45456 Members
64 Forums
193626 Topics
Max Online: 2449 @ 05/13/13 01:57 PM
#2348129 - 08/16/11 07:16 AM
Re: Post your internal engine pics
[Re: Silk]
Loc: Jupiter, Florida
This is a Mitsubishi 4M40 - the 2.8 diesel.I've never seen inside one to see what causes these marks on the bore,but they all have it.Even the new 4M41,that is the 3.2 direct injection common rail version.Their other small diesel the 2.5 4D56 doesn't do this. I think Mitsubishi laser etched certain cylinders for oil retention reasons. I'm not 100% sure that what we are seeing here, but, I'd bet a dollar. Years ago, Mitsubishi pioneered a system where cylinders were laser etched in specific patterns. The etching produced deep, uniform, microscopic oil retention pores. The result was greatly reduced cylinder wear, especially towards the end of engine life, at the point wear accelerates.
Turbo's rule.
#2349863 - 08/17/11 11:07 PM
[Re: Nick R]
Loc: Ky
I had a radiator hose pop off which caused it to overheat and blow the gaskets while warping the heads at the same time.
2001 Eclipse GT 5-Speed Castrol GTX 5w30 Purolator Classic
#2357923 - 08/25/11 11:19 PM
[Re: Nick R]
Loc: Texas
Had to replace my valve cover gaskets this past weekend took the chance to take some pics. 144k on the engine, the head was rebuilt 35K miles ago. Cams and Bearing Caps are still varnished up (the head was one of my spares i had laying around, i didnt send the cams or caps to the machine shop I should've but eh)
88 Toyota Supra
#2427270 - 11/06/11 11:42 PM
[Re: Nick R]
Loc: NorCal
2001 VW Passat 1.8T 175k (Z blend) 2009 Honda Fit 75k many VW TDIs (RT6 or TDT) 2004 Mercedes C320 190k (Z blend) Try the "Z blend": G-Oil+HDEO!
#2427897 - 11/07/11 04:57 PM
[Re: Nick R]
Loc: Jupiter, Fl
Are you sure those aren't my pics?   But mine had less than 60K at this point. '04 Audi A4
Edited by CBR.worm (11/07/11 04:58 PM)
'06 Infiniti G35 Sedan 6MT - 145k miles '06 Infiniti FX45 - 90k '08 BMW 528i - 60K '08 CBR1000RR
#2427964 - 11/07/11 06:00 PM
[Re: Nick R]
Loc: Jupiter, Fl
Mine was also M1 0w40
#2428337 - 11/07/11 10:09 PM
[Re: CBR.worm]
Loc: Ontario, Canada
Is that engine a "sludger" ?
Network Engineer 89 Town Car 00 BMW 328i 02 Expedition 01 BMW ///M5
#2428380 - 11/07/11 11:00 PM
[Re: Nick R]
Loc: NorCal
It's a sludger - VW even issued an extended warranty but I don't know how many of those they carried through because you had to document use of their special oils. I'm happy this new-to-me 1.8t had a steady diet of Mobil1 0-40, but I'm still going with HDEO for the rest of its life more than likely.
CBR, I was impressed at how similar our pics looked too!
#2428385 - 11/07/11 11:02 PM
[Re: zanzabar]
Loc: NorCal
Badly leaking headgasket replaced, ...
That was supposed to say VALVE COVER gasket.
#2434450 - 11/14/11 06:05 PM
[Re: Nick R]
Loc: Jupiter, Fl
Yeah, they are sludgers. VW/Audi spec'd too long an OCI, and they cook the oil in half the time. You should see what they look like when people ran conventional oil for the recommended OCI.
Great running engines though, small turbo engine with lots of torque right off idle. 20 valve 4 cyl - I think they were between 180 and 200 HP depending on the application.
ECOboost 12 years ago.
And it was common to have PCV system failures requiring full-scale system replacement. The effects would be pressurizing the crankcase with boost and pushing oil out of all the seals. Also leaking cam gasket seals. My pictures were from the second valve cover gasket replacement in less than 60k. First was done under warranty.
Edited by CBR.worm (11/14/11 06:09 PM)
#2437595 - 11/17/11 06:39 PM
[Re: Nick R]
Loc: Michigan
'98 BMW 328is 118k Arctic Silver Current: M1 0w-40
#2448845 - 11/29/11 11:15 PM
[Re: Nick R]
Loc: San Antonio, TX
