F1 - 2016 Monaco Grand Prix
by gofast182
05/25/16 11:39 AM
Mazda 3 drain and fill
by jay929
05/25/16 11:38 AM
Looking at VW TDI
by loneryder
05/25/16 11:13 AM
Valvoline Maxlife ATF & Walmart
by HosteenJorje
05/25/16 11:00 AM
New car polish
by Tempest
05/25/16 10:58 AM
Toyota Red long Life vs Pink Super Long Life?
by Drew99GT
05/25/16 10:50 AM
Extended Warranty Requirement
by TiredTrucker
05/25/16 09:57 AM
RARE HID installation
by Kira
05/25/16 08:51 AM
ATP AT-205 good engine cleaner ?
by kr_bitog
05/25/16 06:16 AM
List of VOA's from Russian Oil Club
by spiderbypass
05/25/16 01:43 AM
Quicksilver Prem Plus
by jmw116
05/25/16 01:39 AM
Creating white letter tires
by turtlevette
05/25/16 12:22 AM
Hokie_Dave, ant3a, afterburnerbg, SupraSaiyan, Bighorn2500
57973 Registered Users
82 registered (AKA, 1JZ_E46, Andrei, ARCOgraphite, 97f150, 440Magnum, 9 invisible), 1792 Guests and 316 Spiders online.
57973 Members
66 Forums
249383 Topics
Page 1 of 3 1 2 3 >
#2444464 - 11/25/11 10:50 AM 5w-30 cst
semaj281 Offline
Loc: Suwanee, GA
Do car manufacturers know the fact that 5w-30s (besides PAOs) shear to a 20w by then end of the OCI?
Since I can't quite justify spending the money on Amsoil or Redline, I was pondering on the idea of running a Group III 10w-30 in my 2009 Nissan that call for 5w-30. And I wouldn't hesitate to use it in my Ford that calls for 5w-20 after seeing the UOA thread where the OP used 5w-20 in his Mustang.
I live in an area where it's above 32F at least 11 months out of the year, so the cold start benefits of a 5w probably aren't seen anyway.
Edited by semaj281 (11/25/11 11:01 AM)
09 Nissan Versa S Hatchback - Mobil1 SN 5w-30 and NAPA Gold filter
08 Ford Mustang GT/CS - Castrol Edge 5w-30 and Motorcraft filter
#2444484 - 11/25/11 11:22 AM Re: 5w-30 cst [Re: semaj281]
CATERHAM Offline
Loc: Burlington, Ontario, Canada
First oil shear is not as common as it once was with the higher quality VIIs that are used today in top brand oils.
Secondly, when a manufacturer spec's an oil or oil grade there is an allowance of at least 15% for viscosity loss before the oil would be condemned.
Thirdly, the low VI 10W-30 grade is largely obsolete with synthetic oils since the 5W-30 grade is so shear resistant.
Buying a syn' 10W-30 is therefore a poor value.
Forthly, the main advantage of 5W oils over 10W oils is their higher VI meaning they are lighter on start-up at all temp's not just below freezing. And that also is the main benefit of 0W oil over 5w oils; this advantage aplies even in the summer.
Finally using a 30wt oil when a 20wt is specified acheives nothing other than reduced performance, lower fuel economy and increased wear on start-up.
74 Lotus Europa, 5W-50
86 Porsche 928S, TGMO 0W-20 25% / M1 0W-40 75%
96 BMW 328i, Idemitsu/TGMO 0W-20 70% / M1 0W-40 30%
94 Caterham 7, FUCHS 0W-20
#2444485 - 11/25/11 11:24 AM Re: 5w-30 cst [Re: semaj281]
barlowc Offline
Loc: Southeast Michigan
Really, that's fact? Different 5W-30 oils shear more or less and it's different per vehicle/engine too. For example, in my Nissan's QR25DE, Castrol EDGE (i.e. original formula) sheared more than Pennzoil Ultra. However, the UOAs I had done showed them both to be in-grade still.
