:01 PM
Floor jack question
by Donald
Today at 12:51 PM
Philosophy Behind Extended Euro OCIs
by camrydriver111
Today at 12:25 PM
Fuel Economy with Mobil 1 Extended Perfomance
by wolf_06
Today at 12:13 PM
Anybody into Motocross?
by VeeDubb
Today at 11:36 AM
DALpilotMike, Safetyfirst, rwood, USARMOR, GV00
58943 Registered Users
92 registered (4WD, AIRJAC3, 2004tdigls, Alex_V, Atesz792, 9 invisible), 1750 Guests and 8 Spiders online.
58943 Members
66 Forums
253677 Topics
Page 1 of 2 1 2 >
#2498581 - 01/18/12 09:21 PM Chrysler PentaStar V6 specs 5W30... wow!
LoneRanger Offline
Loc: Midwest
I find it oddly refreshing that while many of the new generation engines that are out or are coming out from various manufacturers are specifying thinner oils like 0W20, Chrysler's innovative new 3.6 liter PentaStar V6 uses 5W30 and it doesn't even have to be synthetic, as long as it meets Chrysler MS-6395. Well done, Mopar, well done.
'09 Subaru Forester .........(Quaker State Syn Blend 5W30)
'16 Ducati Multistrada DVT 1200S (Spectro Platinum 15W50)
#2498602 - 01/18/12 09:35 PM Re: Chrysler PentaStar V6 specs 5W30... wow! [Re: LoneRanger]
rjacket Offline
Loc: CA
Don't get it. 5w-20 has been spec'd in conventional for a long time.
#2498613 - 01/18/12 09:39 PM Re: Chrysler PentaStar V6 specs 5W30... wow! [Re: LoneRanger]
daves87rs Offline
Loc: Michigan
Well, with this following Ford's Ecoboost need for 5w30, I'm not surprised...
Whatever you are, be a good one.
#2498633 - 01/18/12 09:56 PM Re: Chrysler PentaStar V6 specs 5W30... wow! [Re: LoneRanger]
chubbs1 Offline
Loc: Merritt Island FL, USA
It is a great engine. I am really surprised by the quality of the parts I can see. It runs as smooth as butter.
'12 Charger SXT
QSUD 5w30 OEM filter
'12 Charger SXT
Edge FST EP 5w30 OEM (Mine;)
'11 Hyundai Sonata GLS
QSUD 5w20 OEM Filter
#2498643 - 01/18/12 10:02 PM Re: Chrysler PentaStar V6 specs 5W30... wow! [Re: LoneRanger]
rjacket Offline
Loc: CA
When I got my Lexus in 2007, it had a 3.5 V6 with virtually the same hp and torque but a 0-60 in 5.7 secs (compared to just over 6 secs for the Pentastar). However, the highway mpg of the Pentastar is significantly better.
It was then spec'd for 5w30.
Now it is spec'd for 0w20, but not back spec'd as far as I know.
In any case, the upgrade of the same engine has kept the performance but improved the highway mpg, but still below the Pentastar.
The Pentastar is clearly a good engine right now especially since it takes regular. Time will tell how good an engine it really is and if it turns out to be something, no doubt they'll spec it for a 20 weight oil conventional or synthetic.
Edited by rjacket (01/18/12 10:03 PM)
#2498644 - 01/18/12 10:03 PM Re: Chrysler PentaStar V6 specs 5W30... wow! [Re: LoneRanger]
sciphi Offline
Loc: Upstate NY
A lot of GM engines spec 5w-30. I'm not shocked either.
2013 Toyota RAV4 XLE
2012 Chevrolet Cruze Eco
#2498670 - 01/18/12 10:22 PM Re: Chrysler PentaStar V6 specs 5W30... wow! [Re: LoneRanger]
morris Offline
Loc: ks, wichita
i might be old so i dont like the new thin oils. i have 2001 Dakota v-6. i use just a little thicker oil than recommended, with no trouble. note its only a little thicker, i DID learn that lesson. i bet my engine will be running fine when yours is in the junk yard, for a while.
#2498753 - 01/18/12 11:32 PM Re: Chrysler PentaStar V6 specs 5W30... wow! [Re: LoneRanger]
rjacket Offline
Loc: CA
Mercedes lets you use 30 weight or 40 weight oil. Within each, there is already a range of thickness at operating temp. The point is, is the oil strong enough to do it's job if it passes certain tests. And the answer is that as technology has improved, yes thinner oil has gotten more capable.
The engineers are in one way no different to those who are against thinner oils. They start with the assumption that the thicker oil has more strength. But from that point on, they differ from the amateur skeptics because they go and run tests to see whether a thinner oil can hold up over hundreds of thousands of miles. So, companies like Ford, Toyota and Honda have all established their engines can take thinner oil.
