Best alternative to FL500S
by buck91
08/27/16 09:11 PM
New router?
by Quattro Pete
08/27/16 08:44 PM
MPV 7100 Hybrid Mower
by spk2000
08/27/16 08:17 PM
Carlson Slide Pins
by SavagePatch
08/27/16 08:07 PM
Any one have info on a .357 rifle?
by Chris142
08/27/16 07:36 PM
Another Cool Pawn Shop Find!!
by Panzerman
08/27/16 07:20 PM
MS5K vs Super Tech
by car51
08/27/16 06:17 PM
2013 Accord 2.4L 6MT - 11K OCI - M1 AFE OW-20
by oily boyd
08/27/16 05:49 PM
Car inspection in your state?
by car51
08/27/16 05:48 PM
Thoughts on turning rotors
by stygz
08/27/16 05:43 PM
Impressions of Redline in HD trans - good stuff
by MoreCowbellAz
08/27/16 05:35 PM
Help with Oil Analysis
by Enotoga
08/27/16 05:30 PM
Safetyfirst, rwood, USARMOR, GV00, anhwp1
58942 Registered Users
87 registered (4WD, 69GTX, A1O, 1JZ_E46, ag_ghost, 3800Series, 5 invisible), 1417 Guests and 32 Spiders online.
58942 Members
66 Forums
253648 Topics
Page 1 of 2 1 2 >
#2450066 - 12/01/11 12:11 PM 2006 Honda Odyssey misfire
handyman Offline
Loc: TX
My wife’s friend, (you know how that goes, I get volunteered to work on stuff) has a 2006 Honda Odyssey. She is getting random misfires. She took it to Auto Zone and got a scan. The codes read P0302
Definition
Cyliinder misfire detected – cylinder number 2
Explanation
The powertrain control module monitors the crankshaft speed and has detected a misfire condition
Probable cause
aa1 Ignition system fault – spark plugs(s), ignition wires, coil
aa 2 – vacuum leak
aa3 injector fault
aa4 high or low fuel pressure.
It has around 46,000 miles. She drives it to work round trip five miles daily. I think the only thing she does is change the oil.
I thought of Gary Allen. Didn’t he dumped two quarts of ATF and one quart of MMO into the gas tank of one of his cars and fogged the neighborhood? That would clean up the cylinders (hahahaha).
I could not work on it for long last night. I stay up way too late working with my daughter on her homework.
I did dump in a bottle of Chevron Techron Fuel System cleaner and drove around the neighborhood. You can feel the random misfile when you’re idling.
I took off the engine cover and three spark plugs are easy to get to.
Any suggestions?
2011 Prius III 60k
2006 Senna LE 160k
2001 Saturn L140 160k
1993 Corolla LE 150k
#2450077 - 12/01/11 12:18 PM Re: 2006 Honda Odyssey misfire [Re: handyman]
Hokiefyd Offline
Loc: Top of Virginia
I'd say it's likely a spark plug or ignition coil. Spark plugs would be the first thing I'd check and/or change. This engine uses coil-on-plug, so there are no wires to deal with. Is this an EX-L or Touring, or a lower trim Odyssey? An EX-L or Touring from that model year should have the VCM version of the engine (Variable Cylinder Management), and that could introduce a number of variables not common to a more conventional engine.
The Honda J-series engine's cylinders are numbered 1-2-3 on the right (rear) bank starting from the accessories side of the engine and 4-5-6 on the left (front) bank. So unfortunately, this is the center cylinder on the rear bank of the engine.
Cheers,
Jason
2009 Honda Ridgeline RTL
2005 Acura MDX Touring
#2450078 - 12/01/11 12:20 PM Re: 2006 Honda Odyssey misfire [Re: handyman]
SuperDave456 Offline
Loc: Dallas, Texas
I'd start with Plugs, Wires, and Coil pack.
It's almost 6 years old. And it being what it is, it probably spends at least half of the time sitting at Stop Lights.
I'm pretty sure these come with Iridium plugs if so I would check them, and then go about replacing the Wires and Coil pack.
If you want to do it on the cheap, start with only the Coil Pack. Those typically go first, at least in my experience, before wires and plugs. But you might as well do all of them if you are having an issue. I'd still check all the electrical, I'd doubt it is a fuel issue.
It sounds a lot like the Ford Taurus's in my Family that had a bad coil pack from your test drive. Although all of those cars had around 100,000 miles or more before it went bad.
#2450134 - 12/01/11 12:53 PM Re: 2006 Honda Odyssey misfire [Re: handyman]
Radman Offline
Loc: Detroit, Michigan
Ohm the coil packs & change the failed one.
2006 Maxima 120K M1-105, M1 0W40
2006 Sentra 90K M1-105, GTX 5W30
2010 Altima 20K M1-105, GTX 5W30
2013 Yamaha FZ1 1K PL1410, SRT5 15W40
#2450141 - 12/01/11 01:00 PM Re: 2006 Honda Odyssey misfire [Re: handyman]
Quest Offline
Loc: beaver land EH?
*as if MMO and ATF gonna do squat for your cylinders*
Quick trick:
(1) replace all the spark plugs with fresh new ones.
and see if cyl 2 misfires go away. If it does, your job is done.
if not, proceed to step (2)
(2) swap coil pack from cyl 2 to somewhere else (e.g. cyl 1 or 3 or 4, etc.)
clear the codes and then take it out on a drive. If a cylinder misfires detected and seems to follow to the otherwise known cylinder coil that you swap with cyl 2, you know that original cyl 2 coil is faulty (and order a new replacement).
