Kawasaki must be completely full of gas to start
by jrcowboys
16 minutes 34 seconds ago
Un-Screwing
by Ducked
47 minutes 58 seconds ago
BG 109 vs 120, any techs experienced w/ both?
by dccode
Today at 08:24 PM
Harder on engine, idling or restart?
by mattri
Today at 08:20 PM
Solvent/cleaner + 2 stroke oil for piston soak
by OldEuroCarLover
Today at 08:09 PM
Costco Canada Michelin wiper blades $9.99
by JC1
Today at 06:47 PM
Havoline Car Giveaway
by SatinSilver
Today at 06:47 PM
Opinions please
by ceast
Today at 06:41 PM
UOA, Pennzoil Platinum 5W30, 15K KM, 10 months
by ST2008
Today at 06:19 PM
Cruise control going downhill
by Donald
Today at 05:58 PM
O'REILLY SYNTHETIC OIL
by dooscoop32
Today at 05:10 PM
Anyone here a ice road truckee?
by car51
Today at 04:42 PM
therhett17, glldprimr, krankshaft, Tony_Rhed, greasemonkey1
58935 Registered Users
86 registered (AirgunSavant, barkingspider, 4WD, 9C1_guy, 2015_PSD, Bandito440, 6 invisible), 1351 Guests and 35 Spiders online.
58935 Members
66 Forums
253600 Topics
#2442636 - 11/23/11 10:07 AM Lexus ES 350 Oil Change ( oil Type and frequency )
m4s500 Offline
Loc: United Arab Emirates
Hello All,
I purchase 2nd hand Lexus ES350 from a friend , probably he could not afford to maintain it. I decided to maintain the can on my own with some visits to Lexus dealer for major work.
I have a friend who inspired me to put my hand in to service side, he recommends Castrol EDGE 10W60 like anything , he says this the ONLY oil I should use every 5000 KM. Technically I donít have much knowledge about oils but he says thatís the only oil.
Please could anyone tell me what is so magical about this oil that friend of mine only recommends this particular oil.
is this oli suitable for Lexus ES 350, doen around 80K ( KM)
I have no budget issue as such but donít want to pay the agency just for putting tick marks on the checklist and do nothing extra, I would rather learn few things while maintaining my car.
Cheers
Edited by m4s500 (11/23/11 10:17 AM)
#2442646 - 11/23/11 10:16 AM Re: Lexus ES 350 [Re: m4s500]
rshaw125 Offline
Loc: Raleigh ,NC CSA
That oil is way too heavy for the Toyota V6.
2012 Porsche Carrera S
1995 Plymouth Voyager
#2442652 - 11/23/11 10:20 AM Re: Lexus ES 350 [Re: m4s500]
SuperDave456 Offline
Loc: Dallas, Texas
60 weight oil in a Lexus?
I know you guys over in the UAE see some hot temps, but I thought we did also in Texas. Around here we run 30 weights in just about everything. If it calls for it in the Owners manual there is no problem running 20 weights.
Check out the owners manual. I would think you could go with a synthetic 30 weight or 40 weight no problem and get better gas mileage and probably better lubrication due to the increase in flow on start up. Even at room temp a 60 weight oil will be thicker than a 40 weight and therefor a little bit slower to pump.
Since it is already on a diet of synthetic I would stick with it. Unless it has some leaks or burns a lot.
I'm not even sure where I would go for a 60 weight oil around here. I have always found it interesting how overseas you can find all kinds of interesting oils that are significantly thicker than what we can find here in the states.
#2442655 - 11/23/11 10:21 AM Re: Lexus ES 350 [Re: rshaw125]
m4s500 Offline
Thanks rshaw125 for your prompt reply,
So you donít recommend Castrol EDGE 10W60 , which Oil would you recommend for Lexus ES 350 then?
Thanks Once againÖ
#2442669 - 11/23/11 10:40 AM Re: Lexus ES 350 [Re: m4s500]
semaj281 Offline
Loc: Suwanee, GA
Thanks Once againÖ
If it was my car I would look for the Valvoline white bottle, or the semi-synthetic Motorcraft in 5w-30.
If you prefer thick synthetics, try the Castrol Syntec 0w-30.
I would not go higher than a x-30 weight even with UAE temperatures.
09 Nissan Versa S Hatchback - Mobil1 SN 5w-30 and NAPA Gold filter
08 Ford Mustang GT/CS - Castrol Edge 5w-30 and Motorcraft filter
#2442679 - 11/23/11 10:51 AM Re: Lexus ES 350 [Re: m4s500]
bepperb Offline
Loc: Milwaukee, WI
5000km is a very short OCI. Double that would probably be normal in the USA, but I assume you drive in very dusty conditions and that is a factor.
