Smoked some baby backs today
by BeerCan
52 minutes 39 seconds ago
Ford FWD axle replacement
by 2009Edge
54 minutes 6 seconds ago
Saturn ac compressor
by spasm3
Today at 10:20 PM
looking for spray guns - analysis paralysis
by tomcat27
Today at 10:18 PM
WIX 51372 ADBV Failure
by WellOiled
Today at 10:11 PM
moly + engine coatings
by benjy
Today at 09:57 PM
Worth the upgrade?
by daves87rs
Today at 09:47 PM
Mr. Funnel does in fact work!
by TurboFiat124
Today at 09:46 PM
Will ATP205 help with a head oil leak
by NattyBoh
Today at 09:11 PM
Why is 100% gas more expensive in the city?
by TurboFiat124
Today at 09:06 PM
Trouble getting a copper pipe sweat fitting sealed
by NateDN10
Today at 08:58 PM
Murphy oil
by TurboFiat124
Today at 08:53 PM
NJ1911, SneakyTacos, DaveD, 8o8is, Texasdude74
58584 Registered Users
59 registered (AZjeff, abycat, ag_ghost, barkingspider, benjy, Blkstanger, 8 invisible), 1381 Guests and 8 Spiders online.
58584 Members
66 Forums
252216 Topics
#2432624 - 11/12/11 11:45 AM Mixing synthetic and conventional?
zerosoma Offline
Loc: Omaha, NE
Thinking since I have a stash of both Quaker State Green Bottle and Quaker State UD that I could make it last a little longer by adding half dino and half synthetic. They are both 5W-30. Would this be okay or am I asking for trouble?
Also, to make things cheaper, since I live in South Dakota with cold winters, I was thinking of running conventional in the summer and synthetic (for its flow properties) in the winter on both our vehicles.
Is this change from dino to synthetic every year bad? I would probably put dino in around april or may and change it to synthetic around october/november.
Just looking for some input. thanks!
2004 Hyundai Santa Fe LX 3.5L V6 (125k) [Valvoline Max Life Next Gen 5w30]
#2432631 - 11/12/11 11:52 AM Re: Mixing synthetic and conventional? [Re: zerosoma]
Loobed Offline
Loc: Northern California, USA
Yes it is OK. I have been doing that to get rid of some 15w-40 oil I got for 25 cents a quart and some 5w-20 QSUD I got for $1 a quart. I mix it 50/50 and get something like 10w-30.
Engine: 2001 GM 5.3L LM7
Current Fill: Valvoline Synpower 5w-30 w/Pure-One PL25288 filter
I.M.N Oil Enthusiast
#2432634 - 11/12/11 11:59 AM Re: Mixing synthetic and conventional? [Re: zerosoma]
hate2work Offline
Loc: Western Washington
Don't do it, it will ruin your engine, especially in South Dakota!!!
Just kidding smile
Google is your friend...
https://www.google.com/search?q=mixing+s...amp;safe=images
#2432637 - 11/12/11 12:04 PM Re: Mixing synthetic and conventional? [Re: zerosoma]
oily boyd Offline
Loc: WI
I do it all the time.
I fill my 09 camry with 4.5 qts of PU, PP or M1 for an interval of 7.5K miles.
I then top up with PYB or Super 5000 - half a quart every 2k miles. Car has 160k on it.
Kind Regards,
Boyd
#2432646 - 11/12/11 12:16 PM Re: Mixing synthetic and conventional? [Re: zerosoma]
daves87rs Online   content
Loc: Michigan
Not going to hurt..and it may even help.
That's the treatment my Cav gets now Convent-summer/syn-winter...no issues at all.
Whatever you are, be a good one.
#2432654 - 11/12/11 12:24 PM Re: Mixing synthetic and conventional? [Re: zerosoma]
kozanoglu Offline
Loc: MKE
What comes out of the mix of 0W50 and 0W-20?
I have some Eneos Sustina 0W50 which is not good for any of my cars on its own and Toyota 0W20.
#2432760 - 11/12/11 03:11 PM Re: Mixing synthetic and conventional? [Re: zerosoma]
fdcg27 Offline
Loc: OH
This won't cause any problems.
It's all oil, and the syn you're using is a highly refined mineral oil anyway.
I'd go with your plan and use the QSUD during the winter and the QSGB during the summer.
Don't mix the two, use them where they will perform best.
The QSUD would be a good winter oil, or a summer one, for that matter, while the QSGB will be fine for warmer weather.
12 Accord LX 53K HGMO 0W-20
09 Forester 67K PU 5W-30
02 Accord 144K GOil 5W-30
01 Focus ZX3 112K M1 5W-20
95 BMW 318iC 159K Delvac 15W-40
#2432801 - 11/12/11 04:23 PM Re: Mixing synthetic and conventional? [Re: zerosoma]
Papa Bear Offline
Loc: Leamington, ON, Canada ..... r...
Per Valvoline.com's webpage:
Can you mix different types of motor oil? For example, synthetic and synthetic blend or regular and synthetic? Is this going to cause problems?
Mixing synthetic and conventional oils will not cause any problems. The oils are compatible with each other.
I never was too bright - now old age and forgetfulness complicate things as well" crazy
2016 Dodge GC deep cherry CVP drive
#2433630 - 11/13/11 06:04 PM Re: Mixing synthetic and conventional? [Re: Papa Bear]
fdcg27 Offline
Loc: OH
That's nice, but last that I looked, neither QSUD nor QSGB were Valvoline products.
#2434175 - 11/14/11 12:54 PM Re: Mixing synthetic and conventional? [Re: kozanoglu]
Loobed Offline
Mix 2 quarts of 0w-50 with 4 quarts of 0w-20 to get something close to 0w-30. There are other factors, but it will be close to a 30 weight.
(50x2)+(20x4)=180 ===> 180/6=30
#2434183 - 11/14/11 01:14 PM Re: Mixing synthetic and conventional? [Re: zerosoma]
teddyboy Offline
Loc: NC, United States
It's called semi-synthetic although your blend would probably be heavier on the synthetic side which should be a good thing. Hence it would probably be a better blend of syn and dino for the same or less money.
97 Camry M1 5W30 HM & OEM Filter
14 Camry TGMO 0W20 & OEM Filter
08 Volvo S60 M1 0w40 OEM Filter
#2434184 - 11/14/11 01:16 PM Re: Mixing synthetic and conventional? [Re: zerosoma]
lexus114 Offline
Loc: Easton, PA
its okay and all to do so, I just dont know why you want to bother. IMO just do one or the other.
2012 Mercedes-Benz C300 4matic
2015 Lexus RX350 AWD
#2435287 - 11/15/11 02:15 PM Re: Mixing synthetic and conventional? [Re: lexus114]
zerosoma Offline
Loc: Omaha, NE
Conventional is cheaper, I have a stock of synthetic and I'd like to make it last longer.
Edited by zerosoma (11/15/11 02:16 PM)
#2439290 - 11/19/11 05:35 PM Re: Mixing synthetic and conventional? [Re: zerosoma]
otis24 Offline
Loc: South Dakota
I work at a Ford dealership. I can buy my oil at cost +10%. Needless to say, I can buy MC sytnthetic blend very cheaply and I can use the shop's lift, tools and dispose of my oil there. I run 3 qts MC syn blend and 2 qts MC full synthetic. If I did my math correctly, I'm getting a 64% synthetic.
Edited by otis24 (11/19/11 05:37 PM)
1991 Chevrolet K1500 (4.3, 4x4, 86k miles)
2009 Chrysler T&C (85k, 3.8)
