How bad is this?
by cnl64590
02/06/16 02:21 PM
Mag1 or ST Dino: what would YOU use?
by car51
02/06/16 01:54 PM
Ustria?
by Pontual
02/06/16 11:48 AM
Georgia bans 71 oils from 29 brands
by Tom NJ
02/06/16 11:27 AM
Trying to send a Blackstone sample
by 15SilvyEcotec
02/06/16 11:10 AM
2005 Trailblazer getting a new engine
by The_Eric
02/06/16 11:02 AM
AAP: 5 qt Castrol Edge, Boss filter, $30 PP $33
by DoubleWasp
02/06/16 10:48 AM
Make own external backup?
by doitmyself
02/06/16 10:33 AM
What should I use for my next oic?
by dan_erickson
02/06/16 10:25 AM
Motul Sport Ester 5w40 vs Gulf Competition 5w40
by Brit33
02/06/16 10:12 AM
M1 0W-20 EP / 15,745 mi oci / 2004 Honda Accord V6
by vinu_neuro
02/06/16 09:58 AM
Recommend me a small 12v battery.
by dlundblad
02/06/16 09:22 AM
rsritchey, Ball9320, 06Corolla, AyPapii, JakeTheYankee
56834 Registered Users
96 registered (b1amgm47, beetleything, 05LGTLtd, 2015_PSD, Bandito440, bmod305, 6 invisible), 1896 Guests and 189 Spiders online.
56834 Members
66 Forums
244313 Topics
Page 1 of 2 1 2 >
#2444967 - 11/25/11 10:55 PM Aluminum Wheels in Winter
repeater Offline
Loc: Holland, MI
I have aluminum wheels on my Grand Am. They are showing some localized corrosion mostly because of the road salt in use around here. I always wax them before winter, but they always seem to corrode more each season.
Is there a better method than just waxing to keep this from happening?
What is the best way to remove corrosion and at least make it look more like polished metal?
#2445037 - 11/26/11 01:30 AM Re: Aluminum Wheels in Winter [Re: repeater]
Trav Offline
Loc: MA, Mittelfranken.de
Carefully sand the corroded area with 400 and water then go finer to something like 1500-2000 and water. Buff with a Dremel buffing head and compound, wash with warm soapy water and dry.
Mask around the spot and touch up the spot with spray can wheel clear from Duplicolor.
Go to the junk yard and get some cheap steel wheels for the winter and maybe some winter tires.
#2445128 - 11/26/11 08:23 AM Re: Aluminum Wheels in Winter [Re: repeater]
carwreck Offline
Loc: CT
If you have a dremel tool, get the "Dremel 20-Piece Clean & Polish Rotary Tool Accessory Kit" and use the polishing compound that comes with the kit on the corroded areas.
Instead of wax, use an aluminum polish such as Mothers liquid for the whole wheel, and "Mag & Aluminum polish" for the corroded areas. You can apply by hand, or with any drill/polishing tool like Mothers mini cone.
_______________________________________________
1999 Olds GLS
#2445435 - 11/26/11 03:55 PM Re: Aluminum Wheels in Winter [Re: repeater]
Donald Offline
Loc: Upstate NY
Do all aluminum rims come with a clear finish? The rims on my 2001 Jeep GC don't look or feel like it. I also have some corrosion. Guess I need to follow the advice in this thread.
2015 Subaru Forester 2.5 engine/CVT PP & M1
2001 Jeep Grand Cherokee Laredo 4.0 - PP & M1
1999 Dodge Ram 2500 w/Cummins - Rotella T6 & M1
#2445446 - 11/26/11 04:03 PM Re: Aluminum Wheels in Winter [Re: repeater]
ltslimjim Offline
Loc: WatUpDoc
^My came with a clear coat finish, I have 3 original wheels that come with stock VX/HX Civic models(92-00), I purchased a re-furbished and it definitely appears the others have lost their clear coat. It looks like brake dust deposits 'caked on', but more likely aluminum corrosion.
92 Civic Hatch (stolen frown RIP)
07 Honda Fit Sport (A/T) WELCOME thumbsup
#2445606 - 11/26/11 08:37 PM Re: Aluminum Wheels in Winter [Re: Donald]
carwreck Offline
Loc: CT
Some are clear coated; varies by car and year. Grand Am and Olds used clear coat in 1980's, polished or machine finish starting in late 1990's.
On 1980's GM clear coat wheels, the corrsion would form white lines (like a spider web) under the clear coat, and you have to remove the clear coat with paint remover.
It is vary easy to tell if you have clear coat. Metal polish will react with oxidation and turn black on the rag when you polish bare metal.
Metal polish will stay white like Turtle wax if the the wheel is painted or clear finished.
#2445623 - 11/26/11 08:51 PM Re: Aluminum Wheels in Winter [Re: repeater]
Rolla07 Offline
Loc: MTL, CANADA
glad i didnt get aluminum wheels, steel wheels hold up alot better in winter
2007 Corolla Red Pearl 134k miles
TGMO 0w20 & Toyota OEM filter
#2446882 - 11/28/11 05:18 AM Re: Aluminum Wheels in Winter [Re: repeater]
Donald Offline
Loc: Upstate NY
If I use as suggested "MAG & Aluminum" polish will that protect the wheels or just shine them up?
#2446906 - 11/28/11 07:14 AM Re: Aluminum Wheels in Winter [Re: repeater]
sciphi Online   content
Loc: Upstate NY
Best is to get a separate set of wheels for the winter. Then the OEM wheels can be pristine while the aftermarket ones take the salt.
2009 Honda Fit Sport
2012 Chevrolet Cruze Eco
#2446939 - 11/28/11 08:12 AM Re: Aluminum Wheels in Winter [Re: sciphi]
Donald Offline
Loc: Upstate NY
OK, but that is just not going to happen. Its a 2001 Jeep. Whats the next best thing.
#2448391 - 11/29/11 04:49 PM Re: Aluminum Wheels in Winter [Re: repeater]
Dusty Offline
Loc: Omaha, Ne
Poorboy's World Wheel Sealant, or a stronger paint sealant would stand up to the conditions better than wax.
#2452798 - 12/04/11 12:39 PM Re: Aluminum Wheels in Winter [Re: Rolla07]
Kestas Offline
Loc: The Motor City
In my experience, both steel and aluminum rims corrode and give problems at the same rate.
#2453018 - 12/04/11 04:37 PM Re: Aluminum Wheels in Winter [Re: Dusty]
Donald Offline
Loc: Upstate NY
I assume you refer to Pepboys. Not sure there are any around. Anything else? Maybe order something on Amazon.
#2453035 - 12/04/11 04:53 PM Re: Aluminum Wheels in Winter [Re: Donald]
pottymouth Online   confused
Loc: NJ
No, he meant Poorboy's.
Poorboy's Wheel Sealant
#2453118 - 12/04/11 06:23 PM Re: Aluminum Wheels in Winter [Re: Donald]
cchase Offline
Loc: New England
On raw aluminum wheels it will polish them but probably not provide any real protection from salt.
On clearcoated aluminum wheels, it's not going to do anything.
The bottom line is that you can't run raw alloy wheels in the winter if you like them.
Page 1 of 2 1 2 >
