Windstar 2001 AC Low and High pressure reading
by pinjc
07/27/16 09:28 PM
Vacuum Pump Oil for rotary vane pumps.
by bunnspecial
07/27/16 09:22 PM
ST dino oil realistic OCI
by OILGEEK27
07/27/16 09:06 PM
Gas grills
by RN89
07/27/16 08:43 PM
Supercharged Subaru BRZ
by clinebarger
07/27/16 07:52 PM
Side can opener ?
by ST2008
07/27/16 07:48 PM
Pennsoil ULTRA not available
by JXW
07/27/16 07:41 PM
2005 Civic randomly stalls when taking off from a
by Avery4
07/27/16 07:36 PM
2003 Saturn L200 oil choice
by car51
07/27/16 07:30 PM
Good hour meter for small engines?
by motor_oil_madman
07/27/16 07:07 PM
2001 Chevy S10 V6 misfire...
by Blang
07/27/16 07:02 PM
Oil level and rpm
by mjoekingz28
07/27/16 06:59 PM
donsladek, rummy, OILGEEK27, pinjc, Lee_C
58627 Registered Users
29 registered (Brad_C, Chewie, carlprop, ajchien, bvance554, Bachuka, 2 invisible), 926 Guests and 9 Spiders online.
58627 Members
66 Forums
252339 Topics
Page 1 of 4 1 2 3 4 >
#2473547 - 12/26/11 09:07 PM Liqui Moly Mos2 additive.
toyota62 Offline
Loc: Australia
Hi.
I just installed Liqui Moly Mos2 engine oil additive in my Hyundai Elantra.Very happy with the results.
Someone has told me Mos2 additive can create 'Sulfuric acid' .
Is this true? How long i can left Mos2 additive in my engine? I am planing to do 1year/15000km oil change with castrol edge 5w-30 ACEA C3,API SN rated engine oil.
Thanks in advance.
Bob.
Bob.
AIAME
2012 Rav4 Mobil1 EP 0w-20
2016 c250 diesel Mobil1 0w-40
#2473562 - 12/26/11 09:19 PM Re: Liqui Moly Mos2 additive. [Re: toyota62]
JHZR2 Offline
Loc: New Jersey
really the only way to see is if you have abnormal TBN loss via UOA testing. It would be specific to your driving style and profile.
#2473645 - 12/26/11 10:42 PM Re: Liqui Moly Mos2 additive. [Re: toyota62]
chubbs1 Offline
Loc: Merritt Island FL, USA
+1
stylin' and profilin'.
'12 Charger SXT
QSUD 5w30 OEM filter
'12 Charger SXT
Edge FST EP 5w30 OEM (Mine;)
'11 Hyundai Sonata GLS
QSUD 5w20 OEM Filter
#2473651 - 12/26/11 10:51 PM Re: Liqui Moly Mos2 additive. [Re: toyota62]
panthermike Offline
Loc: Phoenix, AZ
All UOA's i've seen with Mos2 seem to have normal TBN numbers, but as mentioned above, testing your specific vehicle is the best idea.
'16 Ram Sport 1500;PP 5w20 2K
'15 Lincoln MKC; MC 5w30 24K
'77 F250 "Ol Yeller"; Kendall/Mos2
'98 ES300; ML/Biotech 206K
#2473745 - 12/27/11 02:55 AM Re: Liqui Moly Mos2 additive. [Re: toyota62]
toyota62 Offline
Loc: Australia
if i shorten the oil change interval in to 6months would that be ok?
Bob.
AIAME
#2473769 - 12/27/11 06:01 AM Re: Liqui Moly Mos2 additive. [Re: toyota62]
toyota62 Offline
Loc: Australia
Dear Mr. Bob,
thank you very much for contacting us and your interest in our LIQUI MOLY
products.
MoS2 is a solid lubricant that creates no sulfid acids. There is absolutely
no problem to do oil range intervalls of 12 months / 15.000 km with MoS2 in
the engine oil.
We hope we could help you with our informations. Should you have further
questions regarding our products we would be very pleased to get contacted
from you again.
Best Regards
i. A.
Steffen Niemietz
Anwendungstechniker
application engineer
Bob.
AIAME
#2473770 - 12/27/11 06:01 AM Re: Liqui Moly Mos2 additive. [Re: toyota62]
toyota62 Offline
Loc: Australia
Sweet...........
Bob.
AIAME
#2474025 - 12/27/11 11:28 AM Re: Liqui Moly Mos2 additive. [Re: toyota62]
panthermike Offline
Loc: Phoenix, AZ
Well there you go. As I mentioned before, I've never seen a significant TBN drop with Mos2. I run Mos2 in all of the cars at my normal OCI's.
#2474395 - 12/27/11 05:15 PM Re: Liqui Moly Mos2 additive. [Re: toyota62]
toyota62 Offline
Loc: Australia
Hi Panthermike.
You were spot on.
Bob.
AIAME
#2474889 - 12/27/11 11:45 PM Re: Liqui Moly Mos2 additive. [Re: toyota62]
mechtech2 Offline
Loc: Chicago Area
Also remember that Lubo Moly has significant boron in it.
#2474904 - 12/28/11 12:33 AM Re: Liqui Moly Mos2 additive. [Re: panthermike]
HTSS_TR Offline
Loc: Lake Forest, CA
If I don't have more than 6-7 pints VSOT(Valvoline Synpower Oil Treament) I would use MOS2 in all my cars too.
'00 MB E430
'04 Honda S2000
'06 Volvo V70
'14 Honda Accord LX
"Throwing food away is like stealing it from the poor and hungry" Pope Francis
#2490774 - 01/11/12 10:36 PM Re: Liqui Moly Mos2 additive. [Re: toyota62]
morris Offline
Loc: ks, wichita
the 'Sulfuric acid' cant be made if there is no water in the oil, most acids are water based. if the vent system works right you should not have much water in the engine. course you still have to change oil on time.
#2491588 - 01/12/12 06:09 PM Re: Liqui Moly Mos2 additive. [Re: toyota62]
k24a4 Offline
Loc: MA
here is a uoa I did last Fall with 1 can MOS2 added to 4.5 qts PYB 5w-20 and the TBN was 4.7 after 6200 miles:
http://www.bobistheoilguy.com/forums/ubb...032#Post2397032
Show the world you give a shift! Save the manuals!
'04 Accord I4 EX 5-MT 159600mi PU 5w-20 SM P1
'93 Miata 5-MT 122450mi PPP SN 5w-30 P1
#2491639 - 01/12/12 06:51 PM Re: Liqui Moly Mos2 additive. [Re: toyota62]
zyxelenator Offline
Loc: Louisville,KY
Here is mine http://www.bobistheoilguy.com/forums/ubb...317#Post2425317
Not the best, but car had engine poped open prior that OCI, valve cover gaskets changed, sludge cleaned from top end,Kreen piston soak.
That Oci had Maxlife + Delvac top offs and AutoRX added+MoS2.
99 Camry V6, 5 speed M/T
148k miles.Current fill:5w-30 G-oil,OVERSIZE P1, some Kreen and Ceratec added.
Lubro Moly 75w90 synthetic hypoid oil,with Moly
#2493024 - 01/14/12 04:40 AM Re: Liqui Moly Mos2 additive. [Re: toyota62]
toyota62 Offline
Loc: Australia
Bob.
AIAME