Q.,
"Internet discussion boards act as echo chambers for conspiracy dittoheads" A.Allen
#2450288 - 12/01/11 04:15 PM Re: 2006 Honda Odyssey misfire [Re: Hokiefyd]
handyman Offline
Loc: TX
I'm almost thinking about telling her to take it to the dealer. The plugs and coils are on the back side of the enjine. I'm not even sure how to check the coils
2011 Prius III 60k
2006 Senna LE 160k
#2450289 - 12/01/11 04:17 PM Re: 2006 Honda Odyssey misfire [Re: handyman]
handyman Offline
Loc: TX
The back side of the engine. It looks like I would have to remove a few things to get to the plugs. I'm not sure I want to do that,.
2011 Prius III 60k
2006 Senna LE 160k
#2450351 - 12/01/11 05:52 PM Re: 2006 Honda Odyssey misfire [Re: handyman]
Hokiefyd Offline
Yes, the ones on the rear bank are not that easy to get to. It appears the best strategy is to simply elevate yourself and lay aross the top of the engine to get to them. With the engine cover removed, you should be able to "lay" on the flat top of the intake manifold and get to the rear coils.
If they're like the ones on our MDX's engine, the coils are retained by a single socket head bolt each. I don't know the size of the proper hex key off-hand, but the proper torque for each is 8.7 lb*ft (again, for my '05 MDX anyway, which uses essentially the same engine). The spark plugs are 13 lb*ft.
Cheers,
Jason
#2450374 - 12/01/11 06:09 PM Re: 2006 Honda Odyssey misfire [Re: handyman]
Tegger Offline
Loc: Canada
First you say "random misfires", which is DTC P0300. Then you say AZ read a P0302, which is a misfire on cylinder 2.
You'd better be dead-sure what codes you're getting, otherwise you may end up looking a fool to the lady you're trying to help. And you may end up chasing a very expensive goose all over the place.
And just so you know, misfire codes may NOT be due to ignition problems!!!!
2013 Toyota RAV4 - 57,000 miles - Toyota 0W-20, Toyota filter
#2450393 - 12/01/11 06:36 PM Re: 2006 Honda Odyssey misfire [Re: handyman]
Audios Offline
Loc: Lyndhurst NJ
The rear plugs arent so bad to reach, you can get your hand in there on the passenger side and snake it around to the drivers. Swap the coil like stated and see where that takes you. If it remains, check the plugs. I believe they are the NGK iridiums, IZFRK-11 in there, list is around 29 a piece I think. EGR passages are known to clog on these motors. I would swap the coils first, and check the condition of the plugs you dont want to throw 180 worth of plugs in there and have it be a coil, or throw a 90 dollar coil at it and have it be plugs. The coils are held down by a 5 or 6mm allen.
1997 Audi A4 1.8t-LM 5/40 Synthoil Premium
2002 VW Golf TDi-Mobil 1 5/40 ESP
#2450616 - 12/01/11 10:41 PM Re: 2006 Honda Odyssey misfire [Re: handyman]
91344George Offline
Loc: CA
Don't get roped into working on this, have your wife's friend take it to the dealer or a good independent shop. If you break it you will NEVER hear the end of it and it could cause your wife to lose a friend.
#2450887 - 12/02/11 10:36 AM Re: 2006 Honda Odyssey misfire [Re: 91344George]
JTK Offline
Loc: Buffalo, NY
Sounds like he's already roped in.
Yes, coils and plugs are easy to get at on the Odyssey 3.5L. I own a 2008. These don't have the clearance issues that other minivans have.
Like said, these engines still use an EGR system and EGR issues are not uncommon, although they usually include a code of their own when issues arise.
How many miles are on this beast? I wouldn't drive it if there's misfiring going on. Excessive fuel loading to the catalytic converters will ruin them. The triple cat assembly for the 2005-2010 Ody is over $1000 to replace.
Joel
Edited by JTK (12/02/11 10:37 AM)
2016 Subaru Forester 2.5, CVT. 2013 Dodge Grand Caravan SE (Babe magnet III)
#2450916 - 12/02/11 10:56 AM Re: 2006 Honda Odyssey misfire [Re: Audios]
handyman Offline
Loc: TX
[censored]! $30 dollar plugs? Yea, I checked last night and I can get to back plugs and coils. I think I will look at the plugs and switch around the coils before I throw any money at it. It has around 46,000 miles.
2011 Prius III 60k
2006 Senna LE 160k
#2450919 - 12/02/11 10:58 AM Re: 2006 Honda Odyssey misfire [Re: handyman]
handyman Offline
Loc: TX
I guess I can clear out the codes by disconnecting the battery for ten minutes.
2011 Prius III 60k
2006 Senna LE 160k
#2450945 - 12/02/11 11:30 AM Re: 2006 Honda Odyssey misfire [Re: handyman]
bigdreama Offline
Loc: Fl & Vt
Get the recommended NGK spark plugs and put them in. I had the same problem with "equivalent crossover" plugs in my Civic.
'14 Subaru Crosstrek MT 39k
'15 Tacoma 4x4 MT 10k
'03 Camry AT 121k
'07 BMW R1200GSA 60k
'98 Electra Glide 51k
'06 Kawi KLR650 34k
'73 Suzuki TS-185 11k
Page 1 of 2 1 2 >
