Gumout Cleaning Deposits from GDI Q&A
Click here to participate in the Gumout Cleaning Deposits From GDI Q&A
food depot
by urrlord
51 minutes 35 seconds ago
Re-surfacing original GM wheels
by HM12460
Yesterday at 10:28 PM
Valve guide seals? - This much smoke?
by Nick1994
Yesterday at 10:12 PM
Opinions on goodyear Viva 3's
by Toaster_Jer
Yesterday at 09:37 PM
Suggestions for used suv/cuv
by dohnuts
Yesterday at 09:26 PM
60's GM S/W With Speedometer That Changed Color ??
by crazyoildude
Yesterday at 08:55 PM
old oil
by OkieHick
Yesterday at 08:48 PM
Good lubricant for door hinges that last?
by wolf_06
Yesterday at 08:47 PM
Mini Cooper OEM Purflux 5153 miles [cut open]
by nicrfe1370
Yesterday at 08:11 PM
Mag 1 and SuperTech knockoffs not looking so good
by AP9
Yesterday at 08:02 PM
Something to think about.....
by motor_oil_madman
Yesterday at 07:11 PM
Temp gauge mod?
by Avery4
Yesterday at 06:51 PM
showstopr30, any_user, NibbanaBanana, h22rider, Troyselby
57963 Registered Users
31 registered (carlprop, asand1, alan003, dave1251, ag_ghost, A_Nelsen, 2 invisible), 753 Guests and 113 Spiders online.
57963 Members
66 Forums
249323 Topics
Page 1 of 2 1 2 >
#2461794 - 12/13/11 08:29 PM Restore engine additive
BlueOvalFitter Offline
Loc: Cajun Country, La.
I'm not one to use snake oil additives in engines but my dad has a 93 Lincoln,4.6,that is smoking/burning oil. Before we pull it and replace/rebuild it I was thinking of trying Restore engine additive. Any opinions on this product?
2007 F150 XL, 4.2 V6, 4R75E Transmission
Pennzoil Platinum HM 5W30, M1-209 Oil Filter
"One Filter, One OCI!"
USA
#2461811 - 12/13/11 08:45 PM Re: Restore engine additive [Re: BlueOvalFitter]
Radman Offline
Loc: Detroit, Michigan
Is that the kit where you put the pellets in the spark plug holes?
If I wanted to keep the car I would rebuild it. If I was selling it I still wouldn't put that stuff in.
2006 Maxima 120K M1-105, M1 0W40
2006 Sentra 90K M1-105, GTX 5W30
2010 Altima 20K M1-105, GTX 5W30
2013 Yamaha FZ1 1K PL1410, SRT5 15W40
#2461817 - 12/13/11 08:53 PM Re: Restore engine additive [Re: BlueOvalFitter]
OVERKILL Offline
Loc: Ontario, Canada
That engine likely just needs valve guide seals. Very common on the early Modular engines.
02 Expedition
06 Charger R/T
14 Charger SRT-8
#2461820 - 12/13/11 08:56 PM Re: Restore engine additive [Re: BlueOvalFitter]
Merkava_4 Offline
Loc: Clovis, CA
The main thing that additive does is thicken up the oil so it doesn't sneak by your worn out piston rings.
#2461821 - 12/13/11 08:57 PM Re: Restore engine additive [Re: BlueOvalFitter]
Quest Offline
Loc: beaver land EH?
IMHO save those money/time and go straight through an engine rebuild. None of these OTC additives will help an oil-burning engine (only a complete teardown will give you a full story of the engine situation).
Q.
"Internet discussion boards act as echo chambers for conspiracy dittoheads" A.Allen
#2461826 - 12/13/11 09:02 PM Re: Restore engine additive [Re: Quest]
Merkava_4 Offline
Loc: Clovis, CA
Yeah, like the ring gap will no longer be at its new spec. grin2
#2461876 - 12/13/11 10:07 PM Re: Restore engine additive [Re: Merkava_4]
chubbs1 Offline
Loc: Merritt Island FL, USA
crackmeup
'12 Charger SXT
QSUD 5w30 OEM filter
'12 Charger SXT
Edge FST EP 5w30 OEM (Mine;)
'11 Hyundai Sonata GLS
QSUD 5w20 OEM Filter
#2461966 - 12/14/11 01:40 AM Re: Restore engine additive [Re: BlueOvalFitter]
ueberooo Offline
Loc: Portland, Oregon
I would give this a try:
http://shop.advanceautoparts.com/webapp/...RP60033_____BBV
CD2 may also have a no smoke addv
Best to get a high mileage variety of oil on next oil change, and a thicker grade. not sure if 10w40 or 15w40 is too thick for an old ford v8?
