Another Cool Pawn Shop Find!!
by Panzerman
7 minutes 36 seconds ago
MS5K vs Super Tech
by car51
Today at 06:17 PM
2013 Accord 2.4L 6MT - 11K OCI - M1 AFE OW-20
by oily boyd
Today at 05:49 PM
Car inspection in your state?
by car51
Today at 05:48 PM
Thoughts on turning rotors
by stygz
Today at 05:43 PM
Impressions of Redline in HD trans - good stuff
by MoreCowbellAz
Today at 05:35 PM
Help with Oil Analysis
by Enotoga
Today at 05:30 PM
Fram PH3600 Orange Can Cut and Post
by DerbyDave
Today at 05:26 PM
Wix 51223XP (BMW)
by OldEuroCarLover
Today at 05:17 PM
out with the subaru and in with a new Fusion
by stygz
Today at 04:33 PM
Brand perception
by OldEuroCarLover
Today at 04:16 PM
Looking for a super economical car, accent ?
by sirgerman
Today at 04:00 PM
Safetyfirst, rwood, USARMOR, GV00, anhwp1
58942 Registered Users
82 registered (anhwp1, b1amgm47, andyd, 69GTX, AIRJAC3, 2015_PSD, 8 invisible), 1505 Guests and 39 Spiders online.
58942 Members
66 Forums
253643 Topics
Page 1 of 2 1 2 >
#2459914 - 12/11/11 07:31 PM Low oil pressure caused by oil filter?
porcupine73 Offline
Loc: Buffalo, NY
So I noticed the oil pressure gauge on my '94 Subaru Legacy seemed to be reading low. After I replaced the oil filter, the problem went away.
It was taking about four seconds after startup for the oil pressure light to go off, then the oil pressure would very slowly rise. But it would never go above 25 psi.
After replacing the oil filter, the pressure now climbs quickly to about 65psi after start up, which is what I expect (this is with engine cold).
So what's up with this oil filter? Was it defective? It was a Amsoil eao34, says Made in Mexico Jul0209. I checked the ADBV and it didn't seem to be stuck. I guess maybe I should cut it open and see if anything is funky in there?
It really irritates me that it seems like it was the oil filter, because this is supposed to be a premium oil filter, and here I was running the engine for a week or so with highly suboptimal oil flow.
At first I thought it was the pressure gauge was bad (Sunpro I had just installed). So I replaced the sender and gauge, but it did the same thing. So next I tried the oil filter, and that seemed to fix it.
#2459932 - 12/11/11 07:45 PM Re: Low oil pressure caused by oil filter? [Re: porcupine73]
GMBoy Offline
Loc: Texas
I had the same thing happen to me on 2 different AC/Delco filters. ZERO oil pressure at start up until you rev'd the engine and then oil pressure rose. I changed the filter and problem gone. I've never used another AC filter since. Been using Bosch the last 2 years and never had the oil pressure issue again. It was the filter.
#2459935 - 12/11/11 07:49 PM Re: Low oil pressure caused by oil filter? [Re: porcupine73]
porcupine73 Offline
Loc: Buffalo, NY
Hm that's interesting. I wonder what it is about the filter that can cause it?
I had the oil pump off while doing the timing belt. I noticed on the first startup, the pressure did climb to around 65psi which I was happy with, but that was it. After that it never went above 25psi again until I changed the filter.
I know some cars can have trouble getting the oil pump to initially suck the oil out of the pan through the pickup after this kind of job though I've never had it happen.
I replaced it with a different Amsoil eao34 and it seemed to be fine. I've been using this filter for many years on several Subaru's but never had this problem before.
The other thing that really bothers me about this, is that without an oil pressure gauge, I would never have known about this problem. I had noticed increased engine noise for the first few seconds after startup which didn't seem quite right, along with the oil light taking too long to go off, but after that I wouldn't have known without a pressure gauge.
Edited by porcupine73 (12/11/11 07:51 PM)
#2459949 - 12/11/11 08:03 PM Re: Low oil pressure caused by oil filter? [Re: porcupine73]
crazyoildude Online   content
Loc: New Jersey
it could be i had a problem like that using a pureone my oil pressure took longer to build up changed that and everything was back to normal that was on a dodge ram 250 with a 5.2 litre 318
Will Not Use Oil Filters With Those Tiny Restrictive Looking Louvers! Also Not A Fan Of Oil Jugs That Don't Have A Security Inner Seal..
#2459995 - 12/11/11 08:47 PM Re: Low oil pressure caused by oil filter? [Re: porcupine73]
qr25de Offline
Loc: Canada
Keep the oil filter and give Amsoil a call ASAP.
#2460026 - 12/11/11 09:30 PM Re: Low oil pressure caused by oil filter? [Re: porcupine73]
Donald Offline
Loc: Upstate NY
I had a flaky oil pressure problem with a Amsoil Ea filter and a 94 Camry. Replaced the filter with another brand and no more problems. Sent filter to Amsoil who said it was full but not defective. I am not sure what to conclude, except that filter in that condition caused a problem.
