05 Odyssey - about 2500 miles - 4 months in use
...just wanted to change it out, cut it open. I replaced it with a SuperTech (Champion non E Core) I had in the stash. Anywayz, I thought you guys might want to see.
Tight Pleats - That junk on the middle top and a little to the right was from opening the can.
The crimped seam and wide pleats. Sorry it's is a little foggy.
Spring and valve
And the inside of the can. Notice the marks on the side from my FilterMag catching garbage.
Not too keen on the wide gaps on one side with it tight on the other.
Just my 2 cents anyway.
Spring and valve
