2016 Volkswagen Tiguan Oil filter - Weird Design?
by FordBroncoVWJeta
07/26/16 02:21 AM
New old ride
by SEBZX79
07/25/16 11:25 PM
Motor Trend Visit with Valvoline
by tenderloin
07/25/16 10:46 PM
Fixing Tractors a no-no, Are cars next?
by user52165
07/25/16 10:38 PM
Cosmetic only or replace
by ram_man
07/25/16 09:55 PM
Wooden Motorcycle Piston from Vietnam
by KeithS_NW_Ohio
07/25/16 09:49 PM
Castrol Edge for hard-driven turbo + DI
by Atomic
07/25/16 09:27 PM
2001 Camry LE V6 - Synthetic ATF Recommendation
by 01CAMRY
07/25/16 08:39 PM
Delo 400?
by Sealbilly
07/25/16 07:17 PM
Noob question about chain maintenance
by JeepWJ19
07/25/16 07:00 PM
Rural King Full Synthetic Oil Sale...
by AnthemBassMan
07/25/16 05:16 PM
Mobil 1 EP oil filter - Cross Reference
by Kung_Faux
07/25/16 05:08 PM
rfabrocini, Tobin28, r0k, KNA, Roanoke6370
58598 Registered Users
16 registered (curiousaboutoil, david_ES2, FordBroncoVWJeta, car51, DeanLutz72, Beria, 2 invisible), 841 Guests and 15 Spiders online.
58598 Members
66 Forums
252250 Topics
#2479716 - 01/01/12 09:06 PM Oil Viscosity vs. Oil Pressure
blackdiamond Offline
Loc: Western Washington
What connection is there between oil viscosity and oil pressure? The engine in question is a 20r/22r hybrid that is driven like a race car. The owner indicated that 20w-50 wasn't cutting the mustard and the reason was that it wouldn't hold oil pressure at high rpm. At some point it seems that the oil pump wouldn't be able to keep up with the higher viscosity.
Any thoughts?
1989 Toyota 4Runner / 5w-30 Valvoline Maxlife
2004 Toyota Sequoia / 5w-30 Mobile 1 EP
2008 Honda Civic / 0w-20 Mobil 1 EP
#2479721 - 01/01/12 09:11 PM Re: Oil Viscosity vs. Oil Pressure [Re: blackdiamond]
GMorg Offline
Loc: Mizzou-land
Exactly what does "hold oil pressure" mean in this context? Are you saying that oil pressure would not continue to rise or that oil pressure would actually drop at high RPM?
#2479746 - 01/01/12 09:37 PM Re: Oil Viscosity vs. Oil Pressure [Re: blackdiamond]
AITG Offline
Loc: USA
On a theoretical level, pressure is the result of resistance to flow. Thinner fluids flow more easily, therefore less pressure is required to move them. Larger clearances result in less resistance, therefore less pressure will be required to move a given volume in a given time.
Practically, thicker fluids may result in more pressure but less flow. Worn components result in lower pressures but increased flow.
AFA the racer is concerned: I have no idea what he was getting at - sorry.
#2479760 - 01/01/12 09:50 PM Re: Oil Viscosity vs. Oil Pressure [Re: blackdiamond]
sm00thpapa Offline
Loc: Spring Hill, FL
16 Sonata Sport
16 Elantra SE
09 FZ6R
04 Ascender
96 Cavalier
#2479778 - 01/01/12 10:09 PM Re: Oil Viscosity vs. Oil Pressure [Re: sm00thpapa]
ltslimjim Offline
Loc: WatUpDoc
Originally Posted By: sm00thpapa
thumbsup
92 Civic Hatch (stolen frown RIP)
07 Honda Fit Sport (A/T) WELCOME thumbsup
#2479963 - 01/02/12 07:08 AM Re: Oil Viscosity vs. Oil Pressure [Re: blackdiamond]
AEHaas Offline
Loc: Sarasota, Florida
One reason may be that the oil pump bypass pressure is set too low for your application / oil grade combination.
The later chapters below may illustrate the issue:
http://ferrarichat.com/forum/faq.php?faq=new_faq_item#faq_haas_articles
Original (but edited by others) version:
http://www.bobistheoilguy.com/motor-oil-101/
aehaas
Machine Guns.
Sarasota Home Inspections.
#2480335 - 01/02/12 02:45 PM Re: Oil Viscosity vs. Oil Pressure [Re: blackdiamond]
mechtech2 Offline
Loc: Chicago Area
It could be too much heat, which can require a thicker oil to keep the pressure up.
But if an engine needs more than a 50 [which you have], it is extreme, for sure.
#2480555 - 01/02/12 05:52 PM Re: Oil Viscosity vs. Oil Pressure [Re: blackdiamond]
aquariuscsm Offline
Loc: South Texas,USA
If you need a thicker than 20W50,there`s always a mono grade 50 or 60.
1996 Nissan 300ZX 5-speed,Arctic Pearl(#175 of 300)
Syntec 10W40/Fram Ultra
Amsoil MTG(tranny)
Amsoil 80W90 GL5(rear diff)
Mobil 1 ATF
Redline Water Wetter
#2481135 - 01/03/12 10:04 AM Re: Oil Viscosity vs. Oil Pressure [Re: blackdiamond]
A_Harman Offline
Loc: Michigan
Any thoughts?
Maybe the 20w50 is TOO thick. The higher viscosity oil will drain back to the pan more slowly than a 5w30, making it more likely that the pickup will starve for oil during hard acceleration or cornering. How much oil pressure is it maintaining at high rpm? Under what driving conditions is the oil pressure dropping?
1985 Z51 Corvette track car
2002 Camaro Z28 LS1/6-speed
2001 Dodge Ram 2500 diesel
1972 GMC 1500 shortbed project truck
