Superbowl and Willie Woods
by Donald
02/07/16 08:32 AM
Rural King Synthetic
by MarkM66
02/07/16 08:32 AM
Lesson learned from rebuilding updraft carb
by Donald
02/07/16 08:12 AM
UOA on QSUD 0W20 coming soon!!!
by thorromig
02/07/16 08:05 AM
Which 0w-20 would you pick? (Based on specs)
by tam92
02/07/16 07:48 AM
Kohler Courage SV735-0013
by Mavigraph
02/07/16 07:46 AM
nearly 20k miles of research gone ....
by meborder
02/07/16 06:46 AM
New - smoke detectors for house.
by bmwjohn
02/07/16 03:45 AM
ProGauge PGO-4612 Oil Filter??
by andrewp1998
02/07/16 01:11 AM
Filter efficiency and diminishing returns
by ToadU
02/07/16 12:19 AM
Change PP after 1000 mi 6 month Short Winter Trips
by WillsYoda
02/07/16 12:00 AM
Tread Life & Curvy Roads
by Nick1994
02/06/16 11:46 PM
Nazmorgul, bhans, truthtracer, Recreator, 18LateModelFan
56842 Registered Users
84 registered (1989outlaw, 77GrandPrix, 90crvtec, 901Memphis, A1O, 5 invisible), 1292 Guests and 204 Spiders online.
56842 Members
66 Forums
244355 Topics
#2443533 - 11/24/11 06:51 AM 0W-20 vs 5W-20
Daryll Offline
Loc: Pennsylvania
I'm new so excuse if this has been discussed here elsewhere, probably ad naseum. In easy-to-understand layman's terms, what is the difference between these two? I see the 0 oil advertised by M1 and others as "for use where 0w-20 or 5w-20 are recommended".
Is that true? Can you really just substitute the 0 for the 5 oil? For reference I live in Pittsburgh and my car is garaged. Occasionally my wife will come out from work and her Lexus RX-330 will have been sitting outside in 0-20 degrees for 8 hours. And in the summer we MIGHT get a stretch of 90-95 degree days. But that's about as extreme as it gets. Most driving is city.
2009 Lexus LS460(M1 0W-20 Adv Fuel Economy)2006 Lexus RX330(M1 5W-20)2010 Toyota Corolla(Toy DealerDino 5W-20)2010 Honda CRV(Hon Dealer Dino 0W-20)
#2443562 - 11/24/11 07:50 AM Re: 0W-20 vs 5W-20 [Re: Daryll]
renegade_987 Offline
Loc: Ankeny, IA
You can easily substitute 5w20 with 0w20, just like M1 says. According to them, you'll still have warranty protection. All the 0 means is it can start easier in the cold then 5w.
2004 F150 181K Quaker State Green Bottle/FL-820s
2011 Baja MB200 Royal Purple 10w30
#2443567 - 11/24/11 07:56 AM Re: 0W-20 vs 5W-20 [Re: Daryll]
teddyboy Offline
Loc: NC, United States
You can certainly use either one without any difficulty; they're generally regarded as being close to inter-changeable. The 0 winter weight would provide some benefit at start up but plenty of people have used 10W or even 20W oils in your climate (and even colder) for years with good results.
You didn't indicate whether you were considering the 5W20 in dino, semi-syn, or syn. The 0W20 is generally available only in a full syn. For my wife's 07 Camry, I'm using 0W20 and stretching out the oci. It seems to be working well.
97 Camry M1 5W30 HM & OEM Filter
14 Camry TGMO 0W20 & OEM Filter
08 Volvo S60 M1 0w40 OEM Filter
#2443576 - 11/24/11 08:02 AM Re: 0W-20 vs 5W-20 [Re: renegade_987]
Pablo Offline
Loc: Duvall WA - Pacific NW USA
Ditto.
#2443598 - 11/24/11 08:37 AM Re: 0W-20 vs 5W-20 [Re: Daryll]
Cooper Offline
Loc: Mid-West, USA
Yes, and most times, the 0w20 is the better oil. Substitute 0w20 for 5w20 confidently.
