2015 dodge journey crossroad
by hardcore302
Today at 10:17 PM
Looking for new mechanical pencil
by Merkava_4
Today at 09:33 PM
Sewer gasses in bathroom
by sxg6
Today at 09:13 PM
I am a idiot, a fool or what? UOA coming soon!
by Vern_in_IL
Today at 08:57 PM
4ft LED T8 replacement bulbs 6.97$
by Rand
Today at 08:35 PM
Low cost sedan looks better than expensive one
by HTSS_TR
Today at 08:22 PM
Toyota red in motorcycles/snowmobi
les
by Altydoc
Today at 07:42 PM
Looking at some old posts
by Oldmoparguy1
Today at 07:35 PM
Towing a heavy trailer
by Donald
Today at 07:31 PM
Envelope Budget System
by GMFan
Today at 06:37 PM
Saving OPE after a flood?
by Geauxtiger
Today at 06:18 PM
Late 80s/early 90s oil tech
by Pepsibottle1
Today at 06:08 PM
Bigford545, FWR132, smancer, FJCurious, kburns
58899 Registered Users
48 registered (4WD, BlueOvalFitter, BrianF, AntsinmyEyes, austinlunsford, bdcardinal, 5 invisible), 1079 Guests and 6 Spiders online.
58899 Members
66 Forums
253476 Topics
Page 1 of 5 1 2 3 4 5 >
#2463087 - 12/15/11 05:06 AM MOS2 Additive
jayschrodter Offline
Loc: Australia
Hi there guys,
Just thought I would let you know my experience with this oil additive. I put 250ml in my Audi Quattro and felt a difference. The most noticeable effect is the reduction in engine braking, it seems to coast far longer (which I suppose is how the would formulate their claim for friction reduction?). Power has increased slightly maybe by 2-3%. Also requires less throttle input for climbing hills and cruising about. Put approx 20ml in with the central hydraulik fluid (steering/brake boost) and it has stopped the majority of the pump noise, and the pump no longer groans..
I didn't service it or change any variables, just curious if other people have had similar results?
The brand I used was Liqui Moly.
BTW - Do these additives reduce compression?
Edited by jayschrodter (12/15/11 05:08 AM)
#2463179 - 12/15/11 08:40 AM Re: MOS2 Additive [Re: jayschrodter]
Clevy Offline
Loc: Saskatoon canada
I buy that stuff by the case. Every gas powered piece of equipment I own plus my Harley ,mustang and truck get it too. In an industry filled with snake oil tjat stuff isn't.
2006 Charger RT
Miles x 2 per oil filter
#2463216 - 12/15/11 09:26 AM Re: MOS2 Additive [Re: jayschrodter]
nicholas Offline
Loc: ottawa
I have used - molyslip with very positive results -
use in the snow-blower was the most noticeable
MOS2=good stuff
#2463246 - 12/15/11 10:11 AM Re: MOS2 Additive [Re: jayschrodter]
ARCOgraphite Offline
Loc: N.H, U.S.A.
The mos2 shouldnt affect engine braking unless its killing your ring seal. Moly is nice in an engine but mos2 will kill tBN faster due to acids formation. Just dont overdose, I would 50% underdose.
Edited by ARCOgraphite (12/15/11 10:12 AM)
2014 Nissan Rogue S CVT, OC#4 19671mi-Castrol EDGE EP 5W30+Nissan 15208-9E01A Filter
2015 Forester 6MT 5Door, OC#6 41243mi-M1EP 0W20+Subaru Filter
#2463264 - 12/15/11 10:43 AM Re: MOS2 Additive [Re: jayschrodter]
JHZR2 Offline
Loc: New Jersey
See my threads about MoS2. You cant tell 2-3% power. All sorts of other variables, including temperature could have effected the results of what you claim.
I will agree that the throttle can be used slightly lighter, but in practice, I have not seen any MPG improvements over pre-MoS2 use (I manually log each tank).
It is good stuff, will see the long term effects next UOA.
#2463422 - 12/15/11 01:25 PM Re: MOS2 Additive [Re: jayschrodter]
mechtech2 Offline
Loc: Chicago Area
I have had Lubro Moly in so long that my comparisons are numbed.
But initially, the idle was smoother and there was more perceived pep.
