Fishing reel drag grease
by bernau
07/29/16 04:26 PM
Sulfated Ash, wt%, ASTM D 874 test questions
by mbacfp
07/29/16 04:02 PM
HD radio
by 007
07/29/16 03:51 PM
Front end repair
by possum328
07/29/16 03:49 PM
Purolator 10111 Red Can
by FordBroncoVWJeta
07/29/16 03:30 PM
Carquest #R85372, 2013 E-250 van, 4,500k
by car51
07/29/16 03:03 PM
Strange failure: Starter AND flywheel cogs ripped
by lars11
07/29/16 02:22 PM
My email from Castrol about Magnatec
by Tech819
07/29/16 02:13 PM
Audi 5000 / Known Stop-Leak Compatible w/ CHF 7.1?
by Miles07PT
07/29/16 01:41 PM
Observations on Workplace corrosion
by Vdubuk
07/29/16 12:15 PM
Oil filter change NIGHTMARE
by MetalSlug
07/29/16 12:08 PM
First time flushing an 05 Tacoma
by Back40
07/29/16 11:53 AM
_hashtagusername, larrybroad123, dr_p, CapHead, rowebil
58632 Registered Users
82 registered (2oldtommy, 440Magnum, Al, 97f150, 901Memphis, 8 invisible), 2095 Guests and 12 Spiders online.
58632 Members
66 Forums
252411 Topics
#2437895 - 11/18/11 03:26 AM is 10w30 and 10w40 the same when cold
Dakota1820 Offline
formerly chevyboy14
Loc: missouri usa
so basically my question is in the title. I noticed my car having start up noise and more cranking to start it with 10w40 yes I was warned and did it anyway. the best way to learn sometimes is the hard way. is 10w30 the same as 10w40 cold and is 5w30 a real big difference at all ? thanks all
2004 Honda civic vp -m1 5w30
1998 Saturn sl2 -mobil super 5000 5w30
#2437914 - 11/18/11 04:47 AM Re: is 10w30 and 10w40 the same when cold [Re: Dakota1820]
crinkles Offline
Loc: Australia
the 10w-40 would be thicker. the 10w part relates to very cold temperatures, something like -30 deg c. at that low temperature, the cranking and pumping issues would be the same. above that temperature the 10w-40 is likely thicker for all temperatures.
the pumping spec for 5w and 10w is the same but 5w is tested at 5 deg c lower than the 10w. ow is tested at 10 deg c lower than 10w.
2002 Toyota Camry 2.4L
2005 Toyota Camry 2.4L
#2437938 - 11/18/11 06:20 AM Re: is 10w30 and 10w40 the same when cold [Re: Dakota1820]
Robenstein Offline
Loc: Central IA
The first number in a multi grade oil is always the cold viscosity, so yes a 10w40 and 10w30 are going to have the same cold start up flow characteristics. However at operating temperature, the 10w40 will be thicker.
If you need good cold weather pumpability and a thicker oil, you can try Castol 0w30 syntec. Its blended on the thick side of a 30 weight but still has great cold weather flow.
You could also go with something like Rotella 5w40
2011 Triumph Speedmaster
1986 Chevy Monte Carlo SS
1970 Chevy Nova
2006 Scion TC
#2437961 - 11/18/11 06:57 AM Re: is 10w30 and 10w40 the same when cold [Re: Dakota1820]
JAG Offline
Loc: Fredericksburg, VA
Generally no. For extreme cold temps., look at the MRV and CCS viscosities of the oils in question. For higher cold temps., use a viscosity calculator.
#2438002 - 11/18/11 08:01 AM Re: is 10w30 and 10w40 the same when cold [Re: Dakota1820]
addyguy Offline
Loc: Canada
The '10W' and '5W' values are a RANGE of cranking viscosities.
For 10W, it can't exceed 7,000centerpoise(cp) at -25 deg. C.
Within that range, different oils have different values, and, in general, a 10w-40 oil will have higher values than a 10W-30, b/c the over all oil is thicker.