2012 Nissan Xterra
2014 Subaru Forester
PENNZOIL ULTRA PLATINUM
#2443611 - 11/24/11 08:48 AM Re: 0W-20 vs 5W-20 [Re: Daryll]
jorton Online   content
Loc: San Antonio, TX
ExxonMobil has a line of oils that's supposed to make your car more fuel efficient. It's Advanced Fuel Economy Mobil 1 0w-20 and 0w-30. If everyone in the US runs this oil, we'll consume a little less fuel. It prevents metal to metal contact just like 5w-20 does.
6 of one, half dozen of the other.
"If everything seems under control, you're just not going fast enough."
- Mario Andretti
#2443633 - 11/24/11 09:05 AM Re: 0W-20 vs 5W-20 [Re: Cooper]
Bayman Offline
Loc: Indiana
Good Point, most if not all 0W-20 oil's a true synthetic or semi-synthetic. I do not think we have seen any Dino 0W-20
We do have quite a few Dino 5W-20
I do believe that the 0W-20 and 5W-20 oil's have different basestocks.
#2443669 - 11/24/11 10:00 AM Re: 0W-20 vs 5W-20 [Re: Daryll]
wiswind Offline
Loc: Wisconsin
In General terms....
The difference between a 0W-xx and a 5W-xx is that the 0W-xx has more resistance to getting thicker as its temperature goes down.
Also, the 0W-xx requires higher quality base stocks to do this.
This means that the 0W-xx is usually more expensive, but you get a higher quality product and a product that will be less thick for cold starts, which is a good thing.
Less thick means better flow at start up and until the motor warms up.
Remember Cold starts are not just when it is 0 degrees F out....even room temperature for us is a cold start for a motor.
A 0W-xx is a upgrade over the 5W-xx
At operating temperature, BOTH 5W-20 and 0W-20 are 20 Weight oils.
This is sometimes not understood.
Look at the HTHS value to compare most closely what the oil will be like in warmed up operation.
#2443830 - 11/24/11 12:31 PM Re: 0W-20 vs 5W-20 [Re: Daryll]
Daryll Offline
Loc: Pennsylvania
So other than cost, why even continue to make/sell/buy/use 5W-20? At my Walmart, by the way, both M1 oils discussed here cost the same...about $6 and change/qt. Plus the M1 0w-20 has the really cool and comforting and "green" label that says it's "advanced", too. So why would ANYONE buy the boring, merely silver label 5w-20 right next to it?
Edited by Daryll (11/24/11 12:33 PM)
#2443847 - 11/24/11 12:44 PM Re: 0W-20 vs 5W-20 [Re: Daryll]
cp3 Offline
Loc: Kitchener, Ontario, Canada
Because the popular misconcetption is that 0wXX is too thin.
Dodge Charger|Pennzoil Platinum 5w20|Mopar MO-744
Pontiac G6 GT|Mobil 1 0w40|Mobil 1 M1-101
#2443868 - 11/24/11 01:20 PM Re: 0W-20 vs 5W-20 [Re: Daryll]
Daryll Offline
Loc: Pennsylvania
Sorta like selling rotary phones.
#2443979 - 11/24/11 04:30 PM Re: 0W-20 vs 5W-20 [Re: jorton]
CATERHAM Offline
Loc: Burlington, Ontario, Canada
The most fuel efficient oil on the market is undoubtedly the EOM made Toyota 0W-20; it's much lighter than M1's own 0W-20 at most temp's but especially at typical start-up temp's. At 32F it's a whopping 35% lighter and even 25% lighter at room temperature.
It's in a league of it's own.
74 Lotus Europa, 5W-50
86 Porsche 928S, TGMO 0W-20 25% / M1 0W-40 75%
96 BMW 328i, Idemitsu/TGMO 0W-20 70% / M1 0W-40 30%
94 Caterham 7, FUCHS 0W-20
#2444272 - 11/25/11 12:13 AM Re: 0W-20 vs 5W-20 [Re: CATERHAM]
Oh no eek. Is hths viscosity ok at all temps?
- Mario Andretti
#2447422 - 11/28/11 04:00 PM Re: 0W-20 vs 5W-20 [Re: Daryll]
tig1 Offline
Loc: Illinois
I use M1 0-20 in both Fords that call for 5-20. The 0-20 performs very well for 10K OCIs and more.
2007 Ford Fusion 173,000 miles
M1 0-20 AFE
2007 Ford Focus 150,000 miles
M1 0-20 AFE
M1 ATF
M1 10-30 in all OPE
MC filters