2013 BMW 335i xDrive Sport Line (26K Miles)
#2444493 - 11/25/11 11:34 AM Re: 5w-30 cst [Re: barlowc]
chubbs1 Offline
Loc: Merritt Island FL, USA
How do you know they sheared more? Castrol Edge (SM) 5w30 is thinner than PU or PP in the first place. Did you do look at the starting 40c and 100c viscosities? Just checking;)
'12 Charger SXT
QSUD 5w30 OEM filter
'12 Charger SXT
Edge FST EP 5w30 OEM (Mine;)
'11 Hyundai Sonata GLS
QSUD 5w20 OEM Filter
#2444498 - 11/25/11 11:41 AM Re: 5w-30 cst [Re: chubbs1]
barlowc Offline
Yep, I compared against their spec viscosities. While EDGE is a little thinner to begin with, the Ultra stayed closer to spec.
#2444502 - 11/25/11 11:43 AM Re: 5w-30 cst [Re: barlowc]
semaj281 Offline
Loc: Suwanee, GA
Most Group III oils failed to maintain viscosity by the time they were drained. I saw your UOA with the EDGE, and your cst was at 8.9. A cst of <9.3 means the oil is a 20w.
These are UOAs and observations that show how easily they shear.
http://www.bobistheoilguy.com/forums/ubb...;page=2#2094467
http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=1902754
http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=1931561
http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=1578935&page=1
#2444505 - 11/25/11 11:45 AM Re: 5w-30 cst [Re: chubbs1]
CATERHAM Offline
[quote=semaj281]
Sorry to be pedantic but we don't really know how thick or thin Castrol Edge is compared to other oils of the same grade since they don't provide HTHSV spec's. A lower KV100 spec' could mean it's lighter at operating temp's but not if it's HTHSV is the same or higher.
That's a big negative with Castrol NA, they don't provide much technical info' on their oils.
#2444506 - 11/25/11 11:47 AM Re: 5w-30 cst [Re: CATERHAM]
semaj281 Offline
Loc: Suwanee, GA
Not in all cases.
http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=2407921
I'm starting to believe the 20wt specification for the Modular Fords was made solely for CAFE reasons.
#2444508 - 11/25/11 11:49 AM Re: 5w-30 cst [Re: semaj281]
barlowc Offline
My bad. I was thinking the Blackstone range stayed within grade but is apparently represents "normal" shearing. Thanks for correcting!
#2444509 - 11/25/11 11:50 AM Re: 5w-30 cst [Re: semaj281]
Drew99GT Offline
Loc: Colorado Springs
Even if it was, it certainly hasn't caused harm to Ford engines.
#2444515 - 11/25/11 11:57 AM Re: 5w-30 cst [Re: barlowc]
semaj281 Offline
Loc: Suwanee, GA
I'm not a tribologist on any level so I may be wrong about the 9.3 threshold. Someone correct me if I'm wrong.
#2444522 - 11/25/11 12:04 PM Re: 5w-30 cst [Re: semaj281]
XS650 Offline
Loc: Northern CA
Google SAE J300 for the numbers if you forget.
Whenever you find yourself on the side of the majority, it is time to pause and reflect.
--Mark Twain
#2444528 - 11/25/11 12:13 PM Re: 5w-30 cst [Re: semaj281]
CATERHAM Offline
That UOA is in new Mustang that's still shedding Fe and other metals and will show higher than normal elemental numbers. Nevertheless the UOA is not bad.
You can conclude nothing fom one UOA, least of all that the oil was too light.
The proper way to determine the correct viscosity is with oil pressure and temperature gauges. The info derived from that will tell you the lowest actual operational viscosity that occurred in the engine and how much of a safety margin you have compared to the manufacturer's minimum spec's.
#2444529 - 11/25/11 12:16 PM Re: 5w-30 cst [Re: XS650]
barlowc Offline
semaj281 is correct. For a 30 grade, the range is 9.3 to 12.5. For a 20 grade it's 5.6 to 9.3. At least according to this paper.
#2444678 - 11/25/11 04:14 PM Re: 5w-30 cst [Re: CATERHAM]
semaj281 Offline
Loc: Suwanee, GA
What are some of the "top brands" that have higher quality VIIs? Do all of today's SN oils fit this category?
Page 1 of 3 1 2 3 >