60 weight is very heavy for the Toyota 3.5. I would think a 40 (0-40, 5-40 or 10-40, even 15-40) weight would be appropriate in your temperatures.
2004 Highlander 2.4
2011 Toyota Sienna 3.5
Recently Gone:
2006 Accord 2.4l K24A8
1993 Kawi EX 500
#2442689 - 11/23/11 11:05 AM Re: Lexus ES 350 Oil Change ( oil Type and frequency ) [Re: m4s500]
lexus114 Offline
Loc: Easton, PA
Hello All,
Cheers
WHAT THE!!!? No man, thats waaaay to heavy for this motor. Just stick to 10W30.
2012 Mercedes-Benz C300 4matic
2015 Lexus RX350 AWD
#2442730 - 11/23/11 11:54 AM Re: Lexus ES 350 Oil Change ( oil Type and frequency ) [Re: m4s500]
Veilside Offline
Loc: Murfreesboro, TN
Couldn't afford to maintain it? Really?
Aside from routine oil changes and tire rotations there really isn't any scheduled maintainance required for these vehicles until well past 100k miles. They carry timing chains, 100k plugs and coolant. Of course if he was putting 6.5 quarts of Castrol 10w-60 in at about $16/qt US then i can understand why maintenance was costing him so much since just the oil for an oil change would be $104.
When i owned my Camry V6 with the same 2GR-FE engine, i ran 10k intervals with factory cartridge filter and the cheapest brand name synthetic 5W-30 i could get, usually PP or M1.
2011 Hyundai Sonata 2.4 GDI
2010 Mazda CX-9 AWD
#2442820 - 11/23/11 01:08 PM Re: Lexus ES 350 Oil Change ( oil Type and frequency ) [Re: m4s500]
tommygunn Offline
Loc: usa
I'd definitely check the owner's manual.....I know some people over-think the whole ambient temperatues, and such....and the affects on Oil....but this engine should do fine with a 5W-30 or 10W-30......
i am a [censored] who hides behind bugmenot.
i also like applying negative pressure to a certain male appendage.
#2443018 - 11/23/11 04:47 PM Re: Lexus ES 350 Oil Change ( oil Type and frequency ) [Re: m4s500]
TJPark01 Offline
Loc: Hollywood, CA
Your friend, although well intentioned, is misinformed. The manual calls for 5W-30 every 8K.
From the 2009 manual:
"If SAE 5W-30 oil is not available,
SAE 10W-30 oil may be used.
However, it should be replaced
with SAE 5W-30 at the next oil
change."
2015 Range Rover HSE - Factory Fill
2011 E92 335i M Sport - M1 0W-40
2013 VW Passat SEL - Factory Fill
2009 Genesis 4.6 - M1 5W-20
#2444304 - 11/25/11 03:37 AM Re: Lexus ES 350 [Re: SuperDave456]
m4s500 Offline
Thanks SuperDave456....
#2444305 - 11/25/11 03:38 AM Re: Lexus ES 350 [Re: m4s500]
m4s500 Offline
Thank You All.. Gret info to start with ...
#2444319 - 11/25/11 04:34 AM Re: Lexus ES 350 Oil Change ( oil Type and frequency ) [Re: Veilside]
m4s500 Offline
@Veilside, Yes - I changed tires and spark plugs etc first time when I purchased it, what he was doing a regular 10K oild change at any petrol startion and thats about it...
#2444720 - 11/25/11 05:01 PM Re: Lexus ES 350 Oil Change ( oil Type and frequency ) [Re: TJPark01]
kozanoglu Offline
Loc: MKE
change."
That manual must be for the US.
Castrol Edge 10W60 is a nice option but you can use 5W40 or 5W50 also.
Valvoline is not sold in each and every country on earth.It is not global like Mobil,Shell,BP.
#2445423 - 11/26/11 03:33 PM Re: Lexus ES 350 Oil Change ( oil Type and frequency ) [Re: m4s500]
Falcon_LS Offline
Loc: Kuwait
Lexus offers their own branded 5W-40 synthetic. That's what I'd use every 10,000 km as instructed.
99 Explorer EB: GC 0W40/FL1A
00 Pajero: Aisin PAO/Ester 5W40/MD352626
01 Marquis: GC 0W40/51372XP
03 Expedition: M1 0W40/51372XP
05 Envoy: GC 0W40/51522XP
