Peppers: do you grow them?
by car51
07/24/16 07:29 AM
Havoline conventional $2.99 at Rural King
by car51
07/24/16 06:35 AM
killing weeds without poisoning well
by oilboy123
07/24/16 01:27 AM
1999 ford expedition factory mercon v synthetic??
by merconvvv
07/23/16 11:40 PM
Buick 3800 - "Von Voyage" oil change?
by Alex_V
07/23/16 10:41 PM
Low oil level light on, but level not THAT low....
by gregk24
07/23/16 10:26 PM
Is SuperLube syn multi grease universal
by NattyBoh
07/23/16 10:05 PM
How come discount tire doesn't use jack stands?
by motor_oil_madman
07/23/16 09:41 PM
SAFETY ?: ramps in rear and jack stands in front
by SavagePatch
07/23/16 09:03 PM
Pennzoil ultra 5w30 back in stock at Walmart.com
by kohnen
07/23/16 08:37 PM
Homelite weedeater not getting fuel
by Drew99GT
07/23/16 08:26 PM
Stability issue on 2015 F250
by Donald
07/23/16 07:25 PM
Matt_P, tpragski, 182RG, BillHuang, jwilliamson185
58578 Registered Users
64 registered (Al, 182RG, Alex_V, 2015_PSD, AEHaas, 4WD, 7 invisible), 1074 Guests and 14 Spiders online.
58578 Members
66 Forums
252176 Topics
#2490420 - 01/11/12 04:42 PM Coolant flow direction through Thermostat ?
HTSS_TR Offline
Loc: Lake Forest, CA
I had Mercury tracer's thermostat replaced a month ago. I don't know if I install it correctly or not, it may be upside down.
From this picture, coolant should flow from bottom up or top down from engine to radiator ?
Which side should be facing the engine ? bottom or top ?
Currently the bottom is facing the engine, and coolant temperature is colder than usual and no heat, the coolant temperature gauge is very low even after 8-10 miles drive. Ambient temperature in So Cal is about mid 60's to mid 70's the last 3-4 weeks, some day last week it was mid to high 80's.
The coolant was at normal range after the new thermostat, Stant 13829, was installed a month ago but only for 30-45 minutes, after that short period of time the coolant was always at minimum range.
Either I didn't install it correctly or the Stant failed in less than 1 hour of use.
'00 MB E430
'04 Honda S2000
'06 Volvo V70
'14 Honda Accord LX
"Throwing food away is like stealing it from the poor and hungry" Pope Francis
#2490429 - 01/11/12 04:49 PM Re: Coolant flow direction through Thermostat ? [Re: HTSS_TR]
NHGUY Offline
Loc: USA
The pellet is in the bottom,and thats whats supposed to get hot,so yes the bottom is toward the engine.
#2490446 - 01/11/12 05:00 PM Re: Coolant flow direction through Thermostat ? [Re: HTSS_TR]
mechtech2 Offline
Loc: Chicago Area
Either carefully test that part, or get a new one. The best you can find.
Also, there may be an air pocket that has to be worked out. But after a month, this should have fixed itself.
#2490448 - 01/11/12 05:01 PM Re: Coolant flow direction through Thermostat ? [Re: HTSS_TR]
HTSS_TR Offline
I found this on http://www.crankshaftcoalition.com/wiki/THERMOSTATS_EXPLAINED
"Install the new thermostat so the copper heat sensing element is toward the engine. If installed upside down, it won’t open."
Where is the "copper heat sensing element" on this Thermostat. bottom or top ?
'00 MB E430
'04 Honda S2000
'06 Volvo V70
'14 Honda Accord LX
#2490455 - 01/11/12 05:05 PM Re: Coolant flow direction through Thermostat ? [Re: mechtech2]
HTSS_TR Offline
So you think that I had the bottom of the stat facing the engine is correct ?
If that is the case I just go get a new "Super Stant".
'00 MB E430
'04 Honda S2000
'06 Volvo V70
'14 Honda Accord LX
#2490463 - 01/11/12 05:09 PM Re: Coolant flow direction through Thermostat ? [Re: HTSS_TR]
MNgopher Offline
Loc: Lakeville, MN
If you installed it backwards, you'd likely be overheating, not over cooling.
Sounds like a bad one out of the box. I gave up with the last two super stants I had - both failed to close after opening. Went with an OEM stat, and its worked fine. (That was on my Jeep).
#2490565 - 01/11/12 06:52 PM Re: Coolant flow direction through Thermostat ? [Re: HTSS_TR]
Chris142 Offline
Loc: apple valley, ca
Spring in the engine.