#2464091 - 12/15/11 11:53 PM Re: MOS2 Additive [Re: ARCOgraphite]
Loc: Australia
Thanks for the input guys.
Could be reducing ring seal, bottom end to mid-range seems the same, definitely a bit more from 4K - 7.5K rpm.
@ JHZ2, I can definitely see what your saying this was just my opinion from my experience that's all. I've given feedback on driving 2 stroke racing engines for the past 8 yrs, so to me I feel like I can notice any characteristic differences.
Ill have to compression check the engine to see if their is any change from last time it was checked.
#2464115 - 12/16/11 12:55 AM Re: MOS2 Additive [Re: jayschrodter]
ltslimjim Offline
Loc: WatUpDoc
I have an idea going forward with my current OCI. I plan to add a correct MoS2 dosage after the initial 1,000 miles into this OCI, with the idea of it being in there after the cleansing package does most of it's work. Take it up to 7,500 and sample.
92 Civic Hatch (stolen frown RIP)
07 Honda Fit Sport (A/T) WELCOME thumbsup
#2471002 - 12/23/11 10:14 AM Re: MOS2 Additive [Re: jayschrodter]
MichaelTiger Offline
Loc: Belgium
Solid lubricants in stable dispersion proved to work well in engines and transmissions. Look for high concentration, good stability and particle size <1 micron. Avoid PTFE, but graphite and Boron Nitride give great results as well.
#2484834 - 01/06/12 03:20 PM Re: MOS2 Additive [Re: jayschrodter]
ltslimjim Offline
Loc: WatUpDoc
I've seen a price increase of almost 100% for MoS2 at local Napa stores, FWIW. Still a decent buy at $7.49 retail locally. If it were to go up any higher, I'd probably stop using it...
#2488828 - 01/10/12 09:06 AM Re: MOS2 Additive [Re: jayschrodter]
45ACP Offline
Loc: Dallas Texas
I think it costs ~4.69 a can at NAPA? In any case, it is a good additive. Even in oils that have Moly already.. something about how the Moly in it is different, somehow. The effect IS noticeable! It "seals" the engine and moving parts up, in a good way. And although putting in the whole can (i put it in on a HOT engine, for maximum adhesion) makes a difference, putting in half a can then the other half later (if you can hold back your will to do so) will have virtually, if slightly less, the same effect.
I have heard somebody say they put in 2 cans once but i would not recommend doing that. And the change in oil color to "olive" is normal.
#2488848 - 01/10/12 09:28 AM Re: MOS2 Additive [Re: jayschrodter]
Vikas Offline
Loc: NorthEast
Is it advisable to put Kreen in the oil which was MOS2'd before? Won't they "fight" each other??
#2488860 - 01/10/12 09:41 AM Re: MOS2 Additive [Re: Vikas]
45ACP Offline
Loc: Dallas Texas
"Kind of." Same when asked if Mos2 can be put in a sludged engine.
Some know better than I but the question was asked if MMO could be used the same time as Mos2. My answer would be "no" but others came in and said that they do different things, and could actually be used at the same time.
And while that sounds good at firs,t if it came down to it, .. i wouldnt do it, as it seems like "too much going on" after a good hard think. Kreen i would imagine would be the same.
Kreen it BEFORE Mos2 IMHO. As i said, i dont know "as much" as someone else but i have kept tabs on this, reading.
#2488863 - 01/10/12 09:47 AM Re: MOS2 Additive [Re: jayschrodter]
Boss302fan Offline
Loc: Oconomowoc Wi
There are cleaners and moly in most oils. What's the difference? I really do not think it makes a difference if you use MMO or Moly at the same time...
John P
Wisconsin
2006 Lexus LS 430
1990 Jaguar XJS V12
2011 Hyundai Santa Fe V6
Other fun cars
#2488881 - 01/10/12 10:16 AM Re: MOS2 Additive [Re: Boss302fan]
45ACP Offline
Loc: Dallas Texas
Yes but
1. They are proportioned to each other and
2. Motor oil is not known for its high moly content OR cleaning ability except predominantly in the case of PYB, PU, High POE M1 or Redline (both) and
3. The Moly goes "into" suspension and "out of" suspension. Does that happen in normal motor oil as well?
Just some thoughts smile
