Bean Counters vs Swedish Engineering
by Y_K
08/28/16 12:04 AM
Interesting website for comparing guns
by 901Memphis
08/27/16 11:45 PM
Android clear cached data
by expat
08/27/16 11:07 PM
Worm gear vs spring type hose clamps?
by TheLoneRanger
08/27/16 10:35 PM
Factory fog lights...common wiring and wattage?
by ryan2022
08/27/16 10:32 PM
2 Hyundai/Kia OEM Filters cut open
by KD0AXS
08/27/16 10:30 PM
Preferred SUV for snow: Large FWD or smaller AWD?
by Carbon12
08/27/16 09:55 PM
Chevron 5W-20 $10/5-quart at WM
by wgtoys
08/27/16 09:15 PM
Best alternative to FL500S
by buck91
08/27/16 09:11 PM
New router?
by Quattro Pete
08/27/16 08:44 PM
MPV 7100 Hybrid Mower
by spk2000
08/27/16 08:17 PM
Carlson Slide Pins
by SavagePatch
08/27/16 08:07 PM
DALpilotMike, Safetyfirst, rwood, USARMOR, GV00
58943 Registered Users
53 registered (3800Series, B320i, Billbert, 69GTX, Astro14, 901Memphis, 6 invisible), 946 Guests and 33 Spiders online.
58943 Members
66 Forums
253655 Topics
Page 1 of 4 1 2 3 4 >
#2445678 - 11/26/11 10:17 PM how long can a water pump last?
Dakota1820 Offline
formerly chevyboy14
Loc: missouri usa
I am curious to hear how long some peoples water pumps have lasted. Mine looks old and makes me nervous with winter coming up. But seems to work alright for now..... It's on my Saturn sl2.thanks all.
2004 Honda civic vp -m1 5w30
1998 Saturn sl2 -mobil super 5000 5w30
#2445683 - 11/26/11 10:20 PM Re: how long can a water pump last? [Re: Dakota1820]
FXjohn Offline
Loc: NE Indiana
it won't go out all at once, it will leak first. don't worry
#2445690 - 11/26/11 10:28 PM Re: how long can a water pump last? [Re: Dakota1820]
Dan55 Offline
Loc: jersey
93 SL2 238K
2016 Lexus NX200T 07 Fit Sport 05 Mazda 3S
#2445694 - 11/26/11 10:30 PM Re: how long can a water pump last? [Re: Dakota1820]
Dakota1820 Offline
formerly chevyboy14
Loc: missouri usa
I've been told that they don't usually leak as much as gush tons of fluid out. Apparently they usually fail with the water pump just pouring out antifreeze. That's what I've been told it could be wrong. And 238k on the original water pump.that's pretty good in my book
#2445701 - 11/26/11 10:37 PM Re: how long can a water pump last? [Re: Dakota1820]
Chris142 Offline
Loc: apple valley, ca
Our shop truck has it's original WP on it with 355K on it.
02 Wrangler Chevron 10w30
87 F250 napa 15w40
04 Tahoe super-s 5w30
Z400 Lucas 10w30
KLR250 Maxima 10w40
Can am maveric delo 5w40
#2445702 - 11/26/11 10:38 PM Re: how long can a water pump last? [Re: Dakota1820]
CBR.worm Offline
Loc: Jupiter, Fl
My experience has been that if it is a replacement with a lifetime warranty, it probably won't last very long.
I typically replace them before or around 200K as PM in my japanese cars and have never had a failure, but they usually have some evidence of weeping at the weep hole by that time.
'06 Infiniti G35 Sedan 6MT - 160k
#2445705 - 11/26/11 10:41 PM Re: how long can a water pump last? [Re: Dakota1820]
Dakota1820 Offline
formerly chevyboy14
Loc: missouri usa
Well if it weeps it is bad correct? Also how can I tell if its an original does anyone know?
#2445715 - 11/26/11 10:51 PM Re: how long can a water pump last? [Re: Dakota1820]
spackard Offline
Loc: CA
I blew mine on a '79 Chrysler Cordoba at 1am, doing WOT, between a 2-3 gear change. Talk about scaring the explicative out of me. Thought I'd blown the engine or trans.
It was about 9 years old, <80k miles.
#2445716 - 11/26/11 10:52 PM Re: how long can a water pump last? [Re: Dakota1820]
JHZR2 Offline
Loc: New Jersey
We have cars with >>200k on them with original pumps. So long as we arent seeing coolant loss, and temperature stays rock-steady in all conditions (mainly a summer thing), I dont see a reason to swap it. Especially since the original one is probably the best one youll find...
#2445719 - 11/26/11 10:56 PM Re: how long can a water pump last? [Re: Dakota1820]
motorguy222 Offline
Loc: Ky
I have a 1978 Ford Pinto and as far as I know,the water pump is original.
#2445722 - 11/26/11 10:59 PM Re: how long can a water pump last? [Re: Dakota1820]
Dakota1820 Offline
formerly chevyboy14
Loc: missouri usa
I didn't realize they lasted so long. I've never owned a car that went much over 100k before needing a pump changed
#2445726 - 11/26/11 11:01 PM Re: how long can a water pump last? [Re: Dakota1820]
Nick R Offline
Loc: Albany, NY
I replaced the one in my cavalier at 130k miles. And the only reason I did that is because I already had the entire engine apart for the head gasket replacement and it was $20 for a new one.
2013 Ford Focus SE 2.0L/73,000miles/Motorcraft Blend 5W-20/FL-400S
#2445729 - 11/26/11 11:04 PM Re: how long can a water pump last? [Re: Dakota1820]
Dakota1820 Offline
formerly chevyboy14
Loc: missouri usa
Uhhh good old cavalier and the head gasket work. I could do that in my sleep now. But its pretty easy all things considered. Seems like chevys water pumps don't last as long as some other ones
#2445748 - 11/26/11 11:34 PM Re: how long can a water pump last? [Re: Dakota1820]
JavierG Offline
Loc: Fresno, CA
What cars have you owned and what do you drive now? Can I assume they've all been Chevys?
2007 Honda Ridgeline RTX - 1057 mi - Pennzoil Ultra 5W-20, K&N filter
1995 Acura Legend LS Coupe - 167mi - NextGen Maxlife 5W-30, Champ filter
#2445758 - 11/26/11 11:48 PM Re: how long can a water pump last? [Re: Dakota1820]
Dakota1820 Offline
formerly chevyboy14
Loc: missouri usa
We had a jeep that was my moms 2 pumps in 120k cavalier needed one with about 100k Chevy truck had one in the time I had it it had 221 but I know it had one replacement prior to the one I did Atleast my jimmy needed one around 190k not sure how many before that. And the Ford truck at 176 and it wasn't the original either previous owner had it replaced 4 times . The Ford was the worst the bolts froze up and broke the timing cover ended up replacing timing set cover and pump. I think Ford aluminum cover on the 302 is a dumb design . My Chevy corsica never needed one in the 1.5 yrs I had it and my Buick neither but the Buick had 107k and was replaced before I got it it died from a spun main bearing thanks to the head gasket.