02 Wrangler super-s 10w30
87 F250 delo 15w40
04 Tahoe super-s 5w30
Z400 Lucas 10w30
KLR250 Maxima 10w40
Can am maveric delo 5w40
#2490748 - 01/11/12 09:58 PM Re: Coolant flow direction through Thermostat ? [Re: HTSS_TR]
The_Eric Offline
Loc: Iowa
Chalk it up to a lesson learned... Go to the Ford dealer and buy a Motorcraft stat and be done.
2005 Lincoln Aviator 4.6 DOHC
2000 Honda Accord 2.3
2001 Hyundai Elantra 2.0
1979 Ford F-150 351M
#2490769 - 01/11/12 10:28 PM Re: Coolant flow direction through Thermostat ? [Re: HTSS_TR]
edwardh1 Online   content
Loc: Coastal South Carolina
many oem stats have a small air bleed hole in them. I bought a non oem and put in a very very small hole myself.
I know women who are always late, they do not allow travel time, they think like Star trek, you leave one place and materialize somewhere else.
#2490777 - 01/11/12 10:44 PM Re: Coolant flow direction through Thermostat ? [Re: HTSS_TR]
HTSS_TR Offline
The other cars had original OEM thermostat, except LS400 had Stant thermostat and upper radiator hose installed about couple years ago after 250k miles, that Stant thermostat in the LS400 works as well as OEM so far. The coolant is at normal operating temperature after less than 2 miles city drive in the morning, and the heat at maximum setting is extra hot.
When I changed the thermostat in the Tracer, because engine ran cold for about 2-3 weeks, the old one was (original OEM stat?) broken to 3 pieces. I plugged them out without looking at the orientation.
I think MNgopher is correct, if I installed it backwards, it likely be overheating, not overcooling.
I'll remove the Stant thermostat and take it back to Pep Boys to see if they will replace it or not, I still box and have receipt that I bought about a month ago. If they don't exchange it for a new one I'll stop by Ford dealer get the OEM.
'00 MB E430
'04 Honda S2000
'06 Volvo V70
'14 Honda Accord LX
#2490976 - 01/12/12 08:39 AM Re: Coolant flow direction through Thermostat ? [Re: HTSS_TR]
Eddie Online   happy
Loc: Florida, Cape Coral
Agree with getting an OEM stat. I have bought many, many stats over the 50 years I've worked on engines. OEM stats are good because dealers & mechanics don't like to do the same job over without pay.
CX5 Touring 2.5L :-)
#2491297 - 01/12/12 01:45 PM Re: Coolant flow direction through Thermostat ? [Re: The_Eric]
oldmaninsc Offline
Loc: California
That's not always foolproof. I recently installed a Motorcraft thermostat in my Mercury and it is running colder than normal - especially downhill. Funny but the older superstant didn't do this. I only changed the thermostat because I was doing coolant system maintenance.
BTW - anyone know who makes the Motorcraft thermostat? It sure looks very close to the superstant plus I heard on another forum that it was Stant (but don't know it for a fact). This is about the third bad Motorcraft I've had in the last 10 years that was bad out of the box.
Edited by oldmaninsc (01/12/12 01:46 PM)
2013 Chevrolet Impala LT
2004 Mercury Grand Marquis LS
2005 Toyota Camry LE
1998 Ford F-150 XLT
#2491776 - 01/12/12 08:41 PM Re: Coolant flow direction through Thermostat ? [Re: oldmaninsc]
The_Eric Offline
Loc: Iowa
Interesting observation. So far, my personal and professional experiences have been that OEM works best. Quicker warm-ups, more consistent at temps and correct temps. In some cases, the aftermarket part is not built anywhere near as "heavy duty" as OEM, most seen in Asian applications. The most glaring difference was on a Mitsubishi Montero.
Says my parts guy best friend, Motorcraft is made by a low bidding contractor, like AC Delco. I can neither confirm, nor deny it, but have no reason to doubt. I can say that low bidder or not, see my above statement.
#2491789 - 01/12/12 08:58 PM Re: Coolant flow direction through Thermostat ? [Re: HTSS_TR]
johnsmellsalot Offline
Loc: Texas
On my car, the spring faces the engine. The coolant always enters the radiator through the upper radiator hose and exits the radiator through the lower radiator hose. With that on mind, you can kinda tell which way the coolant flows.
1999 Buick Century 180,000 miles (first car)
2008 Chrysler PT Cruiser 70,000 miles
#2492450 - 01/13/12 03:31 PM Re: Coolant flow direction through Thermostat ? [Re: HTSS_TR]
SteveSRT8 Offline
Loc: Sunny Florida
That would be opposite my GMC trucks which all flow backwards!
Platform dependent advice, be careful.
"In a democracy, dissent is an act of faith."
J. William Fulbright
Best ET-12.79 @ 111 mph
4340 pounds, Street tires
Just like we go to Publix