For a fictional example, a 10W-30 oil may have a value of 5,600 at -25, while a 10W-40 will have a value of 6,600 at -25. Both are '10W' oils, but the 10W-40 is still thicker, and still has higher cranking values.
2010 Kia Soul 2U - 2.0L I-4, auto, 87k miles.
QSGB 5W-20, NAPA select filter(?)
#2438045 - 11/18/11 08:43 AM Re: is 10w30 and 10w40 the same when cold [Re: addyguy]
Drew99GT Offline
Loc: Colorado Springs
approved In addition, the 10w SAE cold testing is done at -13F for CCS and -22F for MRV. I hope it's not that cold in Missouri currently! 10w-40 will have a thicker overall viscosity at all temps.
#2438280 - 11/18/11 01:11 PM Re: is 10w30 and 10w40 the same when cold [Re: Dakota1820]
Dakota1820 Offline
formerly chevyboy14
Loc: missouri usa
at 30 degrees my Saturn doesn't want 10w40. I guess 5w30 will be best
#2438338 - 11/18/11 02:36 PM Re: is 10w30 and 10w40 the same when cold [Re: addyguy]
KCJeep Offline
Loc: Mahzurrah!
approved Great answer!!!
2004 Jeep Grand 4.0 @ 133k Pennzoil HM 10w30 w/ 1 qt 10w40
Fram PH8A
KIA Sedona 62k, Ford Focus 116k, Chrysler Sebring 186k, Chrysler Concorde 120k
#2439016 - 11/19/11 10:56 AM Re: is 10w30 and 10w40 the same when cold [Re: Dakota1820]
Drew99GT Offline
Try a 5w-30 High Mileage oil. I think your Saturn will approve.
#2439096 - 11/19/11 12:35 PM Re: is 10w30 and 10w40 the same when cold [Re: Dakota1820]
mechtech2 Offline
Loc: Chicago Area
Lots of varied information above!
The 5 and 10 will be the same at 0 deg F. Pretty cold.
At operating temp [oil temp, not coolant], a 30 is a 30 - they are the same.
And intermediate temps? The 5 will be a bit thinner than the 10 up to full operating temps [200 f or so].
#2439241 - 11/19/11 04:25 PM Re: is 10w30 and 10w40 the same when cold [Re: Dakota1820]
MrRPM Offline
Loc: Michigan
according to this http://www.bobistheoilguy.com/motor-oil-109/
a 10w-30 and a 10w-40 do NOT have the same cold temp thickness.
it appears that the 10w-40 will be thicker then the 10w-30 even though they are both 10w
weird
2001 Jeep Wrangler 4.0L, 5qts Quaker State DEFY 10w-30/1qt kendall GT-1 20w-50, FRAM XG8A (ultra)
#2439265 - 11/19/11 04:57 PM Re: is 10w30 and 10w40 the same when cold [Re: mechtech2]
Drew99GT Offline
They might not be (and usually aren't). Look at the viscosity index, and the stated viscosities and plug them into a viscosity calculator.
#2439700 - 11/20/11 09:02 AM Re: is 10w30 and 10w40 the same when cold [Re: mechtech2]
JAG Offline
0 deg F has nothing to do with the SAE J300 that governs viscosity grades: http://widman.biz/English/Tables/J300.html
#2439828 - 11/20/11 12:02 PM Re: is 10w30 and 10w40 the same when cold [Re: Dakota1820]
mechtech2 Offline
Loc: Chicago Area
Oils are rated at 0 deg F, and 200 degF.
How could those temps not be relevant?
But back to the original poster's question:
There are of course differences by mfr - there is a slight RANGE for any viscosity designation. it makes no practical difference - the difference is tiny.
Even two of the SAME oils could show some difference, and have in testing!
Edited by mechtech2 (11/20/11 12:05 PM)
#2439936 - 11/20/11 01:58 PM Re: is 10w30 and 10w40 the same when cold [Re: mechtech2]
JAG Offline
No they are not. Please read and understand the link I posted. This is a basic concept that nobody on this forum should mistake when posting. It makes the forum lose credibility.
