Abnormal Styling ?
by HTSS_TR
05/06/16 07:22 PM
It's that time again.... Ford front-end stuff
by OVERKILL
05/06/16 07:03 PM
Addicts using anti-diarrhea medication to get high
by Mr Nice
05/06/16 06:36 PM
PureOne PL24011 cut open
by AuthorEditor
05/06/16 06:21 PM
Hidden gem for ex-K&N Filter users
by Reddy45
05/06/16 05:54 PM
Chemical Guys Car Wash 1 Gal $13 Amazon
by gallydif
05/06/16 05:43 PM
2006 Charger - rack getting replaced
by OVERKILL
05/06/16 05:38 PM
A Story Worth Living
by LoneRanger
05/06/16 05:37 PM
Snake Oil Detergent - 0.37 Cents
by Greg L
05/06/16 04:35 PM
Wax for silver car
by 007
05/06/16 04:32 PM
Trump's empty picture frames
by SumpChump
05/06/16 04:05 PM
Is 0w40 slightly Thicker than 5w30?
by Greg L
05/06/16 03:53 PM
waldawg, Defcon, drivingaford, funkyheff, Ralph62
57814 Registered Users
86 registered (aquariuscsm, Astro_Guy, 2015_PSD, Al, 137_Trenton, 9 invisible), 0 Guests and 1 Spider online.
57814 Members
66 Forums
248563 Topics
#2478527 - 12/31/11 04:32 PM type f and type fa?
pjc360 Offline
Loc: montana
I was in my local car quest today, and i noticed that the car quest house brand type f transmission fluid is called car quest type fa transmission fluid, and right next to it is the valvoline brand that says valvoline type f.
Is there a difference between type f atf and type fa atf? if so whats the difference between the two if any difference?
#2478553 - 12/31/11 05:02 PM Re: type f and type fa? [Re: pjc360]
chubbs1 Offline
Loc: Merritt Island FL, USA
They are compatible fluids, type F/A has extra FM's for some older ford transmissions. I would get the Valvoline type F unless you have a classic car and need F/A, though it won't hurt your vehicle. What are you putting it in?
'12 Charger SXT
QSUD 5w30 OEM filter
'12 Charger SXT
Edge FST EP 5w30 OEM (Mine;)
'11 Hyundai Sonata GLS
QSUD 5w20 OEM Filter
#2478556 - 12/31/11 05:05 PM Re: type f and type fa? [Re: pjc360]
Pablo Offline
Loc: Duvall WA - Pacific NW USA
They are one and the same. It's interesting that Valvoline makes the Type FA, or used to. Now it's Car Quest type FA.
http://www.yakolda.com/assets/eng/pdf_pisheets/ATFtypeFA.pdf
http://www.i-car.com/pdf/advantage/online/2007/062507_ATF.pdf
#2478557 - 12/31/11 05:06 PM Re: type f and type fa? [Re: pjc360]
pjc360 Offline
Loc: montana
It's going to be going into a non lock up chrysler A-518 transmission in a 1991 dodge ram half ton short bed 4x4.
I just had the transmission re-built in september and was told to flush all the atf out of it and change the filter after 1000 miles, i've got 675 miles on it right now.
#2478558 - 12/31/11 05:08 PM Re: type f and type fa? [Re: pjc360]
pjc360 Offline
Loc: montana
so will i want the fa with the extra friction modifyers or just the regular type f? i will be having a transgo stage 2 shift kit installed soon as well, and i'm going to nhave them increase the line pressure 1 full revolution.
#2478560 - 12/31/11 05:09 PM Re: type f and type fa? [Re: chubbs1]
Pablo Offline
Is that true? Valvoline clearly states their FA has no FM's.
#2478913 - 01/01/12 01:29 AM Re: type f and type fa? [Re: pjc360]
pjc360 Offline
Loc: montana
ya, thats what i thought also, if type fa has some friction modifyers in it then i'll most likey run the reg type f, i was thinking that maybe they were the same but i wasnt sure? all i know is i was told i'd have better performing shifts with type f and lower transmission tempatures in my overdrive torqueflight, the A-518, and my converter is a non lock up converter so i dont have a converter clutch to worry about.
#2479374 - 01/01/12 03:10 PM Re: type f and type fa? [Re: pjc360]
mechtech2 Offline
Loc: Chicago Area
A type F fluid has no slippery friction modifiers.
This is why guys use it for better clutch and band engagement.
#2479499 - 01/01/12 05:35 PM Re: type f and type fa? [Re: pjc360]
pjc360 Offline
Loc: montana
yup, thats why i wanna use it.
#2480896 - 01/02/12 11:06 PM Re: type f and type fa? [Re: pjc360]
EricF Offline
Loc: SF Bay Area
I have 5qts of valvoline type fa, and I've been using it in my p/s units in both Ford's, so far.. so good.
1993 Ford Ranger XLT 4.0L 4x4 (240k) 5W-30 Synpower
2006 Saturn Relay-3 3.5L (85k) 5W-30 Synpower
2012 Ford Fusion SE 2.5L (39k) 5W20 M/C Semi Syn