It's entirely believable that thinner oils are fine because people are always innovating. None of you, even the oldies, are getting their comments on this forum through punch tape and computers with valves are you? There has been something called progress taking place ..........
Edited by rjacket (01/18/12 11:34 PM)
#2498947 - 01/19/12 07:55 AM Re: Chrysler PentaStar V6 specs 5W30... wow! [Re: LoneRanger]
meep Offline
Loc: Southeast
that pentastar can dish out a lot of torque at low revs, which also means lower oil pressure/flow. it may need the slightly heavier oil under those conditions.
I had one in a rental and to be quite honest it was the best-feeling V6 I'd ever driven for a large car. Not peaky like the honda/toyota V6's. more refined than the other domestics. Nice torque early on like the chryco 3.8 but doesn't quit as early. not wheezy like the 3.3 little sister.
never been in to one, though-- the pics look like it is very complicated, whereas the 3.8 is a joy to work on.... simple.
Edited by meep (01/19/12 07:57 AM)
2006 Tundra 2wd
2015 crv (wifey!)
2005 s60 2.4L
#2499040 - 01/19/12 10:14 AM Re: Chrysler PentaStar V6 specs 5W30... wow! [Re: LoneRanger]
Hokiefyd Offline
Loc: Top of Virginia
It's a pretty peaky engine in my dad's Wrangler. Part-throttle shifts at 4-5k RPM aren't uncommon. It's almost never below 2k RPM when driving normally. It acts very much lik the 3.5L V-6 in our Acura really.
Cheers,
Jason
2009 Honda Ridgeline RTL
2005 Acura MDX Touring
#2499139 - 01/19/12 12:15 PM Re: Chrysler PentaStar V6 specs 5W30... wow! [Re: Hokiefyd]
Ursae_Majoris Offline
Loc: South
It is a great engine. Our family minivan passed quite a few slope-pokes in "sports cars" on the highway.
My only issue is the lack of information available about the Chrysler MS-6395 spec. PYB has it, but I am sitting on a good stash of Motul 5w-30 eco-Clean and G-Oil and neither has the spec.
After free oil changes at the dealer are over, am not sure what to do. I do not want to risk losing warranty, but also do not want to put dino in it, since I have synthetic oil on hand.
2011 Chrysler T&C, Dealer bulk fill/, OEM filter
2002 Isuzu Axiom, PureOne, 5w-30 G-Oil
#2499249 - 01/19/12 01:58 PM Re: Chrysler PentaStar V6 specs 5W30... wow! [Re: LoneRanger]
rjundi Offline
Loc: USA
It is a nice engine in the rental I drove.
I hope it turns out to be reliable as its a brand new design.
Chrysler caught up.
#2499558 - 01/19/12 07:22 PM Re: Chrysler PentaStar V6 specs 5W30... wow! [Re: Ursae_Majoris]
silverrat Online   content
Loc: Ontario
I once passed a Viper on the highway in a Corsica.
03 Civic Si(R) - Assembled in Swindon, England
Long Live the Manual Transmission drive
#2501104 - 01/21/12 10:10 AM Re: Chrysler PentaStar V6 specs 5W30... wow! [Re: LoneRanger]
kkreit01 Offline
Loc: Olathe, KS
I too was very surprised -- since my previous Hemi spec'd 5w20. I plan to do my first OCI on the Jeep this weekend. I have some Chevron Supreme (Costco sale), and a Wix cartridge filter waiting in the garage. My next 2 OCIs will be freebies at the dealer. (I had to sneak one in at ~1700 mi smile )
Edited by kkreit01 (01/21/12 10:11 AM)
2014 Dodge Durango Limited AWD 3.6: 5w20 PU/Napa Gold filter
2015 Lincoln MKC Fwd 2.0EB: 5w30 PP/Motorcraft filter
#2501417 - 01/21/12 04:05 PM Re: Chrysler PentaStar V6 specs 5W30... wow! [Re: LoneRanger]
Ken2 Offline
Loc: Washington St.
The size of the bearing that carries the load is one important part of the calculation. A larger bearing for the same load can use lighter oil. If the engine layout requires smaller bearings, stronger oil film is needed, and higher viscosity is one way to get that. The very large diesel engines put 7500hp into each rod bearing using 30 wt oil. The bearings are big enough to spread the load and the bearings live for many years.
Every gun that is made, every warship launched..a theft from those who hunger and are not fed, those who are cold and not clothed.
Gen. Eisenhower
Page 1 of 2 1 2 >