2015 Ford F250 w/Powerstroke
2001 Jeep Grand Cherokee Laredo 4.0- sold
1999 Dodge Ram 2500 w/Cummins- 4-sale
#2460221 - 12/12/11 08:35 AM Re: Low oil pressure caused by oil filter? [Re: GMBoy]
rshaw125 Offline
Loc: Raleigh ,NC CSA
Were they the 'new' AC Delco filters? E cores. I stopped using AC Delco filters and now buy NAPA silvers. Same price.
2012 Porsche Carrera S
1995 Plymouth Voyager
#2460321 - 12/12/11 11:03 AM Re: Low oil pressure caused by oil filter? [Re: GMBoy]
Jim Allen Offline
Loc: NW Ohio
Was this the initial startup after an oil or filter change, or afterwards? Did you autopsy the filters? Two defective filters in a row is bizarre.
Jim Allen
Keepin' the Good Old Days of Four Wheeling Alive
#2460357 - 12/12/11 11:57 AM Re: Low oil pressure caused by oil filter? [Re: Jim Allen]
GMBoy Offline
Loc: Texas
I had posted about this when it happened but beings it was so long ago I could not find it. But, anyhow yes it is strange, but true.
This happened each time about 1000 miles into the OCI, it was not related to a fresh oil change. I threw the first one away but I sent the 2nd to AC DELCO but never got a response. Mind you, these 2 filters were purchased several months apart so I doubt it was the same lot.
#2460358 - 12/12/11 11:58 AM Re: Low oil pressure caused by oil filter? [Re: rshaw125]
GMBoy Offline
Loc: Texas
I'm sorry but I don't remember. It was 2 years ago, not sure exactly when ecore came along but I "think" the number on the box did not have the "E" after it making it the original style.
#2460699 - 12/12/11 06:12 PM Re: Low oil pressure caused by oil filter? [Re: porcupine73]
ZeeOSix Offline
Loc: PNW
Only way a filter could cause a low oil pressure reading on a sending unit located after the filter is if the filter got majorly clogged somehow and didn't allow oil to flow. This would cause the oil pump to increase output pressure and eventually hit its max pressure relief setting, and shunt most of the oil back to the sump.
Even if the media was totally clogged up, it's possible depending on the bypass valve design, that the oil flow could be choked down significantly enough due to a restricted bypass valve flow area that would cause a low oil pressure reading. Or it's possible the bypass valve didn't operated correctly, thereby causing a large restriction when the filter needed to bypass due to clogged media.
Really need to dissect any filter that is suspect of causing a major lack of oil flow.
#2460789 - 12/12/11 08:10 PM Re: Low oil pressure caused by oil filter? [Re: porcupine73]
porcupine73 Offline
Loc: Buffalo, NY
Thanks for the info. So I cut the filter open (Amsoil eao36 [not eao34 I had the wrong #]) this evening to see what was going on in there.
What I found was the media slightly collapsed, but not overly so. There was some amount of a sludge like slightly gritty black material over most of the filter media. I assume it came from my engine.
I don't think I see a bypass valve in this filter? It had a spring and solid end cap. I thought this filter was supposed to have a bypass? Unless I'm just not recognizing it.
So it appears what happened is the filter media got quickly plugged up with this sludgy stuff and then could not pass much oil, especially since it had no bypass.
That would explain that I did see around 65 psig the first time I started it up. There must have been a bit of junk in the pan that got pumped into the filter right at startup.
So I will need to keep an eye on the pressure now, since maybe there is more junk in there that will plug up the filter quickly again.
Between the pleats the filter was pretty clean, but the pleats were pretty packed together.
#2460821 - 12/12/11 08:26 PM Re: Low oil pressure caused by oil filter? [Re: porcupine73]
ltslimjim Offline
Loc: WatUpDoc
I need to open an Amsoil EaO20 that I suspect to be 'full', possibly. That or my oil pressure switch was faulty, replaced filter and switch no more oil light. No actual gauge, though...
92 Civic Hatch (stolen frown RIP)
07 Honda Fit Sport (A/T) WELCOME thumbsup
#2461827 - 12/13/11 09:03 PM Re: Low oil pressure caused by oil filter? [Re: porcupine73]
goodtimes Offline
Loc: california
The filter should be changed with another one exactly the same to verify it is the filter design, or a defect, or a lot closer to verifying. Always possible to get two bad ones in a row but not likely.
#2462029 - 12/14/11 06:05 AM Re: Low oil pressure caused by oil filter? [Re: porcupine73]
rshaw125 Offline
I think AC Delco got out of the filter business around 2005 or 2006. That's when the ecore's began to appear. Along with the complaints.
No point in really using one. They are 3.97 at Walmart. NAPA has the silver for 3.99.
Page 1 of 2 1 2 >