I would avoid the additives that have heavy metals like lead; restore might be one of those.
--- 1995 Subie Imp EJ18, MT, with ~ 193K miles.... Kendall 5w30. I <3 MoS2 + B + Zn ----
#2461969 - 12/14/11 02:01 AM Re: Restore engine additive [Re: ueberooo]
Merkava_4 Offline
Loc: Clovis, CA
This is a modern day Ford 4.6L that's supposed to be run on 5W-20.
Changing to 10W-40 might split the crankcase clean in half. grin2
#2462078 - 12/14/11 07:29 AM Re: Restore engine additive [Re: BlueOvalFitter]
Mud Offline
Loc: Texas
The older mod motors run forever on a good quality 5W-30, I would not start using a thicker oil as a band-aid.
Up to 97, they were also prone to valve stem seal leakage. Dunno the mileage on the engine but before you decide a rebuild is needed it may be worth replacing the seals.
57 Chevy 2drHdtop 454/400/F9
11 Mercedes E350 4Matic
11 Silverado 5.3/6spd
73 VW Bug in progress
97CVPI/02CV/03CVSport sold
#2462112 - 12/14/11 08:20 AM Re: Restore engine additive [Re: BlueOvalFitter]
LeakySeals Offline
Loc: MA
If you get a puff of blue smoke at start up it could be valve seals. If you burn more oil on the highway or when accelerating it could be sticky piston rings. Below is why I say this.
Bought a 02 Camry cheap because it had a bad tick, burned a quart every 1500, and needed a new front cat to pass inspection. Puff of blue smoke at startup, burned more oil on the highway or when accelerating. Under the valve cover was a goopy sludgy mess. Using Mobil 1 High Mileage for a couple of OC's (recommended by BITOG members) dropped the oil consumption to 1/2 quart every 5k. Made a believer out of me. Now I run straight M1 5w-30. Would guess sticky rings were mainly responsible because the valve seals still puff at startup (not as bad). So you should try M1 High Mileage for 2 OC's, change the PCV valve, see what happens. As others have stated restore is an old school method of dealing with oil consumption - dont clean it, plug it up more.
02 Camry XLE 2AZ-FE 345k M1 HM 5w30
06 Escalade 132k. M1 0w30
#2462601 - 12/14/11 04:08 PM Re: Restore engine additive [Re: OVERKILL]
SteveSRT8 Offline
Loc: Sunny Florida
This is true. My son has a thing for big Lincolns and he had one that began smoking at over 200k miles. It was absolutely fine in every way, except:
Just needed valve seals, cost less than ten bucks to fix.
Also, sometimes oil has accumulated in the intake manifold. Be sure and check this engine carefully. Manifold vacuum gauge and a compression gauge are critical.
"In a democracy, dissent is an act of faith."
J. William Fulbright
Best ET-12.79 @ 111 mph
4340 pounds, Street tires
Just like we go to Publix
#2464012 - 12/15/11 09:23 PM Re: Restore engine additive [Re: BlueOvalFitter]
crazyoildude Offline
Loc: New Jersey
before you do a total rebuild check to see it may be the valve seals...
#2464598 - 12/16/11 03:09 PM Re: Restore engine additive [Re: BlueOvalFitter]
EricF Offline
Loc: SF Bay Area
Restore works.. realistically it'll last around 2200 miles.
It stopped a 85 camry smokestack into a clean machine.
1993 Ford Ranger XLT 4.0L 4x4 (240k) 5W-30 Synpower
2006 Saturn Relay-3 3.5L (85k) 5W-30 Synpower
2012 Ford Fusion SE 2.5L (39k) 5W20 M/C Semi Syn
#2469027 - 12/21/11 09:08 AM Re: Restore engine additive [Re: BlueOvalFitter]
urrlord Online   content
Loc: central ga
It works,at least the CSL(copper ,silver,lead particle) version does.I had an 86 ltd v-6 with varying cylinder compression that resulted in a "lumpy" idle.A can of restore levelled out the idle quite bit.I was happy as the car was not worth a rebuild.
Page 1 of 2 1 2 >
